Subaru Crew Problems & Solutions
1363364366368369385
    fibber2fibber2 Member Posts: 3,786
    Hey Wes!
    I picked up a foot or so of soft plastic tubing at the hardware store to lengthen the snout on the fluid bottle the last time I changed mine. You can then hold the bottle up above the diff and give a good squeeze. Took a few minutes to empty it, but saved the cost of a pump.
    Oh, and warm that lube up well if you are doing this job outside in the winter! It flows like... well, not at all... when very cold. And it stinks, so wear plastic gloves.
    Anybody else have their retractable cargo cover break? Mine did last month on a icy cold day. While extending it, it suddenly went 'snap', I heard the barrel spin, and it went limp. It would no longer retract.
    I took it apart (three little sheet metal screws hold each plastic ends in place), and pulled out the inner assembly. Basically, this is very similar to a rollup window shade, and at first I was tempted to just 're-engineer' a scrap window shade that I had in the cellar to replace the core. But being curious, I tore it down. It has a wound spring that attaches to a central steel rod, and hooks to the outer barrel with a plastic insert that serves as an anchor and a bearing/spacer. The plastic sheared into two. Fortunately, both ends use the same part, and with some effort (they crimp the rod flat at the ends to keep it from rotating) I swapped them. A few twists to re-tension it before capping the ends, and it is basically as good as new.
    Note: I didn't tension it quite as stiff as it was, as I expect that the aging plastic replacement end is likely to fail early if I did.
    phil2000phil2000 Member Posts: 195
    Steve, thanks for the information. I can get a hold of some tubing and I will sit the lube on a heat register in my house before I dispense it.
    xwesxxwesx Member Posts: 16,796
    Good call, Steve! I use gallon jugs of gear oil (which don't have nozzles), so I did not consider that as an option, but it makes great sense - especially if you are not going to use the pump on a semi-regular basis. I think I paid about $8 for mine, and have used it a dozen times, so it was a good buy. :D
    Impressive! I never had a problem with the one on my '96 Outback - even winter after frigid winter. Since then, the cargo cover has been an "optional accessory," one which I have not opted to buy.
    It varies by model. Remember it's not just the type of lighting (halogen, HID) but also the optics and the type (reflector, projector).
    My 98 Forester was excellent.
    Our 02 Legacy L was terrible. Outbacks of similar age were better (dad has one).
    Our 09 Forester is very good.
    I keep a Dahon folding bike in my wagon (use it almost daily from March-Dec) for a lunchtime outing, so keeping it out of sight is an issue. I really need to get a dark tint applied.
    The bike has helped me keep my sanity, and I miss getting away for that half hour in the winter.
    Yeah, I bet! You do keep yourself plenty busy. ;)
    My '10 Forester is the first of my Subaru vehicles with "privacy glass" and it works very well. Unless someone makes an effort, it is difficult to see into the rear portion of the vehicle. Since I usually don't carry much in the back other than an emergency tote (with some auto fluids, tow strap, tie downs, tool kit, etc), which looks old and ratty, I didn't feel the >$100 price tag for the cover was worth it. Any time I carry something else, it ends up being large enough that the cover would just have to be stowed anyway.
    I like the tint as well. I had aftermarket tint installed on my '98.
    It was good advise to take the fill plug off first. Because no matter how hard I tried, I could not get it off. I even tried putting a pipe on my breaker bar. If I had a lift, then I could get my body weight behind it. I lifted the back end off the ground about 5 inches, still no joy. Since I am taking it to the dealer next week, I'll let them do it.
    :surprise:
    Whew! Now you know how much of a pain they can be! I had the same problem with my '96 Outback the first time I changed the fluid - actually, it may have been the only time, I can't remember. Anyway, I had pulled the rear of the car onto a set of ramps (about 8" increase?) and still could not get the leverage I needed to break it loose. I ended up taking it over to a friend's place, where an impact wrench was available, and broke the top one loose that way.
    The bottom plug came out with no problem whatsoever.
    I too remember having to use my impact gun to break it loose the first time. Why they would put the fill (upper) one in so tight is beyond comprehension.
    I only have an air ratchet. I think the dealer can do it for $30.00
    Anyone what is the best and worst case senerio if fluid has not been changed in over 100K?
    girlcarbuildergirlcarbuilder Member Posts: 225
    All gear boxes slowly wear leaving a fine metallic sludge in suspension in the oil. It acts like a very fine sand paper over time. That is the reason for changing. I have seen many gearboxes with original oil way over 200K. It is best to change though to prevent problems. You will see the wear first evident in the form of play when you turn the input shaft. Excesive amounts will eventually sound like a clunk from a bad u joint.
    Problems in standard transmisions are more evident in difficulty of shifting just like worn out shifter bushings.
    Well friends.
    That humming and noise from the back was a bad bearing. It had reached end-of-life and was about to seize. Was it bad maintenance or the fact that it had 311,675 miles on it. That is the $495.37 question.
    Now they only did the driver/roadside. The passenger/curbside was replaced early on so it had 250K+ miles on it. Since it was done about a year after I got the car and was covered by the warranty. The dealer said today that it is close to going. I am going to have a local garage do that one.
    Now I can do more that 55 on the highway will way less noise. I can now hear the radio.
    :surprise:
    Gar! I should have thought about the wheel bearing, as I had one fail on a '69 Econoline van after it clunked and hummed for a few hundred miles. As it was, I ended up stranded fifty miles south of the Alaska Highway on Highway 37 (Cassiar) in northern Britich Columbia. I was back on my after four days and $500, but boy was that an expensive lesson to learn. :sick:
    Bearings wear out with age - that is just the way of it. I am not sure that Subaru bearings have a maintenance schedule, meaning you can repack them, etc., but it is something I do on my older rigs every 50,000 miles or so. Over a quarter-million miles on a bearing seems like a pretty decent lifespan to me. ;)
    Just 312k miles? ;)
    They don't build Subarus like they used to. :D
    I am happy to do this longevity test for you guys. All I ask is honorable mention in your memoirs when you talk about this guy drove to the moon and back in his Forester.
    wideopenslopewideopenslope Member Posts: 6
    I used to love the remote starter on my Mazda Protegé.
    Does anybody know if it is a smart option on a Forester?
    And being a live rear axle, it probably ruined your drum brakes with a good bath of gear lube! At least that's what my old '72 Mercury did to me.
    Poor Phil. He made it to the moon, but only a portion of the way back! Marooned...
    IIRC it's in the 2010 catalog, so I think so...
    To answer someone else's comment first. Yes the rear axle is live on 4wd and awd, but no there will not be gear lube all over the bakes, because the assembly uses half shafts that do not contain gear oil compared to a housing unit.
    So far, these bearings begin to run low around 200K on grease. Being large bearings, the low does not really make them run hot for some time longer. I have seen most of them close to failure around 240K. It requires a press to change them out. If you run them too long, it will distort the hub assembly. If it is not replaced, it will cause the next set to fail early. Use a good quality synthetic grease such as Valvoline part number VV986. Make sure any grease it came with is carefully cleaned out and repacked with this. Bottom line, not enough grease equals failure.
    I am hoping to come up with a way to inject grease into the assemblies when ever the half shaft is being pulled. It is a pain to replace these bearings, front or rear.
    I recalled something girlcarbuilder mentioned in post 18506.
    Over time fine metal particules accumulate in the lubricants around moving parts. This sludges acts like sandpaper and overtime wears down those parts swimming in the oils and greases. By changing these fluids you slow the wearing process down (but not eliminated it).
    Wheel bears were once removed from the vehicle, cleaned, and packed with fresh grease (I still have a tub in my garage). But now that bearings are sealed, that semi-abrasive sludge wears down the part until it fails (for me around 310K) and catastrophic failure (seizure) in another 5K.
    All bearings in a vehicle should be replaced periodically based on this line of thinking. For wheel bearings, I would say around 250K miles.
    Phil, you definitely get a place of honor in Subaru lore. ;)
    I wouldn't mind doing a longevity test. The problem is that I keep starting at zero. I just passed a whopping 7,000 on my 2010, though! Maybe I will get the car to 300,000 by the time my daughter is eighteen. To put that into perspective, she is now two. ;)
    Wes,
    There are a couple of reasons, I have not followed your foot steps.
    I do not like car payments. I got tired of driving the car for the bank. And when you have a major repair, you still have to make payments along with the cost of the repair. I took out the purchase price from the 401K and paid cash. Now that I am close to retirement, I can not do that now.
    With the size of my family, I would need a minivan. So another Forester would be out of the question right now.
    And finally since I keep adding up the miles, I want to be the guy with the most mileage as an original ower or any type for that matter. In five and a half years, I want to be able to post 500 thousand miles on this site.
    For clarification I was referring to the axle assembly that was typically used on older American cars - prior to the extensive use of IRS. The 'live rear axle' is a one piece assembly in which differential lube can enter the axle tubes, especially if overfilled. If the bearings and seals fail, 80W-90 gear oil can make it's way to the (then typical) rear drum brakes. I went thru this twice before I got smart and replaced the entire axle rather than continue to try and rebuild it. A year later I came to find out that there was actually a recall on early build '72 Mercury Montego and Ford Torino models to replace these rears, but it was only good for 5 years and I was now late. It was a venting problem, IIRC. Even when properly filled, pressure buildup would force the lube out the ends of the tubes.
    Wes's Ford E-series might have suffered something similar.
    Well, I hope - truly hope - that you need not follow my footsteps! I "got rid" of my 220,000-mile Outback the hard way. ;)
    While I also do not like car payments, this was a good time to become an original owner due to the electrical gremlins plaguing my van (which meant my wife would not use it due to not trusting it), interest rates, etc. Assuming no catastrophes, we look forward to getting many years of enjoyment out of the car. I really wasn't joking, though, when I said it will likely be 15-16 years before we hit the 300,000 mark! :P
    On a separate note, I just added a 1/2 quart of oil to the car last night after 4,500 miles since the last oil change. The dipstick read just a smidge under half-way between the "add" and "fill" marks. As the bit of oil I added was the last of a gallon bottle, I figured it was a good time to do it.
    The dealer told an untruth?
    I asked them to loosen the transaxle drain and fill plugs.
    They did it on the manual transmission, I still can't change the rear transaxle fluid.
    I guess if I paid them to change it, they would have gotten the right one.
    Phil, you might have confused them by what you asked for. The front assembly is a transaxle as it contains three elements - the transmission, the front differential and the center differential (in the tailshaft). The rear assembly is simply a differential, or 'rear end'.
    mhooksmhooks Member Posts: 2
    A little embarassed to ask, but is there anything tricky to replaceing brakes on a 2005 Impreza 2.5 RS (Wagon)? Specifically I was conserned with the ABS, i.e. do I simply disconnect the negative lead on the battery, or is there more to it?.. Never done it before, and I just wanted to make sure I don't screw anything up.
    Unless there is something new added that I'm not aware of, you really needn't worry about the ABS system. In addition to the normal hydraulic line going to the piston, there will be a single wire going to a speed sensor mounted on the hub. In a normal brake service, even if you are pulling the rotor for resurfacing or replacement, you won't be disturbing the hub & sensor setup itself.
    I did my Forester and it was pretty standard.
    The only reason it was tougher than my Miata was that it had dual piston calipers, so it's a bit more effort to retract those.
    Should I worry about bleeding the caliper? just don't want to mess anything up.
    I don't intend on changing the brake fluid quite yet......just need a fix for about a month or so
    Thanks again.
    A full fluid change periodically is highly recommended. That said, I am guilty of occasionally just slowly and carefully pushing in the piston with a wood block and a C-clamp without opening the bleeders. I recently bought a tool from Harbor Freight that should get this done with less risk than the big C-clamp approach.
    Same here, the tool was cheap and paid for itself in time and hassle the first time I used it.
    oneduckstwooneduckstwo Member Posts: 34
    It's been a long time since I've been on here which I think is a good thing! Anyway, my 02 Bugeye has about 103k miles on it (w/no problems other than the somewhat common: cold weather gas smell...dealer replaced some gas lines, etc.) and I've had the reverse gear pop out while reversing about 3 times in the last couple months. All times were under heavy load (deep snow or quick reversing.) I'm just wondering if there is any consensus as to what my future repair might involve?
    Moving through the gears going forward seems the slightest bit more clunky lately but it could be b/c I'm trying to pay attention to it.
    Thanks in advance.
    jbur1jbur1 Member Posts: 15
    I finally got a decent day (around 40 degrees) to investigate the coolant leak further. I noticed some areas wet with coolant but did not see any hoses in the vicinity. I hate to think that it may be a head gasket based on the photos posted below.
    I wish I could annotate your pictures and repost them, but I'm afraid that I don't know how. Your top image tells me a lot. You are looking down on a pair of hoses that go to your cabin heater, and right below that is the steering box. The box is wet. Do you see a philips head screw on the steering box to the left of the steering shaft? Move an inch to the left of the screw, dead center in the photo, about an inch off of the left margin. That is the back of the head, and it looks like there is a paper/plastic barcode tag glued to it. Just 'north' of that spot you can see a crease line - that's the edge of the head gasket, and beyond that the block. The tag area looks yellowish and wet. That is exactly where mine leaked from on both occasions.
    Below that spot, but above the steering box is a greyish curved heavy piece of metal that is part of the subframe. The cutout in this brace is what enables you to see down to the steering box. It looks coated in green and quite dirty as well - almost exactly as mine did. Guess what the 'green' is....
    Sorry to be the bearer of bad news, but I think you already knew the score.
    rebel71rebel71 Member Posts: 87
    Is it standard practice for the dealer to charge you a diagnostic fee, even if your vehicle is under warranty.
    I've had this complaint for years, and talked to Service Managers about it. The net is that policies constantly change, but in general the manufacturers reimburse the dealer at a very low rate, or sometimes not at all for service visits that result in a "No Trouble Found" diagnosis. This means that the dealership, who is an independent business and essentially the middleman in this transaction ends up eating the cost of you coming in with a complaint that doesn't result in a repair that can be billed to the maker. Depending on the issue, they may eat it, or pass the cost on to you. It depends a lot on the nature of the complaint, how well you document and/or demonstrate it, etc.
    I don't like it, but I am coming to understand it.
    forester_incvforester_incv Member Posts: 10
    my 06 with just 24K miles does a bad shift, hard with a bang, think it's 3rd to 4th, usually at 30-35 mph, when under 40F, often lightly loaded on the throttle.
    Tranny fluid on this auto was very yellow by 15K miles. I did a partial change (3 drains, fills), that helped, changed the $40 filter last week, that improved things too but still getting that hard clunk shift sometimes (but fluid-filter definitely helped).
    Is this typical in anyway or do I have a tranny failure coming? (under 6/60 warranty I hope). Thanks for any opinion or advice.
    The sudden advent of 'shift shock' can mean that the clutches are burned/contaminted so that they grab too fast, or the fluid pressure on the actuator is suddenly too high (valve body issue?). Either way, it can signal coming major trouble. I'd get it looked at, especially if you are still under warranty coverage.
    However, see my post above yours for the possible outcome if the dealer doesn't agree that the tranny is bad! I went thru this exact same scenario on a Toyota for multiple visits until just beyond the 5/60 warranty. Amazingly at something like 62k, the tranny was now declared a total loss, and the district mgr denied the claim! I don't think Subaru would be so arrogant, but it's best to build your case carefully and methodically. Note that I don't presently own a Toyota....
    Thanks for the confirmation of my suspicion. Or should I say thanks -not! Since my vehicle (2003 Forester) was not included in the Subaru extended warranty I guess I need to make a decision since I have about 81,000 miles on the vehicle. Whether or not to purchase a new vehicle or to invest in this repair along with other service needs in the near future (i.e. timing belt, water pump, etc.). The other unknown is how long the head gasket repair would last since this seems to be an ongoing issue with this engine.
    hammerheadhammerhead Member Posts: 907
    My 99 LGT wagon had both head gaskets replaced at about 119K (before I bought it, per the paperwork that came with the car). IIRC, the bill was about $2K. Car has 176K miles now, with absolutely no sign of HG issues.
    Cheers!
    Paul
    lucien2lucien2 Member Posts: 2,984
    had to do ours at 130k, but the car only has 140ish on it now. So yea, no probs ;-)
    Sorry to have been the bearer of bad news... Nice pixs, by the way.
    Unfortunately, I am on the unlucky end of the spectrum, and have had two failures - first at 15k, then again at 63k. Even though my car is an '02, my VIN was exempted from the extended warranty. Only '00 & '01 were covered in full, '02 partially, yet SOA picked up the full tab. I have a friend with a '99 that was also taken care of as a courtesy.
    My suggestion is that you call 1-800-Subaru3 and open a case prior to bringing it in for service. When you take it in, give the service mgr the case number, and ask them to call SOA and go to bat for you. If you have any kind of positive relationship at all with the dealer, you might get at least some of it covered.
    While mine was apart, I had them do the timing & accessory belts, paying only for these extra parts. It all has to come off anyhow, so it's the time to do it. Labor was already covered.
    See if you can turn your 'lemons' into lemonade and get to drive the car a while longer.
    canddmeyercanddmeyer Member Posts: 410
    The other option is hose it down well, then drive it to the dealer on a rainy day and purchase a new vehicle without wheeling and dealing too much. You get a new vehicle; they get to fix or auction your old one. Save the hassle and go new if you can afford it. At the price they want for repairs, I'd prefer to put that into a new vehicle and knock on wood, hopefully be problem free.
    johnmccjohnmcc Member Posts: 5
    Sorry to hear about your problem.I had my head gasket go at 63,000 just after warranty even after had it there earlier to check it out but of course they found nothing until had that nice over heating problems.I found every site I could find talking about bad head gasket on their 2.5 L which seem to be the case from 1999-2009.Oh make sure you copy all links to complaints about head gasket failure and send them too Subaru head quarters it's what I did and finally got them to cough up some money but still cost me a lot to fix it.A Subaru mechanic I know said they just finally change the head gaskets in the 2010 models.If you get the head fix then do rear end seal,serpentine belt,timing chain,water pump but these depend on if your over 60,000 if you are they have to take most of these off to get to them anyway so replace them so 10,000 down road don't have to pay for labor again.Oh yeah make sure change coolant sensor it's $15 and I had all kinds of problems still with temp gauge turns out the sensor wide open easy fix.Oh do not do not do not let them put any of their coolant conditioner in your coolant system.It's just Holts leak seal with their sticker from what I found out from talking to more them a few EX-Subaru mechanics.That stuff over time clogs the radiator and causes much of the over heating down the road.I learned the hard way.Get something called RMI25 that's the letter i not a one in the RMI25.It's a coolant system cleaner that removes all the build gunk over the years and puts it in your overflow which you have to empty out a lot until all gone.This stuff been around for about 30 years it causes the water to become akaline gets rid of electrolysis.My heater always took forever to warm up now it could cook eggs.
    It was a long time ago, but I'm pretty sure early Foresters had an issue with popping out of gear, not many of them but a few.
    Search for a TSB on that, though I don't think it was as recent as model year 2002.
