2500 vs 3500 for towing fifth wheel
What is the difference between these two engine sizes when towing a 32 to 37 foot 5th wheel? Is 2500 adequate or would 3500 be a requirement? Also, would like some input into the pros and cons of whether to buy a 4WD or 2WD.
The point of all this, find out how much the 2500 and 3500 weigh, then subtract that from the GVWR to find out how much weight you can haul, ie.. pin weight. Then find out what the GCWR is, probably 20k. Then find out what the 5th wheel weighs and how much weight is on the pin. If the 5th wheel weight exceeds the load capacity of the 2500, then look to the 3500 SRW, if that is too light, then look to the 3500 DRW.
As far as 2wd vs. 4wd, your needs dictates that decision. I can tell you the extra hardware needed for the 4wd system will decrease your load capacity by a few hundred pounds on any truck you choose.
Joanie, for a 5th that long, you will be much better off with the DRW 3500. The "training wheels" will keep the whole rig a little more stable in windy conditions, and it spreads the pin load over more tire patch to reduce tire wear. The top hauler for the new 2003 Ram 3500 DRW is a regular cab 2wd with the HO Cummins, 6 speed manual, and 4.10 axle. That will give you a GCWR of 23,000 pounds, which should be plenty. Unless you live and/or tow in wintry conditions, you probably can get away with just a limited slip rear axle. The 4WD weighs more, has less payload and towing capacity, and would just put unnecessary wear on front end components (and your wallet, mpg will be less due to the weight and a higher wind profile).
If you REALLY do need more grunt than that, wait til early 2003. Ford will be offering the F450 Crew Cab with a standard DRW pickup bed for the first time, a GVWR of 15K, and a GCWR of 30K with the new 6.0L Powerstroke diesel. If THAT can't do the job, then you need to be shopping at Freightliner dealers
kcram
Smart Shopper and FWI Message Boards
kcram
