maintenance on Toyota vs. Honda vs. Nissan
I was having a discussion with a friend who swears that maintenance on Nissans and Toyotas are a lot easier than Hondas. He claims that its easier to get to most items on toyotas and nissans. I have an accord and do find that most parts are packed closely to others.
Does anyone else feel that toyotas and Nissans are easier to work on?
HOnda V6's are easier to change the spark plugs....much easier.
The Toyota V6's are easier to change the oil filter than Honda V6's.
Fuel filters are a pain to do on Toyotas.
I have 250,000 miles on my honda and did no work on it other than 4 belts and option to change water pump. my sons 89 prelude did take an alternator once [located on the top front came out in fifteen min
i have never had a drop of oil leak out of any of my veh. or do they burn oil
all i can do is wonder if toyota and nissian can hold up to these high standards in a test of time
hobieslug, you're wondering if Toyotas and Nissans can withstand the test of time as well as Hondas do? I can tell you Toyotas will. I've seen plenty with over 200K, and a few with over 300K. In fact, a friend of mine still has his '78 Corolla, and the last time I saw him, it had over 375K on it, and the engine has never been apart. It may have over 400K by now. I can't speak for Nissans, I've never had one, and I don't anyone who has.
Newcar31 I agree with you. If you buy a Mazda get one that still has a Mazda engine and transmission or you will be short changing yourself on durability.
don't think it would be worth it for you to make this tool,you would need access to a shop and some fairly expensive tools [3/4 drive]
if your still interested e mail me hobieslug96@peoplepc.com
water pumps on hondas are fairly easy
hardly any surface cleaning just make sure the o ring stays in its grove
I change it with every timing belt [thats every 90,000 miles] if you do a belt and you don't do the w/pump it could leak shortly after and that would mean doing the whole job over again
I did 7 belts which made the tool worth while
To tighten position rachet with pipe extending underneath the car and bump the key once now it's tightend. This method is useful if one does not have access to a compressor
all hondas are counter clock wise rotation
bumping the starter will only tighten the bolt or break it
there are a few ways to break this bolt freed but the crank bolt on hondas are so tight honda decided to make a hex cut out on their pulley's for a tool to fit in
on one honda I broke two snap-on impacts with a 1/2 in. drive I.R impact I have a 3/4 socket and gun using shop air with a larger air line[1/2 in. dia] there is no problem
