the same engine in a Euro market car will have a factory recommended change interval twice that of the US. go figure. the 3K interval can't have anything to do with what is really technically needed!
the only reason I see to ever change at 3K is if you get someone to look under the car to check for other things going wrong you may not have the inclination to do yourself. I can certainly vouch that several cars I have had may well not have lasted as long as they did as I would have missed torn CV joints and minor oil leaks, leaking water pumps etc etc till it was too late but because I had taken them in for an oil change they were noticed early. the actual change of the oil at 3-4K had nothing to do with it though!
you should change at least every 6 months though (even the manufacturers who say go by the change interval indicator say never less than annually) as the various additives to the oil degrade with time.
On my Subes and my wifes Chevy I usually change about 5K or whenever the change oil light comes on, which has never been less than 6K in her Ventureand once was still not lighting by 9K but 6 months were up so it got changed. I know lots of people with early/mid 90s BMWs and Mercs who change 7-10K and have no problems and it isn't just because they may be "better engineered", its because 3K is nothing more than propaganda by oil companies and oil change places!
yes it may only be only 20 bucks for piece of mind but its a heck of a lot of oil used in total by the driving public and quite honestly my 4 months in the Gulf 10 years ago wasn't exactly something I would like to see others have to go through. though it seems history will shortly repeat itself! some things are worth fighting for but BP Amoco and Jiffy Lube isn't it!
1. it doesn't have a "normal" oil capacity. my 3.0L inline six uses 7 quarts of oil.
2. those long drains are ONLY possible with full synthetics. the lights will tag through quickly with mineral oil.
3. oil temp is critical for oil quality. lots of very short trips contaminate the oil because it never reaches a self-cleaning temperature. a rule of thumb for this is 5 minutes after the water temperature gauge reaches normal temp, since few cars have an oil temp gauge.
btw it's $53 to change my oil at the dealer, but only they (or someone else with a $1500 scantool) can reset the lights. considering that's with a new filter and 7 quarts of bmw's special formula Mobil1, it's not a bad deal. I always have changed my own before now...
-Colin
I think 5K is a good compromise between what the oil companies say and what the manufacturer says (7.5K in my case).
The other advantage to a 5K interval is that it's easy to remember. When the odometer rolls around to a 5K multiple I change the oil. I don't need a little sticker on my windshield to remind me when the next change is due.
I really hate those oil company commercials where they imply that you are taking big risks going beyond 3K. Independant studies seem to show otherwise...
Colin
I had a 84 UK spec 318 when I was in Europe. Changed oil 5K religiously and put on over 80K (miles not km) in 2 1/2 years. I know its still running. Its passed through several people at the place I worked at since I left.
This is the only car I have ever done my own oil on. This after I took it to the main West London dealer who didn't tighten the drain plug! Good thing someone who noticed my trail of oil honked me when I was only a few streets away! They were charging close to UKL60 then and I was only a "poor civil servant". If your BMW dealer is only charging $53 for 7 qts synthetic , you are getting a bargain! My local Jiffy Lube charges $48 for 5 quart synthetic changes!
OT question, but do you wait to change oil until the indicator comes on, and do you need a scantool to reset it every time?
Ken
We've got a '96 Impreza Outback with over 80K on it, and a '01 Forester with over 30K on it, and have had no problems with either vehicle.
Bob
So now I'm changing every 3k, still using dino oil. No big deal - I enjoy doing it, it keeps me in touch with my cars.
Hmm, 7 quarts at $3.50 per quart is...luxury car, luxury budget! ;-)
Edit: Loosh figured out his problem. The leads were dirty on the battery, and cleaning them fixed it.
-juice
-mike
Yes, there are Subaru owners who have had problems. No vehicle can be expected to be 100% problem-free, so some problems are to be expected. Your situation, however, seems unique, and very much out of the norm.
1998 was the first year for the Forester, so that may account some, if not all of your problems. Although, another "Crew Leader" here (Juice) has a '98 Forester, which he loves. So, who knows...
Did you buy your Subaru new? I'm assuming you had it serviced as per the normal recommended maintenance schedule, at a Subaru dealer?
Bob
There are series of lights, if I remember correctly 5 green, 2 yellow and one red. You're supposed to change the oil by the last green, yellow means "cmon now" and red is past due service.
And yes, a scantool is the only way to reset it.
-Colin
FWIW I drive my cars hard...I don't trash them, but I drive them (occasional redlines, etc.).
So, bottom line is: Most important part about oil changes is that they are done regularly along with a new filter and some good quality oil. I only used Castrol GTX on my honda but plan now to only use Mobil 1 in the future on my '01 Bean and '99 Ody.
-r
Joe: grab Consumer Reports' annual auto issue, and the Forester is at the top in their reliability rankings. It's virtually tied at the top for the best overall rating, too.
Noone's perfect, but that's close.
kaysey: you're compaing FWD to AWD, it's like apples to oranges. Volvo's XC gets 17/24 mpg with AWD, so you'd be lucky to match your average with strictly highway driving on the Volvo, and that's premium fuel, by the way.
gobagoo: you're half right. It's not that we're lucky, it's that you are unlucky. You got the bad apple in the batch. The CV joint problem is rare, in fact I'd never heard of one until now.
The seal leak is not unheard of, but still not common.
I have my original brake pads, even, with 47k hard miles, including towing and off roading.
Venting makes you feel better, so be my guest, just don't assume all Subies are like that. Mine certainly isn't, and that's why we became a repeat customer, the 5th Subie in our family.
-juice
-juice
-Colin
I'm glad My.Subaru.Com came along, because it allows me to document changes I did myself in an orderly fashion, and print them on something official looking.
-juice
All the customer service people did was refer us back to the dips**t dealer. Newsflash, Billy, if the dealer was going to help us, we wouldn't be calling the customer service in the first place!
If the Forrester is so sterling(our neighbors finally got rid of theirs a couple of years ago because of mx problems and dealer intransigence) why did the Subie reps tell gobagoo to pound sand?
I'm getting a WRX next time, but only because they are built in Japan. Anything built in Lafayette is a domestic automobile.TC
Having said this, I have a few highly technical buddies in my LandCruiser group who've sent their oil in for analysis to see what kind of interval they can get away with. Several were getting normal ranges in their samples. My advice if you want max use from the oil while maintaining proper protection? Send in your oil samples to a testing company for an entire change cycle. You may find that you can run more miles. Using synthetic also eliminates the sludging problem in all cars.
IdahoDoug
The CSRs may not have known that you'd already been at the dealer, since people might just call them first. It's easier to pick up the phone than to pay a visit to the dealer.
I used to work at a Help Desk, and it's the toughest job in the world. Strangers call you to yell at you in anger over something that wasn't your fault, and you have to be polite.
My wife's 2002 Legacy is solid and has better NVH control than my 1998 Forester did when new.
-juice
<< I'm getting a WRX next time, but only because they are built in Japan. Anything built in Lafayette is a domestic automobile. >>
Bob
>__< ...
But yeah, if you suspect your dealer and have other local options, I would use them. In fact, call 800-SUBARU3 and ask if there is a regional rep near by that can supervise the fix.
-juice
-Flummoxed in Florida-
In another topic, Steve mentioned the coolant may have air pockets. In that case, try "burping" the system, I know there is a valve to let air out, though I've never done it myself.
-juice
Since you are a team leader for this forum and seem to be the one responding to my notes, I will address this to you.
Local dealer took the transmission off today to discover that not only has the rear oil seal failed, but also the pin seal. Please note that this car has a perfect maintenance record and is only used for street or highway driving.
Have been spending way too much time lately speaking with people who have had experience with Subarus. Most interesting was a mechanic who uses these engines in "sand rails". He was very familiar with the oil seal issue. His opinion was that the relief valve (please forgive any wrong technical terms)on this engine is undersized. This, in turn, causes pressure build-up and blows the seals. He claims that someone sells aftermarket kits to rectify this problem and they install them on all the sand rail engines. Has anyone else heard about this?
I have noticed quite a few complaints about oil leaks, seal failures, etc. in this forum so in this issue we are not too rare. Any help would be appreciated. MAP
I traded in the 1996 and bought a 2000 subaru Outback. I baby the car. No hard driving. Now it has 36,600 miles. It has never idled smooth. It had a recall for a sensor. Which did not seem to smooth out the idle. The fan makes an irritating whine sound. The AC is not generating as cold air as it used to. At 30,000 miles, the idle arm had to be adjusted. I don't know if this is on all cars, but the fan coming in from the outside blows across the engine and the air is very hot and does not work for an alternative to AC.
Yesterday the Check engine light came on. It seems to me that this is a poor record.
Am I too picky?
Her email is: PMickel@subaru.com.
As to your oil leaks, I'm afraid I don't have any answers, as I'm not a mechanic.
Bob
Any help will be appreciated
ray
It might be a good idea to replace the seals if you're doing the timing belt (at 60 or 90k miles), since the labor is paid for and it'll cost you next to nothing.
dmtracy: the '96 was a 2.2l but had the same block, so you had thicker cylinder walls. Any time you have a large displacement 4 cylinder (like the 2.5l), it'll carry inherent disadvantages compared to a smaller displacement engine, especially with the same block.
The trade off is more power and torque, of course.
But it should still be fairly smooth. A couple of things to consider that are cheap fixes:
#1: get a new battery. The OE batteries have very low CCA ratings, and my replacement battery (with double the CCAs) resulted in smoother starting and running.
#2: look into the SPG mod on i-club.com. SPG for single-point ground. It doesn't help everyone, but it does help people with the symptoms you describe. You have nothing to lose.
For a DIYer that enjoys projects, you could spend a couple of hours and knock both those out.
Next...A/C. Hmm. Check the belt tension, make sure it's not slipping. Inspec the belt itself. I've heard of people insulating the A/C lines, too, which run on the driver's side of the engine, right next to the red-hot exhaust manifold, which might make the A/C loose some effectiveness.
You can thank the feds for the check engine light, it could be something as silly as a loose gas cap. The dealer can reset it. NAPA stores will read the codes for free, I've heard.
Hang in there, it sounds like every problem you have can be addressed.
Ray: try any local auto parts stores, but measure the current size first.
-juice
It would have to be up near the top of the radiator, where the air pockets would go. Check the highest hose that leaves the radiator first.
-juice
Maybe when I get home. I'll be changing the coolant soon, so this would be good preparation.
Jim
Bob
IdahoDoug
Are there any other Outback automatic owner have the same problem with brake and gas pedal placement as I am having? I found the brake pedal is too close to the gas pedal in auto gearbox Outbacks. This could be a defect and subaru has to take care of.
I need to check out the manual tranny outback to see if the distance between brake and gas pedals are the same as that in auto tranny outbacks.
ray
ray: we have a manual Legacy with pedals like the Outback. Ours has good spacing, but it does take a while to get used to the hinged gas pedal (the top portion moves back an inch or two without increasing the throttle).
-juice
-juice
IdahoDoug
Last time I just checked and topped it off for the next 2-3 days. By the 3rd day it stayed full.
-juice
IdahoDoug
That's why I love these forums, I've learned to look for that valve next time.
-juice
IdahoDoug
Make sure to clean up any spills and recycle the stuff.
-juice
Otherwise, I think I'm just carrying an extra pint around in the event of an overheat/boilover.
IdahoDoug
Per Idahodoug in post #5671:
"The reason it's funny is that yesterday I bought a couple more factory oil filters and I intentionally did not ask for the little seal crush washers they'd give me the first time. Sure enough the parts guy was careful to put one in with the filter and I asked him to again show me where it goes. It's a normal crush washer, and on the factory oil filter there's a circular depression it fits into around the threaded center hole. The bulge goes against the block as would be standard crush washer practice on a drain plug or other. So, seemed like unprompted reinforcement of this feature. I asked him why a Fram or other aftermarket filter for my car did not have this feature and he didn't know."
I searched everywhere for this info. Even on i-club. I found no reference to an oil filter crush washer other than 1 post asking if the washer was for the filter or not. All responses were that it was for the drain plug and NOT the filter. Seeing how Doug got it from the parts dept. person it seems as though it must be correct. Anyone esle ever install a crush washer on their OEM filter?
bit
