Tire Rotation on All time 4 Wheel Drive SUV's
Recently I was at a Land Rover dealer and asked what the tire rotation schedule on a Freelander was. I was told there is no nchedule and the manufuctur recommends you do not rotate the tires at all because its an all time 4 wheel drive vechile and the tire wear is the same on all 4 tires at all times.
I then went to a Subaru dealer and asked the same quesition for a Forester. I was told the recommened tire roation schedule is every 7,500. Since both vechiles are 4 wheel drive, which one of these two statements makes the most sense? I'm confused. Can someone please help? thanks
I'd have to believe that both mfr's are telling their respective owners the correct info. I have no reason to believe either comment is incorrect.
-scott
Wondering if I should look at Michelins for my next tires. I was happy with them on another vehicle.
-mike
By 'cupping', I mean when a series of many regular cups or divots (for want of a better word) appears at the edge of the tire tread area. (I'm not sure if that's what others here mean.)
Positive camber is bad.
-mike
"they all get cupped" could also mean the suspension is designed for a lot of bite, and if the tires are aggressive at that point on their tread, then there is indication of some bad choices in design. could also be load dependent... the classic VW bug was rough on tires... the car sat on the outsides of the treads with just a driver, and on the insides of the treads with a load in it. that is also a bad choice in design.
be interesting to see if some subie owners who have put different tires on got rid of the issue, or if it took the miracle of an extremely with-it alignment man to puzzle out the exact issue.
-mike
Like others here, I believe cupping is not the tires' fault; it is caused by the way the alignment angles or the suspension presses the tires to the road surface. It shouldn't happen with a proper stock (non-racing) alignment and suspension set-up.
-mike
Does it currently steer weird or pull left/right at all? When going over a bump, does the backend tend to want to track differently than the front?
FWIW, I'd personally trust the one using Hunter equipment.
-Brian
-mike
-mike
Also have had severe problems with unbalanced Goodyear tires and
windshield wiper fluid that will not spray.
