can't get my keys out!!!!! help!!!!
I need some help real quick. My son's 97 grand am has the keys stuck in the ignition. The car will start and run, but will not shift out of "park" making it impossible to drive. I tried everything I could think of (jiggling the steering wheel, rocking the car, etc.), but nothing I did released the key or allowed me to shift out of "park". I noticed that a "Theft Sys" light was illuminated on the dash board. The car was bought used and didn't have an owners manual with it. Finally, I just disconnected the battery to get the lights to shut off. If anyone has any suggestions, PLEASE respond quickly. It's Friday evening and he needs the car for work Monday morning.
1. Turn ignition to on--don't start.
2. Move shift to neutral
3. Start car.
4. Shift will work normally.
The tech said that it might be the ignition switch (which they'd replace free) or the neutral safety switch. They'd do the ignition switch first and if that took care of it there'd be no charge. Apparently that was it because they fixed it for free. Either that or the problem was non-reoccuring and is just waiting to happen again. This happened once before and I'm sure it was the ignition switch that was fixed. That was my fault because I was hanging too many keys off of it. Let me know if the neutral safety switch is the same thing as the shift interrupt switch, or if it's another part altogether.
I've had the neutral safety switch go out on an 87 Nova and it was in the area of the transmission. This malfunction (at least the first one which was repaired) was in the ignition switch. Like I said, caused by too many keys.
The neutral safety switch is the same as the starter interrupt switch, it goes on the trans under the shift lever.
Did you have a problem getting the car out of park or just a problem turning the key? If you had a switch meltown that would cause you to not be able to turn the key, but if you couldn't get it out of gear that is an unrelated issue.
