Lexus ES300 problems
I am pretty sure that I shut the car doors last night (as always).
While I like the car, it is proving to be less than reliable. Every morning when I get into the car, I keep my fingers crossed. I have owned many cars in the past (Accord, Camry), and have never had the battery ever die on me.
The car also has a buzzing sound around the passenger area. Dealer has acknowledged the problem and has tried to fix it on two occasions. No luck
The car has been to the dealer 5 times in 3 months for the above problems.
Any ideas. Do I have a possible lemon?
Thanks for your help
My 02 also has the same buzzing sound in the front passenger area but it comes and go. Last time it last more than 30 minutes and it was loud enough to cause me a headache. But it was gone by the time I got to the dealer. Anybody has a fix?
My question is, how hard is it to replace them?
What would be required to do to remove the instrument cluster to get to the old bulbs? Any help would be greatly appreciated.
Since most drivers don't know the feel of a good shock unless they bought the car brand new and the decline is so progressive and slow ...... Lexus and Infiniti have adopted the leak test which is far from valid........to make these cars appear less costly to maintain and to avoid the hassle and cost by not covering them as a wear and tear item.
Rubber isolated suspension pieces also wear and need replacing to reduce the initial slop in the first 1" of body movement.
Just do it and you will return the ride to close to new.
The rebound stiffness [the force opposing/slowing the bump compressed springs return and overshoot is critical........without it the rear sways and jumps up excessively.
Do you know if disconnecting the wire harness erases any info such as the digital mileage info?
Guys and girls, can anybody suggest a possible cause? Appreciate your inputs!
So check with dealer... or ask around...
I have the same problem with my 97 ES300 stereo readout. It works fine, but it almost completely black now. Have you sent yours in for repair? Are there any other options you can think of? What action do you plan to take to resolve your problem? Thanks in advance for any suggestions.
Anyone else hear this?
Otherwise, I love this car. Bestluxury for the money.
What could the problem be? the electrical system went under a load test and the battery and alternator checked in fine. Now, the dealer did say it may be the starter. Basically the tech at the Lexus dealer said that the starter may not be making the electrical connection. Now, of course, when I took it to the dealer it starts perfectly. Therefore, they can't say for certain if it's the starter or not.
Any ideas?
The other thing is I thought the fuel filter was due to be changed in the 60k mile service but Lexus is saying that it is a "lifetime" filter and if/when it is changed, the fuel lines will need to be changed as well. I've never heard of anything like this before.
Any info. will be appreciated. Other than the check light, I like the car. Thanks.
1. The weather is humid.
2. It rains.
3. When the air conditioner is in use.
I first complained to the dealership. Their solution was to execute some ambigous cleanup procedure and spray a freshener which proved only to be a temporary solution. After a few months dealing with the problem with the dealership, they left me with an impression that there was nothing they could do. Which meant I would be would be either sweating to death on a hot summer day by not using the air-conditioner or braving the obnoxious fumes while the Lexus people set in the comfort of the offices breathing fresh air conditioned air. I called the Lexus customer satisfaction line which gave me the run around several times. They insisted that it was a problem with the type of fuel (supposedly high sulfur content) being used on the east coast. As far as they were concerned the car was operating normally and that there was nothing to be done. The only thing they suggested I do was to find a better type of fuel and run a few tankfuls through the car. The conversation with Lexus left me puzzled. I was breathing car exhaust fumes throught the ventilation system and that was considered normal. I explained that the problem was only when it was damp outside or when I use the air-conditioner. Lexus (customer service) was hearing me but they were not listening to what I was saying. After a few more phones calls to Lexus and drilling my experiences with the car into their heads was when they understood what I was saying. My situation was now referred back to the dealership where they replaced the air conditioning filter (05/15/03) assuring me that the action be the final solution to the problem. Well, it was'nt. Now it's back to dealing with the Lexus service manager and if necessary Lexus Customer Satisfaction. If they do not come up with more concrete measures, then I will have little choice but to start the arbitration process. Stay tuned!
PS. I haven't mention the transmission problem and various creaks and rattles in a 38+k car. I can't beleive I passed up a Acura RL and a MB E320 for this adventure.
That is exactly the same suggestions the Lexus dealer and Customer Satisfaction gave me. I was also told that is what a new car's air conditioner suppose to smell like. I owned total 9 new cars over the last 25 years, Japanese, domestic and European. Nothing smell like this Y2K ES300's air conditioner.
http://us.lexusownersclub.com/forums/index.php?act=ST&f=7&- ;t=1276&st=15
Also, complaints on the tranny can be called into the National Transportation Safety Administration.
1-888-DASH-2-DOT. It's easy to do. I would urge you to do it if you're having problems.
