You have the B2B warranty, of course, and that might cover the window seal. But read the fine print, B2B does not mean everything between the bumpers (think wear and tear).
-juice
Finally bid good riddance to the anemic factory horn - NAPA had a Fiamm 120db for 15 bucks. Better, louder, but I prefer the airhorns on the work truck!
Cheers!
Paul
-mike
I'd love to install them on the subie but unfortunately, I can't find a good mounting location for then. There just isn't much room in the engine compartment!
Jim
-mike
I'm not sure if it's written anywhere, but dealers will fix or address almost anything, however minor (like squeaks), you mention in the first year or 12K miles. Of course, that excludes any obvious abuse-related problems.
It's best to get little niggles taken care of early on.
Ken
Overall my best repair experiences have not been dealers, but former Subaru Dealership mechanics. Hope you can find a good one. I have found two.
i maybe half into a tank of gas and it'll go on.then i start it up and it's not on for some time. other than that it runs like a champ. i'm about to email New Motors in erie,pa where i got it (2hrs away) but i wondered if anyone else had this problem.
The bracket he made was just metal that he bent into a U shape. That bolted onto the ABS controller, and the horns bolted to the bracket. That thing was LOUD though.
Check the gear oil levels if you've already looked at the heat shields.
-juice
-juice
What was the trick with using the plastic bags? Just place the filter in it, add oil and squeeze it around?? :-)
The WRX has a MAS, correct? Anyone know what the 2.2L on the 97 OBS has? I never had any issues with it and always get the sensors mixed up.
The MAF is the more fragile one, correct?
-Dennis
So right away, I'd say make sure you tighten that gas cap until a clicks, a few times even. Any leak in the system, which needs a vacuum to capture fumes, will turn a light on.
A dealer can scan the codes to find out what was being reported, since they are stored. A single engine misfire could trigger the light, for instance. Say from condenstation in the fuel lines (i.e. water in the gas). Try to keep your fuel tank full, especially when it's really cold. Forget running on empty, it's not a good idea.
Generally, if the car's running well, just have your dealer scan the codes at the next oil change. If it's stumbling or hesitating, take it in. If the light is blinking on and off, park it and call for roadside assistance, as any driving can be harmful at that point.
Though the blinking light is pretty rare.
-juice
Joe
-juice
Yes, that's what I did. Of course, I blotted it with a newspaper once I was done squeezing it and before I reinstalled it in the filter box.
Ed
Your WRX actually has both a Mass Air Flow sensor and a Manifold Absolute Pressure sensor. Your OBS should've had both as well, but the newer naturally aspirated models make due with only a MAP. (They inversely calculate airflow by the MAP instead of directly metering it as a MAF does. This isn't as accurate.)
The WRX's MAF should be pretty reliable. It was only the 1999 Japanese-built engines that have an unreliable MAF sensor; the Forester, Impreza RS and WRX / Impreza turbo. (the latter not being a problem for North Americans, since we didn't get a WRX in 1999.)
About the oiling, after cleaning and drying the filter just put it in a plastic bag and add a tiny amount of oil. Work it carefully into the filter, taking care not to bend the aluminum frame built-in to the filter. Add more in small amounts as needed, but do no overoil.
-Colin
http://www.xpel.com/
check this thread from the i-club
http://forums.i-club.com/forums/showthread.php?s=&threadid=199597&highlight=clear+fog
Oiling the filter in the bag keeps your hands clean and makes it easier to spread the oil around evenly. Also, I like to warm the oil (stick the bottle in some warm water) before using it -- it lowers it's viscosity and makes it easier to apply.
Ken
And Colin, thanks for the MAF / MAP tutorial! :-)
-Dennis
I've seen the Aussie/UK(?) protectors and I'm definitely getting some.
Patti, please pass on suggestions to expand the U.S. option choices. Looks like I'll be ordering light protectors and a rear cupholder from the UK.
-Dennis
service included: brake, coolant, AT fluid, and differental flush and fill. New plugs. Oil, fuel and air filters and tire rotation. plus some inspections...
--jay
Joe
$550 does seem high for what's needed. Ask the service manager if they can give you a complete "menu" of service items they include in the 30K. Reference that against what's in your maintenance booklet and decide what's necessary. Many times, dealers will put in additional service items that are discretionary. You should be able to reduce the price by removing some of those items.
Ken
jay_24: i agree with kens recommendation on dealer service. see what you're paying for which part of the service, whether it can be done cheaper elsewhere, and if they're doing more than what subaru recommends. to justify the service, shops often (rightfully so) point out that most vehicles are in fact driven under the conditions that the manufacturer considers "severe", e.g. lots of short trips, temperature extremes, etc. fwiw, i paid about that much for 60K service, since that time my opinion of this dealer and their service has eroded so i will be going elsewhere for the 90K.
I'm sure Colin can tell you why the one engine needs it and the other doesn't; I couldn't engineer my way out of a paper bag.
-juice
Jim: yes, I've felt it myself and heard at least one other person complain. Ice and slush got inside my steel wheels and threw the wheels off balance.
Short term, you can just use your fingers to remove the slush.
Long term, wax your wheels. I'm serious. That makes the surface more slippery, so ice can't "stick". At least keep the inside of the wheels clean (easiest when you rotate the tires, every 7.5k miles).
Note that this is universal, not just on Subies. You can wax alloys, too, if they're painted, as most are.
-juice
Last month I had the 30K service done. The dealer quoted me $400, but after a AAA discount(which they have now discontinued for some reason), and using my own synthetic fluids, it wound up costing ~$325.
Mark
Here is the Subaru 30,000 mile service from the my.subaru page. There is a lot of 'inspect' where the dealer I'm going to is doing a flush and replace...
Inspect Steering and suspension
Inspect Clutch operation
Perform Inspect brake lines and check op...
Inspect Brake linings and drums
Inspect Disc brake pads and discs.....
Replace Brake fluid
Inspect Automatic transmission fluid
Inspect Transmission/Differential....
Replace Spark plugs
Replace Air cleaner element
Recommended Performance Replace fuel filter
Perform Replace engine coolant
Replace Engine oil filter
Replace Engine oil
Inspect Camshaft drive belt
Inspect Drive belt(s) [Except camshaft]
It's actually a good idea to have your AT fluid drained and replaced on a regular basis.
The only item on the list you posted that requires some mechanical experience is replacing the spark plugs. Everything else is fairly straightforward.
Ken
We have the gauge pack (calibrated in Celsius), and see temperatures in the oil pan (sensor replaces the drain plug) between ~72 and ~95, with a peak under heavy load of ~110. Those translate to ~162 to ~203 with a peak of 230 degrees Fahrenheit.
Running Pennzoil 10w-30 in the summer, 5w-30 in the winter. It's the summer grade I'm wondering about.
FWIW, the engine temp gauge has never budged off of dead center, and I watch it (them actually) like a hawk, especially when I'm towing. It's interesting to see that the engine temp gauge shows "warmed up" well before the oil pan comes off of the cold peg in the winter.
I agree with nearly everything on the list. Isn't draining much cheaper than a flush?
Also how about brake fluid change. I hear many of you talking about that, but I've never done it with my other cars... Obviously brakes are important to keep working in good order. Others I work with also questioned it.
--jay
Are you sure they discontinued the discount? Last time I was there they had a new computer that didn't retain the AAA info, and you have to show it at each service.
I'll find out for sure this weekend when I pick up my plates.
Jay - Those items are for "normal" service and not "severe" correct?
My current dealer is about $100 cheaper than my previous dealer on the big (30k, 60k) services. Plus, they give you a loaner regardless of where you bought the car. It pays to shop around
-Dennis
I believe the items I listed are for normal driving. The my.subaru page didn't seem to specify... I should go out and read my manual :0
I too get a "free" loaner. Usually an acura integra.
--jay
One thing to keep in mind is that the my.subaru service items are directly out of your owner's manual. The list reflects a minimum set of service items under normal driving conditions. It's better to err on the safe side for certain items like AT fluid and engine oil.
Ken
Check/add PS fluid level, grease sways with lithium, hose out spring bases
Grease pedal, check gear oil level
This is really *after* bleeding as per below
Look at rotors and drums for scrapes, warping
Measure pad thickness, if worn replace
Replace Brake fluid
Bleed 'em, you need a 2nd person to help with that
Check ATF level, add, gear oil if MT
Check gear oil level in both places, add 75w90 if needed
Replace Spark plugs
self-explanatory
air filter
fuel filter
flush/fill
check to make sure the rubber gasket from the old filter was removed
Replace Engine oil
don't forget the 17mm crush washer
look for hairline cracks, fraying
same for all belts
None of this is hard, in fact it's a good check list. I'd rotate the tires and change the wiper blades, too.
The one thing that might be tough it inspecting the rear diffy oil level, since that 1/2" drive bolt is a bear to remove.
-juice
Thanks. I'll let my sister know about your tip for her PT Cruiser and try it myself.
They gave me a 02 legacy GT for a loaner! It seems more responsive than my 01 OB. The engine seems louder both in the car and out. It also has a tad more road noise and a bit less head room due to the moon roof(s). We will be taking the long way back to the dealer this afternoon
--jay
Those same tires also have smaller diameter, making gearing effectively shorter than your OB. It'll be quicker off the line, but revs will be a bit higher on the highway.
-juice
--jay
Contrast the design of Fumoto, whose valve actuates with a lever but has an optional nipple to attach a drain hose. A small quantity (10-15cc) of dirty oil pools in a recessed portion of the plug. See photos and notch mod at ScoobyMods, currently down.
FYI, per a Fram email, a Subaru engine oil pan's drain plug has a 20mm x 1.5mm thread size: So currently, Fram SureDrain isn't an option for Subarus.
Per Fumoto: For those with a Fumoto, did you buy a F105 or F105 N (with nipple to attach a drain hose)? Does the F105 dribble oil on the plastic cowling? Any clearance issues?
Cheers,
..Mike
..Mike
