Motor Mounts
While replacing a light on my Grand Am, my son saw the motor actually move when he moved my car to get to it better. When he started to just move the car forward a foot, the motor literally shifted forward & made a clunking noise.
My question is this: Where should I take this to be done? I've had problems with a repair place & would like to know approximately what it would cost (I'm on a low income-so extremely important) & who to trust. Are there specific shops that do this work?
Thank you so much for your help.
I have a 1996 Grand Am that just died on me yesterday. It looks like a problem might be with the Generator Drive Belt. I have the drive belt for the car but i just need to know how to install it or if there is a web site where i can go to, to get the info.
Please help
Thank You
I hope I don't think about this, because then I'll really develop an opinion
Remove or Disconnect
1. Place a jack with block of wood on it under oil pan to support engine
Important: Make sure the wood block extends past the width of the oil pan to avoid damage
2. Torque axis engine mount where it connects the mount to the engine mounting bracket
3. Electrical connector from crank sensor
4. Engine mounting bracket lower stud, and lower engine to clear frame rail
5. Raise engine and reinstall bolt into torque axis mount. Lower engine to allow spacer to be removed
6. Belt
Install or Connect
1. Belt
2. Spacer. Remove bolt from torque axis bracket and lower engine
3. Electrical connector to crank sensor
4. Mounting bracket stud
5. Raise engine and install torque axis mount bolt
Some other GM's are similar. They don't get changed on the side of the road.
You ever talk with one of these genious engineers who design these things? LOL!
These guys only know numbers. If the specs say that they can fit a part into a 4" area, they will build the part 3.85" big.
If something else has to be installed over it, then that isn't there concern.
joyrider, yeah, if the engine isn't being held in place, bad things happen. it's instructive periodically to leave the hood open and pop the accelerator, and see whether the engine wants to stay under the hood or wants to dance. you can see that much under the crack between the hood and the vent cowl from the drivers' seat. if the latter, get thee to a parts shop pronto.
