Craig
Cheers Pat.
The dealer still wants to do 500 mile oil checks for the next 2000-3000 miles just to make sure I am not losing oil.
ANd about the "normal" oil usage, I think that is a cop out as well, but Subaru won't authorize any warranty work if it is using any less than the 1 quart per 1,000 miles.
Kim
Eric
They basically told me to keep an eye on it until my oil change at 3750 miles. Also if any oil needs to be added they told me to take it to them.
I checked it after about 80 miles of driving today after the dealer visit and it is reading perfect now.
Thanks for the information you guys and gals provided and I will keep y'all posted.
Kim, hopefully that's all it was for your vehicle. Keep us up to date and let us know if anything happens.
After driving for over an hour and then making slow tight turns I had no grinding noise. Yahoo!
Thanks for everyone's feedback here!
mix 50/50 with distilled water and add.
-Colin
When they drove my car up to me, it even sounded differently. The engine has a higher pitch to it. The hesitation is completely gone. I stepped on the gas, expecting it to hesitate and it took off like never before.
The rocking/rough idle is gone now too. All I feel is the vibration of the boxer engine.
The dealer did ask me to keep an eye on the oil and possibly come back every 500 miles for the next 2000-3000 if I notice any decrease.
So bottom line...I liked the car when I bought it but I love, love love it now!
Kim
FWIW, we once asked Darlene to look into what motor oil came from the factory, and she said they used Havoline. Perhaps they use Havoline coolant also?
-juice
Great Kim, good to hear that.
-juice
Joe: A rusted slider or piston that doesn't properly retract will play havoc with brake pad wear. Eventually, when the friction material is worn away, the steel backing pad will act like a lathe on the iron rotor, reducing it to metal shavings! Ask me how I know.....
Kim: That much oil mist being injested into the intake tract (thru the PCV) will eventually foul the plugs. The unburnt hydrocarbons level rises in the catalytic converter, and the oxygen sensors start playing with engine parameters in a vain attempt to compensate. Bottom line is very poor driveability.
Steve
I just got my OB H6-3.0 wagon last weekend. I just found out that there're a few paint spots that doesn't matched the rest of the car color(Silver Stone). These spots are in the 1/4" diameter and its appearance is darker and lack the metallic look.
As a first time OB owner, please give me some advice and recommendations on how to address this problem.
This's definitely a defects in material/workmanship.
Tom P.
There must be a short somewhere. It could even be related to the ignition.
Tom: my guess is that's acid rain damage, or from sap, maybe even hail that was repaired. Talk to your dealer, they may be able to wet sand it, if not they can repaint, at least the clear coat.
-juice
HTH, Owen
Do you guys know of any place that I might find the schematic or wiring diagram online?
DaveM
Jon
idiot?... nah. Unsuspecting?... yah
Does the '92 Loyale come with remote keyless?
-Dave
-Bob
I've had the same thing happen to me on my old '00 Outback. It took me a day or so to figure out the problem. I was taking out the fuse so that the lights wouldn't drain the battery!
Regards, Owen
I bought the car in March 2002, was working at home and not driving every day, and experienced dead battery problems from June 2002 - March of 2003. I finally THOUGHT the problem was resolved. Not by the dealer but by my getting a new job contract where I put 20 miles a day on the car.
Now I'm driving 6 miles a day round trip and the dead battery problem is back. This time after only two days sitting in the garage. Strangely enough, the dead battery often coincides with a nearly empty gas tank (wierd, huh?).
There is a new service manager at the Subaru dealer, but no new solution. In the 9 months since I last posted, has anyone heard of anyone else having this problem? The dealer swears they have tested everything they could that is related to the electrical system and there is no problem with the car. They want to put a trickle charger on my car. I don't want to have to plug my car in.
My husband's Jeep, with all of the same electrical toys, can sit at the airport for a week at a time and still start right up. My old car, with fewer electrical accessories, sat up to a month at a time and still started up. This is NOT normal operation for a car.
Cheryl
Doing it right is going to require a little inventiveness. An ammeter needs to be in series with the battery terminal. But what I don't want you to do is disconnect the circuit and reconnect, as this may change the results of the test. We need to catch everything in the 'natural' state, exactly as it is done when you turn off the ignition and then leave the car untouched.
The ammeter needs to be connected first, then the battery terminal disconnected, so that the flow goes thru the ammeter uninterrupted. Some autoparts stores stock a 'quick disconnect' battery terminal adaptor with a green knob that easily isolates the battery. Prewire the ammeter to each side, then when you turn the knob, the flow is seemlessly shunted thru the meter. In an ideal world, you would borrow a meter that could be connected to a recording device (PC or chart recorder) to catch anything really unusual.
Steve
But...I suspect it's a leak in the electrical system. Ask the dealer to keep it overnight to try to reproduce the problem.
I had an old Datsun, and had the same problem. It was a loose brake pedal, it would travel down to a point where the brake light would turn on at times, draining the battery. I woke up to a dead battery for a few days before figuring out why.
-juice
Meanwhile, I found what appears to be a pretty good battery site (http://www.batteryfaq.org) that backs up my belief that even with all the new electrical gear on most cars, a car should be able to sit for 2 weeks and still be able to start.
I know this is a wierd coincidence, but is it possible it's my low gas light that's acting as an electrical parasite? As I drove my car out of the dealership last night, the gas light was on, and this is about the 4th time I remember driving directly from the dealership to a gas station a block away. It's probably just a coincidence, but if I were debugging computer code and saw a linkage like this, I'd suspect a relationship.
I'm going to start by-passing the dealership, both by filing this issue with SOA (I initially thought the dealer would do that), and getting my favorite local mechanic involved.
Thanks again,
Cheryl
P.S. One other thought. I assume that the headlights on the 2002 Forester are auto-off with the ignition switch, just like the 2003. Is that true? I try to always turn the lights off, but with the daylight running lights it's easy to forget.
Make sure you haven't left on the running lights, the switch is on top of the steering column. That could slowly drain the battery. I'd check that first.
I don't think a low fuel light would stay on when you remove the key.
-juice
If you really think your on to something with the low fuel situation, it might be worth looking at the fuse(s) that go to the electrical sender unit for the gas tank, the fuel pump, and the idiot light and maybe pulling it(them) when you leave the car for a couple days. Pick up a handful of assorted fuses so if you lose one you won't be out of luck.
What you've got is one really unusual problem and any help you can give the dealer will be to your benefit (and piece of mind).
Larry
Patti
Steve
1) Bad battery - internal leakage between plates can drop the voltage when they sit idle.
2) Poor alternator output - bad windings, bad voltage regulator, slipping belt - all can result in insufficient charge being put back in when you drive. Battery voltage is around 12.6v or so. Alternator output to charge a battery should be 14.5v or so, plus there must be sufficient current. As your situation is elusive, the testing needs to be dynamic - ie when the car is driven, and not just when sitting in the shop tied to the diagnostic equipment.
Steve
You can also pull your battery yourself and many auto parts stores will check them for free (I know AutoZone in my area does this).
Good luck in finding the problem, it's has to be a pain for your.
Paul
What electrical and/or Electronic, OEM and aftermarket, goodies do you have in the car?
-Dave
I've been moving so my computer has been in a box.
Last month at less than 32K miles, my 2000 Impreza 2.5 RS had developed a major leak in the gas /fuel line.
I went to a deal in Upstate NY where I live now and they asked me if anyone had worked on the fuel tank because it looked like someone had damaged the fuel line and o rings went working on the fuel tank. At first I said no because I was thinking of something recent. Later I remembered that my original deal in Rockville had done several warranty repairs that dealt with the fuel tank. My original dealer had confirmed that they had ordered a fuel level indicator/fuel pump assembly/fuel tank sending unit in APril 2002 and installed it in May 2002.
Per Patti's advice I talked to the 800 Suburu3 people. THe customer service rep unfortunately was not very helpful in my opinion. More on that later.
I explained then to to the dealer in Upste NY that my original dealer had done a few things to the fuel system including replacing the fuel assembly etc. and they said that made sense and that it was obvious to them that something done during the installation of the unit had caused damage to the o rings and this damage or improper installation had led to the current leak, which was a serious leak.
Getting back to the customer service rep, I feel that she was not helpful and feel she was trying to shift the blame on to anyone but the suburu mechanics. I don't know if the customer service reps are mechanics but she seemed to me to imply
that if the dealer had damaged something upon installing a part that it would have leaked right away. She claimed that she would talk to the suburu place in NY state and in ROckville to get to the bottom of it and work something out.
However, I'm not sure if she ever did as she never got back to me and the NY dealer never mentioned getting a call from her (I forgot to ask when I picked it up)
However, the dealer in NYstate found that it was obvious to them that the problem was not a manufacture defect but a workmanship issue and that something done on installation of the unit had led to the problem. THey told me that since it was workmanship issue not warranty issue that they would have to charge me but that I should try to get reimbursed by my original dealer that had done the installation.
I decided to do this in person when I was back in Rockville area (which is now) as I was needing to go back to MD anyway sometime so that gave me a good reason. I thought it might be helpful to the installers to see the part so I had it kept for me so they could see for themselves what went wrong and hopefully to avoid something like that in the future since I was told this kind of leak could be dangerous.
I'm going in person to the dealer in ROckville today (wish me luck) as I think that's the best way to deal with it. THe repair cost nearly $400 and I spent around a week without my car.
THe dealer in rockville has always been accomodating and fair thus far, especially since my car had several warranty repairs needed (I was in to the dealer so many times I lost track of how many) with this or that going wrong. I was surprised that this car had so many problems because everyone else seems not to have these problems with Suburus.
I'm not sure what to expect. I am only in town for the day but coming back again next week. I hope to get it resolved and will let you all know how it turns out.
Has anyone else had problems like this? Was the attitude I received from the customer service rep typical or atypical?
I like my car's driving and handling but I will admit that its been a real pain all the times I've had to bring it in the shop btwn 15k miles and now. I'm glad that so far everything is always resolved and hoping this problem will be too.
Thanks for listening.
One thing I asked the dealer to check was clutch chatter. I had it changed back in late 2001 which pre-dates the latest clutch material (mentioned in the TSB). The dealer did tell me I'm over a year out so I might be out of luck, but I thought I'd try anyway.
I'm driving a rental OB right now (AT) and I'm seriously missing my Forester! I was supposed to get a WRX sedan but the rental did not make it back in time. :-(
Ken
Good to hear from you. I hope you're doing well!
Ken
-mike
Patti
Steve
I just had my WRX oil change done at a dealer (I got 2 years free service when I got the car), I brought them an unopened 6 quart box of Mobil 1. They returned one bottle and about 200ml is missing from that one. I looked at the invoice today, they said they filled 5 1/2 quarts. The dipstick is reading to just where the twist starts. I figure they must have put in at least 5.2 liters instead of the 4.8 necessary. Is that a big enough deal to cause trouble and go back to get fixed. This dealer is miles away (those who read my a/c woes on my Legacy know the story on that one!)
Craig
Good luck!
Jon
I'm using Motul Gear 300 in the Rex, and I used Amsoil in the OBS for 3 years. I was happier with the Amsoil (the regular synthetic Gear Lube, not Series 2000).
YMMV.
-Dennis
