'99 Ford F-250 Superduty 4x4 with Triton V-10
i'm looking at buying a 1999 Ford F-250 Superduty
4 x 4 Crewcab and trying to decide whether to go
with the standard 5.4 Liter OC V-8, or upgrade to
the Triton V-10. I plan to tow 6000 lbs camping
trailer and also plan to put the snow blade package
on it for the winters. any input would be
appreciated.
appreciated.
V10 should get as good as v8,better under moderate or bigger load.
The reason they went to the v10 is for better milage and less pollution than a big v8.
Level highway solo best leg 14 mpg. Towing a 28' travel trailer,(6860lbs)same leg 10.4 mpg.
These figures sound very realistic to me. More believable than 16 mpg around town.
0-60 10.3 sec solo (pretty good for 6500lb van)
0-60 27.6 sec towing
If you can find a Super Duty in Lariat trim, you will find a MPG/compass just above the rear view mirror. You can get an idea of mileage by resetting this as you drive: set to average miles per gallon and reset by pushing both buttons at the same time. None of the salesman know how to do this.
I have friends with the V10, 7.3 diesel and the 5.4 engines. The V10 got 10 MPG with no load in around town driving on the first tank. You might get 13 on the highway empty but we will have to see. The 7.3 diesel gets 17 on the highway empty. No word on other driving conditions yet. The 5.4 in an F250 4x4 non super duty is only getting 11 empty and 9 with an 8,000 lb. 5th wheel trailer. It is underpowered with the 5th wheel and he wishes he got a super duty with the V10.
A 1991 F250 with the 7.3 non turbo got 13 MPG no matter what the driving conditions. At 170,000 miles the engine blew a piston and had a $7,500 repair bill. Mechanics say this happens to 1 out of every 50 7.3 Ford diesels. Diesel mechanics generally prefer the Cummins over the Ford diesel motors because they are easier to work on and cheaper to repair. The Cummins diesel in Dodge pickups my friends have gets 20 MPG empty and 15 MPG under heavy load. The new 24 valve Cummins is as quick as the new Ford but doesn't have as much torque.
I am leaning toward the F250 4x4 crew cab short box but am undecided about the motor. If the diesel gets an average of 5 MPG better and the fuel cost is the same, it will take 50,000 miles of driving to bread even on the extra cost of the 7.3 diesel motor over the V10.
I am very interested in MPG real life for the V10 and real life MPG for the new 7.3 diesel. Another friend has a 1996 F250 with a 7.3 and she gets 12-13 MPG empty on country road driving going 70 mph.
regarding your question concerning real life fuel mileage for the 7.3, I can give a little input. I now have a little over 2,000 miles on my 250, crew cab, four wheel drive with the short box. Highway mileage at 65-70 mph with a medium load has averaged 18.5 or better. I expect the mileage to improve as the engine breaks in. However, I don't expect a phenomenal gain. For now at least, I am glad I got the diesel.
If you haven't ordered yours yet you may want to spring for the power trailer tow mirrors and running boards. That right hand mirror is too far away to adjust and it's a real climb to get in without the running boards.
Hope this helps.
I have a Dodge 2500 Quad Cab 24V TD w/3.55 automatic. I get 17 in town, 21 hwy, and 14 towing 6500 lb 5th wheel.
