Is it still worth trying to reset the limit switch?
I believe the reset does more than just reset the limit points. It actually resets the tiny microcontroller that controls the drive motor for the window. So you have to go through a learning sequence of some sort for it to re-learn where the up and down stop points are, for instance.
Next step is to pull it completely apart to find out why the motor would be loose.
I would Appriciate the help
now i removed cover and can see oil around the filter and oil pan gasket but everything is tight and not leaking at pan or filter do i need to replace this hex nut o ring above oil filter too ?
some have told me to replace the oil pressure swith that screw into the block located above the oil filter
is this an o ring problem or what ?
please help dealer told me it would be $1200 to fix this leak
Also, any chance you're tightening the filter too much?
Just checking the basics first....
the oil pressure regulator valve attached to the oil pump so that would require removal of the oil pan.
If so, the next thing I'd do is get an oil filter from Nissan. They have built-in pressure relief valves.
a good repair shop can also put a dye into the oil and use a black light to find the source of the leak.
Other possibilities...........loose bolts on oil pan, failed oil pan gasket, failed head gasket, but this last one is very costly to fix, so cross your fingers that it is only the dipstick!
