Paint color?
Paint selections are very slim on pickup trucks.
Even when manufacturers introduce new colors, they
are often restricted, limited, or eventually
dropped altogether (dark blue comes to mind). What
paint colors would you like to see offered that
aren't - or have been dropped?
Personally, I would like to see Black Cherry (a
near-black maroon paint with red metallic flakes),
Royal Blue metallic, and Black metallic (if you've
ever seen this on a BMW or Benz, you'll know it
beats regular Black hands down). And I would
really like to see someone do a black truck with a
white center band two-tone. This would look pretty
good on both the Ford Super Duty F-series, Dodge
Ram, and Dodge Dakota.
Your votes - nothing ridiculous, just OEM colors
that don't exist now.
As far as general OEM colors -- I do like the idea of a metallic black CC; I can't say that I'd apply the white stripe though. Just not my style.
I'd be interested in a good grey. This is a very easy color to do wrong. One of our neighbors has a newish metallic grey Ferrari -- its absolutely beautiful.
Yes, Dodge does use it on the pickups - it's called "Intense Blue" (very appropriate).
I would be very careful about changing the brand of paint on any vehicle. There are compatibility issues. According to my wife's brother in-law, who works for a paint manufacturer, the modern automotive paint job is a "SYSTEM". The system starts with the bare metal preparation and goes up through primer, color coats and clear coat. Mixing between brands gets very ugly in 3-6 months.
Rich
But, I wasn't aware of any new "process" involved in new paints. So, if I do get around to repainting my truck, which I probably will, I'll take it down to bare metal and hopefully that will make the paint job last for more than six months.
Thanks again for the pointers. Also, I admit I haven't done a base coat/clear coat paint job yet althought I have seen it and it seems easier/more forgiving than the acrylic enamal and the lacquer that I've done.
Just had to vent.
Ryan
And the sanding of the clear coat was a [non-permissible content removed] too....
Oh well, I'll just do it all over again...
Ryan
Tom
Ryan
Tom (bigfur)
My GUESS is that there may be a paint incompatibility. An easy way to test is to spray a spot on the inside surface of the wheel. Let it sit for a few days and check for compatibility.
Rich
Does anyone know if Ford has declared a replacement for the Dark Blue color that they pulled earlier this year?
Ryan
But I must agree---it can't replace that previous Blue. That was really neat!! Who knows, by the time we reorder in the early Spring--several other colors may be available. Good Luck. JB
I've always heard that silver was the color that was the most sensitive to sun damage.
Any opinions? (My better half wants to order a silver color car. All I've ever seen is half silver and half primer after about 5-6 years in the LA sun.)
Rich
