http://www.alldata.com/tsb/Acura/1160204400000_1161759600000_06-039/index.html
They are internal documents which a manufacturer will send out to service providers. Some are just legal notices. Some are suggestions for how to troubleshoot problems. Some are complete fixes for known problems.
In the past, Honda's CR-V had problems with pulling to the right. One of the solutions was making sure the damper spring was properly aligned on the upper spring seat. I dunno if the MDX suspension is a similar set-up, but I didn't see that listed as a possible culprit in that MDX TSB.
I hear it sliding and thumping around when braking and going around corners.
It's driving me nuts!
I called and talked to Acura again.
They have since had other MDXs come in with this same sub woofer rattle complaint.
They have found some vent near/in the rear bumper causing the noise and now know of a solution.
I'll believe that when I see it. (or should I say, hear it)
As for the new noise, most likely their last solution coming loose... ugh.
Dropping it off on Jan 8, will keep ya's posted!
Okay... last installment!
Got the MDX back last night.
The new noise, a screw which came loose in the rear panel.
That, they corrected.
As for the subwoofer vibration, it has NOT been corrected.
It was explained to me that it is a vent within the rear corner of the car.
As the subwoofer displaces air, it flows through this vent and causes the horrible vibration, and cannot be corrected.
I don't buy this.
You'd figure that the "high-end" stereo in their $45,000 Touring package would not rattle.
Turns out all 06 (and below) MDXs have the problem.
You'll only notice it depending on the music you listen to, the settings for your bass and treble and the volume.
And no, I'm not a rolling 'gheto-blaster'
Not sure what I'm doing yet.
Maybe a good first step would be letters to Acura and Bose to see what may come of it.
On my Xmas roadtrip, I could hear some slight vibration/tremble in the rear subwoofer when XM played certain music with super-bass. It doesn't happen often but definitely exists. Mine is '06 model.
sisu1996
And it's not just music.
Listen to talk... it happens a lot.
...and not just at loud volumes.
I personally feel less than impressed by the Bose stereo in this vehicle.
I tried different combinations but did not experience any rattling on my 2003 touring. I tried it with rock/pop/heavy metal and also with a music DVD. I didn't want to end up with the rattling so I quit
play anything with lower bass notes and put the volume somewhere around 7-9 (louder if you want an obvious vibration)
Hop out of the car and walk around to the rear passenger corner and you'll see the lower quarter panel vibrate.
This vibration can be heard as well.
At first, I only heard this when outside of the vehicle.
Now, my ears are tuned to it and I here it inside as well.
I here it when listening to my music (and the wife's which is much calmer music that mine) but I also here it when I'm listening to talk and when my daughter is watching movies.
It's not horrible and I suppose I'll have to live with it, but it is definitely there, and shouldn't be.
This isn't a $14,000 Scion, it's a $45,000 Acura with an optional Bose stereo, which I'm actually very unimpressed with.
I have the 07 Sport/Entertainment model....
The lawsuit is against Honda/Acura as well as the manufacturer of the odometers.
If the plaintif wins, all 02-06 owners will receive a 5% milage extension to their existing warranty.
I got my notice 2 nights ago. I have not noticed any discrepancy in milage on my 06 MDX, but I haven't exactly tested it either.
As soon as I asked for Acura's contact information, their tune completely changed.
They have offered to take the MDX in for 3-4 days (???) and I will not get it back until the problem is resolved.
Knowing that I have been on the G35/TLs fence, they have offered me an 07 TL Type-S loaner for those days.
This is their 5th and last chance to make good on this.
We'll see what happens.
It's due to go in on my next oil change, which is about 3 weeks out.
:sick: :sick: :sick:
I have a 2003 MDX in which I just found out that the warranty has expired. (4 years). I only have 47K miles. i guess I will have to find an Acura Auto repair shop. Does anyone know of a reputable repair shop in the DC Metropolitan area, preferably in Maryland?
It's also 06 MDX bought in Dec 05.
You have a bad battery or an abnormal battery drain condition.
BTW, I have my Treo 700wx successfully paired with my 07 MDX and it works great for voice calls. I haven't tried any other features like phonebook import aa I did not want to transfer my 1000 odd contacts to my car.
Question; What does Acura do differently? I don't see any gripes about this vibration. Is there a difference? Does anyone know if the 07 MDX (thus the 08 Pilot) has re-engineered the drivetrain? If Honda has, I am buying an 07 MDX tomorrow! (even with all its problems). W#hat other forums are out there? Good motoring! solo
P.S. I wonder if its time to go back to my Tahoes!
SUVs and Smart Shopper
Tony
2007 MDX, ENT/TECH
Gary
4,500 lbs of boat trailer.
This assumes you have a tranny cooler installed.
One thing to note... MDX specifications for the 2001-2006 model years are published assuming the vehicle is also hauling 4 occupants and their gear for a weekend. Most other companies assume only a driver and zero gear. So, their numbers are inflated a wee bit.
For more, read up on this link (scroll down to the bottom).
Taking MDX for 12000 mile service check on May 14. Mentioned the hood vibration to service department on the phone and they said MDX "hood does shake some". This is getting to feel like a design flaw on Acura's part. Any comments?
The oil changes usually cost around $ 34.95 however you would also need to change the Rear differential fluid which is expensive and can add up to $ 200 and change.
