Vibe Maintenance & Repair Concerns
Roy
I'm confused - what is Pontiac or Buick ceasing production on? The tires, gas tank, car??
I would have prefered a Toyota but couldn't afford the ticket price. Perhaps should have looked at the Hyundai more but now that I have "her" I'll do the best to keep up with changes. I'm just not used to having any issues or problems with a fairly new car. (My PV 2005 21,320 miles at purchase). My next big decision is to decide whether to buy the extended warranty. I've only had the car 2.5 months and it's been in the shop 6 times.
The radio/CD player is still not to my satisfaction. They couldn't fix it the first few times so they put in a whole new unit. Still CD's skip if I hit a bump and there is a background noise that doesn't change no matter what I do to the controls. Good luck
I hope it's Buick that goes it would be awful to not be able to get parts, but then Matrix parts should fit. I should have my head examined for buying GM car wife liked the styling, never a goodreas to pbuy a car or anything.
Apparently, you can't get a roofrack with a Toyota Matrix.
Oh Yeah, I emailed GM for the Vibe Roofrack max weightload. It's 75 Lbs.
That worked so well, the next question I asked was what the reccomended mileage was for replacing the timing belt. They did not reply. If it had a timing chain, I expect they would have replied rather quickly to correct me and to point out the advantage of a timing chain vs a belt. :confuse:
Seventy-five pounds my foot.
http://www.msu.edu/~steine13/vibe.html
That's a 58-lb. canoe, a 65-lb. canoe, plus the weight of the rack hardware.
It's the factory rack that's rated at 75 lbs. The Matrix has a roof load of 125 lbs. with the proper hardware.
If you use the new kind of Yakima Q towers, the Vibe will handle 125 lbs. just fine and probably more.
And yes, it's an interference engine with a chain.
-Mathias
I was just looking for this information. Can you provide or know the site to look at for the PVibe 05 roof rack limits.
75 lbs is nothing and I wonder why if the Matrix doesn't even start with a rack has a higher capacity. Probably Toyota vs PV (boy, do I miss my Toyota).
Also, I was going to use the Pontiac accessory site to buy parts to install a 12 speed and Mt bike on top. Would the Yakima system be better and do you happen to have a customer link where I can get that information. Appreciate the data and this automatic email delivery helps lessen the excuse why I haven't set my car with the funner ride of a bike! tks
d
The weight limit for the Vibe roof is 75 lbs.
Nobody will tell you differently, least of all a rack manufacturer.
It's the limit for the factory rack, though, since GM apparently didn't think anybody would use additional hardware. And if you look at yakima.com and spec' out a Matrix rack, you'll find that THAT car allows 125 lbs.
Just speaking for myself, and not giving advice, I decided that I would put a bunch of weight on my car by using Q towers in front and Rail Riders in back. And it woiked.
Forget the Pontiac site and buy either Yakima or Thule. Better yet, get an '01 Cherokee and use a raingutter rack ;-)
-Mathias
BTW - What is the advantage of an interference engine?
What is your RPM crusing at 65MPH?
Cruising RPM? Dunno... I don't have the car anymore, but I do know I checked it to compare it against our Sienna... seems like I remember at 70 mph, the van does low 2000's and the Vibe did, don't hold me to it, something like 2,800.
It's a pretty loud car, but at speed, the wind, tire, and engine noises kinda blend together reasonably well.
I'm gonna get another one, either next year, or a year after the replacement comes out.. that'd be '09. IF there is a replacement, which I doubt. Probably wouldn't buy it if I didn't have help from the (old, blue) GM Card.
-Mathias
32-33psi is for the rest of the years driving.
:shades:
during this time i had the A/C problems...new compressor
and also a squeky brake problem...twice now they have tried to "clean" the rotors, squeek sounds like it is coming from the rear drums.....any one know of a fix?
Also just recently discovered another problem: when i turn off the recirc button something behind the dash starts to click. it also does it when i try to use the defrost? just annoyed now have had the car only 3 weeks and have more problems than i care to deal with.
Please anyone have a fix for any of these?
RoyNC
My car is ready for it's first quarterly maintenance. I'm curious about the compressor for the AC. Since I've read in other websites that the PV has poor AC I just took it for granted that the car takes so long to either cool down or warm up (though in Texas) we have SO NOT needed any more warmth.
My question, then is how do you know you have an AC problem? Meaning, mine comes on but doesn't get very cold - so is that how you knew there was a problem? (or did it just not come on at all?).
The other issue I've seen alot here is about the tires and the rotors. The dealer has told me NO PROBLEMS - now. My car does ride rough but I'm not skilled enough to know if it's the tires or not and since I had alot of first time repairs right off the lot (bought it used 2005 26K miles). To my surprise they had to replace all the rotors (at an unreal low mileage) and I had them rotate the tires as well. (Mine were still good on my old Toyota Camry at 135k and I had them replaced just for safety then).. there is sadly a difference between the 2 make-ups of the car.
Since I'm just about to be logging real high mileage in the next few weeks, I'm kinda wondering about the tire wear and
at 27k what types of maintenance I should have completed.
The pontiac site(I registered there and asked them what maintenance should I do for this time based also on my VIN) they emailed me back with this list for 27k miles states I need to do (estimate low cost= $151) these things: (a big ouch for sure). What do you think?
air filter (i can do)
automatic transmission flush and change (?)
cabin air filter (?)- I've seen mixed views on doing this
lubricate chassis
replace coolant and inspect system
engine oil change (I'm thinking of going synthetic - and
wonder if after NOT having synthetic before if that's
a good idea)
oil filter replaced (i can do)
fuel line and cap inspection
rear differential fluid change (?)
transfer case fluid change (?)
wheels and tire inspect and adjust air pressure
brakes inspect
all fluids inspect and fill as needed
The ? means I'm unsure where this is or if I can do these myself once I figure out where to go?
any thoughts
also, was looking for any thoughts/answers for my problems with the brakes squeeling and the clicking behind the dash when i turn off the recirculation or use defrost?
today i am going to replace the front brakes and lube the rear shoes where it makes contact with the drum. hopefully that will eliminate that. i will keep everyone posted. just need help solving the other issue with the a/c
then went on to fix my A/C problem with the recirculation/ defrost clicking behind the dash. opened the glove box up and found it right away. the motor that opens and closes the cabin air filter was causing the filter door to be bouncing from closed to open. i took the motor out and discovered the main plastic gear assembly had two teeth missing. today i am going to the dealership to try and get just the gear. (no one else carries it.) i will keep you updated.
I also noticed in the mornings when I'm pulling out of the driveway after having the emergency brake on that there is a groaning sound coming from the front left tire. I thought that was because it was just "new." Well, not so. The dealer says it's a leaking strut and they have to order the part.
As for the starting not happening, they say there is a neutral safety switch that prevents the car from being started when it's in neutral without the clutch depressed. OK. I'll buy that. But what about the times it was depressed???? She said they'll check it again.
I have been so ecstatic the last couple of weeks. The car is a blast to drive and I'm finally settling into the manual trannie. Now my confidence is shaken as I wonder if I have a lemon? I researched this car for two months and didn't decide on the purchase lightly. I paid cash for the car and expected to drive off without worries. I'm really concerned there is more of this to come.
I also noticed when washing it this weekend that the front left panel over the wheel well is slightly off color from the rest of the car. I know I'm being really picky, but that makes me kind of curious. The car was delivered to Richmond from Philly and came to me with 288 miles on it from the trip, so I can't imagine there could have been an accident in it?? Maybe just a manufacturing flaw?
BTW, it's the BEAUTIFUL Stealth color!
As far as the struts; stuff like that happens. There's thousands of parts on your new car, it'll be more in the shop the first year than the next three. I had a Nissan did a couple things like that followed by 5 years of trouble-free driving.
Good luck,
-Mathias
I had the same problem. The Technical Service bulleting said to replace the HVAC actuator - the motor that opens and closes the door between inside and outside air.
I did this and the mechanic said the new actuator operates all the time irregardless of the button setting (recirc or outside air and that the actuator would burn out if it ran all the time. Thinking it might be a faulty actuator, I replaced it again but with the same results.
I unplugged the new actuator to keep it from burning out and hope someday Pontiac will tell us what the real problem is. It must be upstream from the actuator, perhaps the switch, that is causing the malfunction and eventual symptom of a blown actuator tapping away below the glove compartment.
So we are living without the ability to recirc inside air. What this means is that when it is really hot outside it takes longer for the AC to cool the car and when it is really cold outside, it takes longer for the heater to warm up the car. Fortunately we live in a climate that that only goes to those extremes about two months out of the year.
I trust that Pontiac has someone reading these forums and will come up with a solution for us. There are a lot of people who report this problem.
For example, here in the Pontiac Vibe Group you'll find:
New Vibe Owners - Give Us Your Report
Pontiac Vibe Test Drive - What Did You Think?
Vibe and Matrix Maintenance & Repair Concerns
Pontiac Vibe: Audio & Entertainment Questions
Pontiac Vibe Electrical/Lighting Issues
Pontiac Vibe Engine Questions
Pontiac Vibe: Changes You'd Like To See
Pontiac Vibe Tire/Wheel Questions
Vibe Transmission Troubles
Pontiac Vibe: Accessories & Modifications
to name a few of the discussions.
So when posting, we'd like to ask you to please check the discussion list here in the Pontiac Vibe Group for the appropriate discussion to post in. If the issue or problem you wish to discuss doesn't appear to have an existing discussion, please feel free ot create one. Should you accidently duplicate an existing discussion, we can deal with that as we go on.
Thanks for your understanding and help in making this a valuable source of information for Pontiac Vibe owners and fans.
So here are some questions and if you have an answer to any of them please let me know:
1. What is the average gas milage you have experienced both in town and while on the highway?
2. What is the maintenance record? What have been the common things to fail and at what milage did they fail? How much did it cost to repair?
3. What is the plausible service life of the vehicle? I am looking to get 200K of more and will that be fairly trouble free with routine maintanence?
4. Performance-wise how do the different motor options stack up? If you could would you recomend the AWD even though it has the lowest horsepower rating, or do you get the higher performance though front-wheel drive only engine?
5. Comfort-wise, how did you feel after a long trip? Did you long to get out of the car or was a long trip a fairly bearable experience.
6. Did you feel safe while driving the car? Meaning did you feel confident that you would be able to handle all types of weather conditions and or traffic conditions such as snow and or ice, and panic stops and manuvers? If not, in which conditons did you not feel comfortable with and would you attribute this to the car's inability or your inability to handle the condition? Example: would the car be able to handle an icy road, but you would not because you have never driven on one before?
These are my basic questions and any advice is much appreciated. I am looking to do 2500-3000K miles a month and need to do so in fairly good comfort with out having to spend an arm and a leg at the gas pump and at the repair shop both before the 100K mile mark and after. I understand that there are parts that wear out and nothing lasts forever, but if I can get the car to go to 200K with out any major repairs, that is what I am looking for. And if I can get it to do that while maintaining some degree of comfort and style I will be happy. I just don't want to be stuck driving a fancy Geo Metro.
