and worst of all is the unusual seat movement in both seats about 1/2 inch travel whe stopping and starting seems that would have been a recall item does anyone else have these problems with their 2000 z3.Thanks for any help possible God Bless
any help would be greatly appreciated.Thanks
The seat movement is due to deteriorated rubber bushings in the seat rails. I replaced mine using plastic discs I made from my recycling bin. There is a you-tube vdeo that explains exactly how to replace them. Go to youtube .com and plug in BMW seat repair.
This is from my manual
Automatic transmission with Steptronic*
You can drive as with a normal automatic
transmission. In addition, you can
also shift manually.
When you move the selector lever from
the "D" position to the left into the M/S
range, the performance-oriented shift
programs of the automatic transmission
are engaged. As soon as you briefly
touch the selector lever in the "+" or "–"
direction, Steptronic changes the gear.
The manual mode is engaged. When
you wish to use the automatic transmission
mode again, move the selector
lever to the right into the "D" position.
The automatic transmission of your
BMW is equipped with Adaptive Transmission
Control (ATC), a system which
reacts with precision to your individual
driving style and the driving conditions.
To achieve this, different shift programs
are automatically engaged.
For additional details concerning the
ATC, please refer to the chapter
"Advanced technology" on page 166.
Selector lever positions
P R N D M/S + –
Dave
________________________________________
and to left on console there is a button with an A or M which does what I stated earlier according to the book buy it's very vague and you when you visit your local dealer service dept and they think like me it's used for highway then it makes you wander then who made the doggone car DUH????Their not for sure they think???????? :mad:
Dave
bornleader@comcast.net
I often link to a specific post in other enthusiasts' sites if they permit it. What Edmunds frowns upon is active solicitation of members to other sites for recruitment purposes. This is all spelled out in the Member Agreement which we all see when we register here.
So feel free to help Jose if you can find a post that directly addresses his issue.
My advice would be, that unless you are slipping badly in snow, to ignore that button and just downshift manual in the regular "A" mode.
Doesn't really matter. If something happens, just put the stock one back on before you take it in. Pricky dealer if he would make a hassle out of that anyway. A supercharger would be a different story.
Boy, did I have sticker shock when I priced a paint job. $4800 from a GM dealer. Another guy guessed at $8000. One good shop was $2500 but I used to buddy around with his dad, so maybe he treated me right. Some suggested looking for part time guys or small shops that may need the work. Still looking with a $1500 target but I may strip it myself. One guy said anyone can shoot the case coat as it won't run. May try it. But for now, I'll just try to fill the chips and may try slightly contrasting colors on the depressed area by the 3rd brake light, between the tail lights and maybe the hood bulge. Anyone have a reference to unique paint jobs? Now is the time to play as I can correct it with the paint job. I just picked up some dark blue spray cans. I think I can mix a lighter and darker color to get a good match to cover all the white primer chips. Anything is better that it is now. BMW wants $28 for 2 little bottles of touckup. Comments welcome.
So, what am I missing here? There is a Clarion aftermarket stereo installed with a power amp in the trunk, so someone must have been there. And the 5"? woofers have a plastic cone. Is that OEM? At any rate, does anyone know what the trick is here? Probably simple, but I'm stumped.
HALP
The surrounds on my speakers were split so to see if it was the problem. I fixed them with contact cement and reinforced the break with a thin coating of adhesive caulk. So far so good. Will eventually replace them but not sure with what. BTY, one speaker looked fine but still buzzed. Upon further insoection there was a crack not visible until I flexet it outward with my finger.
Google Madisound speaker to see wjhat they have for replacements. They have been around forever and also sell high quality speaker kits. I would guess they could suggest quality replacments. Please post what you find for replacements.
Jerry
An 8-ohm speaker would give you a slightly lower sound level, but should not damage anything, and you can always turn the volume up a bit to compensate - that is, unless your drive around with the volume turned up to max all the time anyway :P .
Read more: http://www.cars.currentblips.com/2011/09/lured-in-by-opel-ampera-tech-bmw-seeks.- html#ixzz1XqL9OQDh
As for fixing them, you'll have to gear up some, and get a good scan tool, a volt/ohm meter and a factory workshop manual. No reason why you couldn't do things like fluid changes, brake pads, tire rotation, belts and hoses, that sort of thing. It would be a much higher learning curve to get into engine work or electronics.
It would be a great idea also for to a) join the BMW club of America and b) line up an independent BMW repair shop that you can develop a relationship with. To take care of a car like this, you need a support system so that you are not dependent in any way on the dealer for service or parts.
But to back up a bit. Last summer, there was another 96 Z3 1.9 for sale back home. After the ad ran for a few weeks indicating a deal may be had, I reluctantly decided to look at it. The car body was rough but no rust and the leather seats had weathered well over 109k, unlike what I see in Arizona - Boxsters especially. What do they use for leather in those things? Anyway, I thought What's to lose by taking a drive even though I already Know I don't like it. Hmmm, solid lil sucker. Drives great.
Somewhere on that drive I was shocked to discover Hey, I like this one.
But, I didn't buy it. I still wanted that Boxster and the Z's never really appealed to me.
OK, so now I'm in Arizona still looking for that 2k or newer Boxster private party. Nothing. But along comes the Miata. So, missed that one. In the back of my mind was that Z3. Ya know, I think I'll see if she ever sold it when I get home. I drove past and called multiple times. No car and no answer, so I figured it was gone. Then after a few weeks, I saw the ad laying there. What the heck. I'll try one more time. Phone rang and rang..... and rang. Finally, she picked up. "Do you still have your BMW for sale?" "How you know I have BMW? "I looked at it last year." People wast my time. Not buy my car. They not interested. (Testy little Chinese gal') "Well, I must be interested, I'm calling you.
Anyway, my wife, grandson and I went over and I drove it again while wife and G'son waited in the car. BTW, my wife was not thrilled with this adventure. I went back to thr car and my wife starts out with " You didn't buy it did you? Yup. Guess who now likes it? ;-) We both do. It's getting a nice dark blue top to match the upcoming Montreal Blue paint job. But right now, I'm back in AZ while the Z rests, still looking for that elusive Boxster.
Oh ya, the 1.9. For some reason, this one seems to have lots more power than the one in AZ, but it could have been my mood that day, who knows?
Good torque and just shift at 1.5 - 2.5k for normal driving. Step it down on the road and the speedometer moves up rather smartly too. Totally adequate, especially when you consider the great gas mileage - just under 37 first tank but that may have been an anomily. Another owner I spoke with proclaimed that the 1.9 runs on fumes. What do you other owners get for MPG. We are now quite happy that we have the 4 cylinder. I can drive my 55 Chev with the 396/425 HP if I want to smoke em. Good luck with your car. I think you'll like it.
http://www.youtube.com/watch?v=xvLRMGs-Ti8
While there were some attempts at rectifying this issue, you can't be entirely safe until the redesigned 987 in the year 2009 I believe.
Not every Boxster will do this of course, but god help you if you don't have any potential purchase thoroughly checked out.
Maybe the Z3 wasn't a bad choice after all. I will say that the 1.9 seems to be a sweet engine, and sounds like an engine.
BTW, it seems that your Spell Check isn't working.
Any input would help. Thanks, John
