-Brian
-mike
Gotcha.
(I'm one to talk!)
Jim
What can be the problem.
Please help.
THanks
Bertus
Another possibility is a bad ground wire as well. Check the connections on the battery.
-mike
Rondo320
Also, could be the key switch.
cusafr
Thanks guys, much appreciated.
cusafr
You wouldn't want to leave your igintion key in the car, locked or unlocked, would you?
-Dave
Had it towed to the shop but I didn't want to spend a whole lot of money on the car. He did some analysis but wasn't much help so I brought it home and have been working on it since then. I have learned a lot that might help you if this happens to you.
I replaced the burned out 45 amp fusible link and 8 fuses and the wiper motor. I replaced the alternator and checked the battery but the car was still running on only two cylinders. The front two were dead. Thought it was the ignition coil but a new one didn't help. Bought a computer at the junk yard but that didn't help. Got some advice about the ignitor which is a small 2x2 inch box on the firewall. Despite being told that they never go bad that was it and I was running on all 4 cylinders. But before I could celebrate I found that the alternator was not charging the battery. We took the new alternator off and had it tested. It was good. Checked the battery. No problem.
My original repair person had told me that if the bulb on the instrument panel was burned out that the control circuit would not allow the alternator to charge. I didn't think much of that theory but through the help of a more talented friend than me, we bypassed the circuit with a functioning bulb in the line (don't just use a wire or you can cause more damage) and it started charging.
After taking the instrument panel apart I searched for replacement bulbs. I went to two auto stores and got #74 bulbs but both were different and both would not fit. I checked the dealer who wanted $10 a piece because they are sold with the base. I checked a local bulb distributor who had them at $.96 a piece. The right size is 74 N probably for NARROW because that is the difference from the regular 74. Now the alternator is charging.
I have two problems left that I know of. The engine fan runs continually. After replacing the fuse for the fan, we started pulling relays and found the one that controls it to be above the fuse box that's below the instrument panel.
The other problem is that the cassette mechanism on the radio runs all the time without a tape inserted so I had to disconnect the radio to stop it. I think that is what is blocking out the radio and CD from functioning. This is a minor issue now that the car is running.
All I got to say is thank God for junk yards because Subaru dealers and parts departments are grotesquely expensive and when you have an unusual problem it's tough not to start throwing parts at the problem. All in all I spent $170 on parts I didn't need but that would have been a drop in the bucket had I had the dealer fix this problem.
The biggest issue is what caused this problem in the first place. In trouble shooting I discovered a faulty ground. This was where the black wire from the battery connects to the body. That may have been it. I don't know. Or the alternator may have given out since the car has 130,000 miles.
Thanks to all of you who had suggestions for me. And I hope some of this info might help in the future.
Rondo320
Craig
-mike
No, but I often want to leave the key in the ignition while the driver's door is open, as when working on the car or waiting in the car.
It just happened all of the sudden. I was idling & opened both the driver's & front passenger's doors. I closed the doors & then I couldn't open the driver's door again from the inside. All other doors work fine. In my troubleshooting, I once closed the dr door, but not fully. Even then, I couldn't open it back up from the inside. Are there child locks on the driver's door?
Search Scooby Mods on how to remove the door panel. I bet a cable broke loose or something.
Well, you announced my first suggestion: take it in, and explain to the mech what you hear. If you can make it happen on a test drive, so much the better. (Personally, I have lousy luck with that one!)
It could be anything from a loose exhaust pipe hanger to misplaced insulation around your catalytic converter. Have you ever had any catalytic converter problems? The insulation is a bear to replace properly. :mad:
Best of luck with it!
Gaucho
Any suggestions?
Though my '98 cooled plenty well.
I'm a friend of user "fyredan" who you helped with a 93 Legacy Wagon and his overheating trouble. The wagon finally gave up the ghost and blew the head gasket. 3 days ago we bought another 93 Legacy sedan with the same EJ22 (2.2 liter) non-turbo engine. This car will start but idles rough and will not rev up unless you butterfly the gas pedal and then it will only go up to around 5k rpm. If you put it in gear, it wants to die and will not rev up at all. We've replaced the TPS, IAC, MAF, ECM, pcv valve, knock sensor, fuel pump, coil, plugs, and plug wires. We popped a couple of holes in the front catalytic convertor thinking it might be clogged. After replacing all the components it idles smoother but still will not rev up. The components came off the wagon and we weren't getting any codes before swapping them. Now we're getting codes for the TPS, IAC, MAF, and knock sensor. I'm thinking that this is electrical with either a possible loose connection or bad ground. Any help or ideas would be of great help at this point. Is there a common connection for all of these components or something that we might be overlooking? Thanks,
Dean
P.S. The ingnition switch is acting up too. There's an electrical solenoid on the switch that isn't releasing the tumbler so you can roll the switch back to the locked position and remove the key. I can unplug the solenoid and lock the switch and remove the key with no problem. Could this be related to the electrical trouble we're having with the engine or something else entirely?
Can I just use the foam insulation tubes available at Home Depot for this?
Thanks again,
Dean
I thought I would get feedback here before I sucked it up and took the car to the dealership :-) I have a 1999 Subaru Forester that has around 150K miles on it. It has the remote door locking feature but this past fall the battery wore out and I just never got around to replacing it so I just used the key to enter the car.
A few months ago I noticed that when I tried to use the key to enter the passenger door or the hatch, the key would go into the lock but I could not turn it. In true
cheapcost saving fashion, I ignored it and just used the driver's door to get in. Well today the driver's door went kaput as well. I jimmy'd the key a little and now the key will turn in the lock but the door won't unlock. I have my roadside assitance coming to unlock the door for me as I type.Any ideas on what this could be? I am hoping that this is not a "replace all the locks" issue ;-) Thanks for any and all insight!
Dean
Maybe someone else w/more technical knowledge (Paisan? or?) can pipe in on possible causes. Faulty sensor?
I would more think it's a problem with the cat being clogged up due to non-use.
Definitely would get a 2nd opinion on it though and without seeing the problem live, it's hard to diagnose.
-mike
