Chevy Silverado: Problems & Solutions
:shades:
engine. The fix was to clean the intake where the butterfly works and install a small piece of some type to help prevent further problems. Our vehicle was fixed by a GM mechanic and we have not had a problem since the repair.
The repair had been made once before without the part being added and we had the problem again.
until i got in it after work. >_<;; mine is set to automatically lock when you shift gears from park; when it tried to do so, the doors made a horrid noise. i experimented with it some: when unlocking with the power door locks, it makes two quick subsequent clicking noises. when locking, it makes an almost... griding of gears noise. it's a short one, but kind-of loud and mostly based in the driver's side door. i'm unsure what could have caused it, considering i didn't really drive it much today in the first place.
my mother thinks it could be the battery (it's never been replaced, but i've not driven too terribly much), and i've read several threads saying a blown fuse may create a problem like mine.
any thoughts, guys? ( poor giant green cucumber. ;__; )
Just put in a new power steering gear box and even though reference marks were made for reinstallation, a couple things are off now. 1) The wheels are ok in relation to each other but are turned a bit to the right. 2) From the center point where the steering wheel is, I can rotate the wheel 1.5 times to the left and 1.25 to the right, so I think maybe the gear could have been off a turn or two where the pinch bolt goes(?)
Does anyone know how the pitman arm should look in relation to the gearbox or truck body when the steering wheel is centered? Should it be parallel to the gear box or parallel with the front to back end of the truck?
With all that said, When moving the steering a little left to line the wheels up, the pitman is now parallel with the steering box and the max travel to the left and right from that point is the same. I'm wondering if things were off to begin with and maybe now the steering wheel should be moved... I can't seem to find any info on the pitman position. I haven't actually moved the steering wheel yet.
PS: I have also noticed my truck's suspension sags lower on one side (like many others posted here), and would also appreciate any advice/opinions regarding this!
Thanks in advance for any help!!!
I know to hold the compass button down until i have to pick a zone, but I have no clue as to the zone i am in while in miami, FL. then I have to complete 3 circles/// I believe,
Anybody know or have a map ofthe different zones in the US?
You'll need an 18mm socket, 1/2 inch drive, with a long breaker bar or torque wrench. Being sure the truck is on flat, level ground, measure the front height. It doesn't really matter where you measure as long as your consistent. Forward frame is best. At the aft end of each torsion bar you'll find an adjusting bolt. Turn clockwise to raise the truck, same amount both sides. Experiment to find the height you want. Try 1 1/2 turns to start. When you get it where you want it drive the truck over a dippy road and re-measure on the same flat, level ground and adjust if necessary. When your satisfied take it to an independent front-end shop and have it re-aligned. 50 bucks!
-David
-David
Ok my climate control would flicker and some times get stuck on ac for some times now. I have been looking to replace it but its no longer available and can't fine after market. Well today on my way back from picking up some synth freon since it only lasts a year here in the desert the whole thing died. No power or light or even the vent blowing. I beat on the dand thing. I can't go through 100+ weather with no cool. Only one window cracks open. My 78 Seira clasic ac pump was dead when I drove it here. But, hey! That was back before Desert Storm and I could walk on water. I can't take the heat no more. I would throw an old one it but hey this model is square just like the radio. Man I miss my 78 Sierra Classic, That thing was a beast and only had to mess with easy old stuff,no electronics up the wazoo and more room to dive in.
So if anyone knows where I can get this climate controle please let me know. blackmoonrising at cox dot net
Your situation reminds me of the problems I had with my boat equipped with a Volvo Penta SX outdrive (marine transmission equivalent) It developed a really annoying rattling noise at about 15 hours. When the engine was running, it sounded like somebody was shaking a bucket of bolts.
They changed all the bearings in the upper gear case and reshimmed the gears. The noise went away for about 10 hours and came back with a vengeance. More bearings and shims replaced, again the noise returned a short time later. I requested that they install a new complete upper gearcase at this point. They refused. Finally, I had enough. I wrote a letter to the CEO of the company, complaining about how my boat spent more time in service than on water and nothing was getting accomplished. They decided to replace the entire outdrive(upper and lower gearcase). After the new outdrive was installed, no more noise or other problems. It has been fine for 9 years.
The mechanic who worked on my outdrive suspected that the internal upper gearbox bore was not machined correctly and that no matter how carefully they rebuilt the gearbox, the noise would return.
You could have a similar problem with your transmission. The transmission case could be somehow defective and no amount of rebuilding will solve the problem. A new transmission probably will.
Note: If they refuse to give you a new transmission, I suggest contacting a good lawyer and take it from there.
1)How much damage is most likely to have been done?
2)How hard is it to replace the oil pump?
Any help would be very much appreciated.
sometime when excelerating up hills
He could have a defective bearing on one of the idler pulleys, water pump , or the alternator. Recommend removing the serpentine belt and runnning the engine with the truck in park for several seconds, including higher RPMs to see if the noise disappears.
If you have the hub cassette it is a bit pricy but easy to repair. good luck
FYI:::::
my buds 04 1500 5.3 !
Nature of the beast from what I read on the GM
truck forums..................
