The car base remains firm and intact where the belt crosses the base, but it moves up from the seat as you go further away from the belt. I am not sure how to overcome that issue and whether it is an issue to begin with. Either way, once you set up the car seat, I would highly recommend getting it inspected at the local police station. They do the inspection for free. Statistically 70% of the car seats are not installed accurately as per responses collected from cops.
Good luck and congrats in advance.
When did you 2007 X owners first took your car for any sort of regular service ? What mileages and which month.
Was is dependent completely on the maintenance minder system ?
Was it simply a oil change or did you guys get something more done ?
I was planning a trip from MA to IL, and wanted to get the new oil in before I left.
The dealer turned me away and told me to wait until I got back.
They explained that Acura uses special oil with additives to assist with proper break-in, and early changes were not recommended.
First I had heard of something like that, but I did as they told me to do. :confuse:
I bought 07 MDX with Tech package in 11/06. Have noticed 2 problems for which I ave already been to the dealer once without a fix ( BTW the dealer is in St Louis and I live in Columbia, MO about 120 miles away).
1. XM radio reception issue: While driving or parked the radio looses reception and all I get is static. People at XM say that the factory radio is faulty and Acura says that all is well. My friend has a Pilot with XM and has no problems. :confuse:
2. Rear suspension noise : Whenever the car goes over evena small bump there is a noise from the rear suspension area which sounds like a thud. Sounds like a strut is bad. Dealer test drove the vehicle and told me that it is from 3rd orw seat. :confuse: .
Wondering if anyone else has the same problems. I am going to St Louis again on Saturday to get this fixed. Would appreciate any input.
P.S - sorry about long wordy message.
I have been seeing prices around $20,000 to $22,950 (33k to 60k miles) here in NJ and NY. Is that a good range?
Thanks in advance for your inputs and for taking the time to answer so many questions :>)
R
Do you keep the 3rd row up or down? Whichever way you do it, try driving around with the seat in the other position. If the noise goes away, your dealer is probably right.
All you may need to do is place a small chunk of rubber or foam under the seat to create something like a recoil spring. It will soften the "landing" when the seat frame comes to rest after being lifted by a bump.
I bought a 2004 touring model back in November of 2005. I purchased through a dealer. Checking the title, we found the vehicle had been on the road for 18 months. It had 33K miles on it at the time.
No major known problems with the 2004 models. It appears the tranny issues with earlier years were sorted out. Posters here and in other forums have reported a number of issues, but not many that are epidemic.
Mine has been flawless, but I've only had it for 18 months myself. It now has something like 68K miles on the odo. I'm averaging 21.4 mpg with a 60/40 split between highway travel and suburban streets. I see plenty of stop and go on crowded highways, but almost never do real city driving.
No idea what pricing is like today.
I just bought a 2007 MDX Tech package 6 days ago and also noticed a slightly loud noise from the rear when hitting even the smallest of bumps. I was thinking that I may be being a bit paranoid, so I am glad I found your post. I too was thinking that it may be from the 3rd row of seats being folded down. I then also checked that the spare was on tight underneath and not hitting the undercarriage with every bump. For now I have just been turning the radio up a bit so I dont hear it as much. Great solution huh?
Did you make it back to the dealer again? If so did they do anything to fix it?
D. Wilson
Since i have the warranty i am sure the dealer is going to play the cat and mouse game and i want to be fully prepared.
you might have loose compressor mounts or some such?
Any thoughts on the lifespan of MDX batteries/warranty.
A Tip: If your battery was truly run down and barely turning the engine over, it's not a good idea to charge it with the alternator. This puts a lot of strain on the alternator, and repeated use of the alternator as a charger for really dead batteries will lead to a premature failure of that unit.
Tiffany.
If you use a cleanser with a degreaser, it will suck the natural oils out of the leather hide. The leather will end up dry and may crack.
My car MDX is about 5 weeks old and I noticed the rather loud clunking noise coming from the rear right from the get go. I have yet to bring it to the attention of the dealer. I was planning to wait until my first oil change. I have been trying to figure out what it is but havent had any success. The car is great, has a smooth ride, but that noise when I hit even the smallest of bumps is driving me nuts.
If anyone gets a reasonable explanation of where the noise is coming from and what the fix is please let post on this formum.
Scoot84
If anyone has had this problem, and had it fixed, please let us know what it is.
David
Love this website. Good info from all you folks. Wish me luck!
Jack H.
I have been researching the purchase of an mdx sport 2007. This blog has been a great resource. I believe that I have found a possible explaintion of the clucking issue. An Acura service bulletin has been issued. Here is the link to the bulliten I have found. Within the bulletin is the cause and vin numbers effected.
http://www.in.honda.com/Rjanisis/pubs/SB/B07-033.PDF
BTW: I also have an airvent on the front dash (top) that keeps popping up. Anyone else has this issue?
The dealer was contacted and he recommended calling Roadside Assistance and let them decide what should be done. Road Assistance came and decided the MDX should go to the dealer for repair. It was loaded on a flat bed truck and taken to the dealer that had serviced it. Everyone was most helpful in solving the problem.
After inspection by the dealer, it was determined that the oil was the old oil that had gone into a "catch basin" while being drained. The catch basin had not been cleaned out properly and the old oil had ultimately spilled out onto my garage floor. (This whole explanation seems a bit odd) The vehichle was later picked up by my grandson and returned to my home.
I don't know how much expense was incurred by the dealer in this exercise, but it probably was considerable. In any event, it certainly raises severe questions as to the quality control of the service dept. of my local dealership. If a simple task as an oil change and filter plus tire rotation cannot be done correctly, then what happens if I should have a real problem?
Jack H.
The price was going to be $1,094, so I said I would think about it, as I wasn't sure I needed if fixed that bad. Anyone had an experiences with backup cameras gone bad?
I inquired at the dealer if the audio back up system was available. It is, for a price of about $1000.00. It annoys me to pay an additional $1000 after I have paid for the backup camera and NAV system in my original purchase of the vehicle. Is there an aftermarket audio system available any where? Comments please.
Jack H.
barb36jack31@yahoo.com
Now, maybe you can help out on the loud popping sound when I start the car. It happens sometimes and sometimes it does not. I ask the service manager and he said it was related to Ethanol fume that is combusted when I start the car. He said it happens on his Toyota but I am thinking how could that be? It is so random that what he say does not make any sense. It happens when I have full tank or 1/4 tank. Anyone else have that strange pop when you start your MDX?
each time when the car got started each morning, right after the engine started, a "Bong" sound was heard. There
can be repeated several times. Afterwards, when the engine got started again, there was no such sound. Has any one
had such experience?
Appreciate very much for your comments.
Rick b.
Has any one else had problems with the engine mounts, especially if you did not know there was a problem in this area when you took the car to the dealer?
You may be interested in Edmunds' new Dealer Ratings and Reviews - you can rate/review your dealer service there.
Prior to seeing the TSB posting, I took apart the back trunk area trying to identify the noise and did find a part loose. Some plastic clip was popped out and rolling around. So if it is not a clunking sound like the spring, it maybe something else. Good Luck. I agree that for 40+K, this should not happen.
I too brought my car in to the dealer and even printed off the report from Honda so they could see what to do. When I left the dealer the car was no different than when I brought it in. If I hit even a crack in the road it sounds like I hit a 2 foot deep pot hole.
I don't want to just deal with it, but I also dont want to be backand forth to the dealer over and over again. Anyone from NJ had this problem fixed by a good dealer?
