95 suburban vibration
I have 95 diesel suburban 4x4. From 65mph+ the vehicle vibrates. The faster you go the more it vibrates. Here is what I've replaced trying to stop the vibration. Four new Michelin's, rear shocks(bilstein's),new drive shaft w/u-joints, new rear brake drums, 3 alignments, new steering stabilizer. Vibration seems to be coming from the rear because steering wheel doesn't shake much. Any suggestions!
I have briefly looked back over the preceding posts, and I do not see the idea of shaft balance addressed. I have seen weights that were like rectangular patches of metal, that were attached (spot welded?) onto drive shafts. I was advised that these were balance weights. I recall that certain drive-line specialty shops did this variety of shaft balancing. You might pursue that avenue a bit.
I am plumb out of ideas on your situation! Let us all know what you finally discover.
