2001 Saab 9-5: Puff of white smoke on start up
I just bought a 2001 9-5 sedan with 19,000 miles. At the dealership, a puff of white smoke came out of the exhaust on one of the start ups and the salesman explained it away with detailed talk of the turbo, "it's a saab thing", it only happens when the ignition is in ON for a bit before you start it, etc. I test drove it a couple times on different days and it didn't happen at each start up. So I buy it (both the story and the car) and of course a huge puff of white smoke envelopes the car on my second start up (wasn't in the ON position for any length of time). I'm thinking exhaust should always be invisible and have been told it could be the turbo needing to be replaced. Is this a Saab thing?? Anyone else every heard of this? (we're talking huge puff of smoke) Thanks.
A huge puff of white smoke (not light blue) is emblematic of moisture in the combustion chamber. Could be a blown head gasket or some leakage due to acracked cylinder head or engine block. Cylinder head pressures with a turbo motor are extremely high and abusive driving with a lack of maintenance can certainly cause problems.
I'd get this one to a Saab specialist or a Saab dealer ASAP. Its still under warranty.
A bad turbo would suck up oil and the smoke would be distinctly BLUE. Same with valve stem seals. Both a bad turbo and bad stem seals are often diagnosed at start up, that's true, but the WHITE smoke is a give-away that these two items are not at fault.
I'd have the cooling system pressure tested and have a compression test done. I'd bet the bad head gasket will show up.
You don't want to mess around with this, because if the head gasket is dripping water into the combustion chamber overnight, it could theoretically drip enough to actually fill up one cylinder. Then, when you crank the engine, the piston will try to compress the water, which of course is impossible, and you will bend a connecting rod and perhaps damage the crankshaft.
Although I love the car, I am starting to question the cost of maintaining it after the warranty is over. I've had a few things replaced under warranty already. I push the car pretty hard but I have it serviced every 5K miles.
But if the smoke happens on pullaway starts, smells like oil and then goes away...well that's not what we're talking about here. Is it?
Remember it this way--if the white smoke doesn't go away, THEN you have a problem. If it disappears after a few minutes, it's just water vapor. Part of the chemical equation for the combustion of gasoline includes H20.
