2002 HD W/locking rear diff ?????
                    Is it necessary to change the rear diff fluid at 3000 miles?  My dealership tells me it is, or are they just looking for money?  Any help would be great.  I want to do the right thing.
Mike Smith
Mike Smith
Swoosh Man
first change is important, then you can probably go the life of the truck......
I did mine a week ago @ 5300 miles. Fluid was dark, and smelled burnt, but thought fresh stuff was rather stenchy, too. I used Mobil1, with a new gasket.
BTW no magnet on diff cover, either.
-Eric
Where did you get the 5000 mile change info?
I changed mine around 6k after hearing some HD owners mention it. Also went with mobil 1. Old oil looked weak.
-Eric
http://www.allisontransmission.com/service/autoapp155/
There are links to download the service and maintainence information you're looking for.
The link is for the Allison filter, but I was referring to the rear diff.
BTW the stereo is a year long project (as in I start but never finish - procrastination at its finest).
-Eric
Anyone like to recommend a synthetic for a locking differential?
-David
I used Mobil1 synthetic gear lube (75w-90 btw) and meets GM's API service GL-5 requirement.
And just so you know, there is no need to take the cover off, there is no magnet on the diff cover to clean, so save the grief and aggrevation of scraping off the gasket and getting a new one. Just remove the drain plug, and let it drain that way.
-Eric
BUT, you've got a pretty expensive trans and changing it at 5,000 the 1st time isn't a bad idea! I'm changing mine at 5k. I Think I'll go ahead and use the Mobil 1 synthetic gear lube and do it myself.
Towed TvlTrlr 1500 miles, running WFO into the wind (6.0L) in 3rd gear of 5 quite a bit last coupla weeks.
Rear diff still pretty and black. Worth a few minutes and $1 or so........
At 23k miles. Changed fluid after first tow when truck was new. Wondering when I should change again.
