slow power windows 1991 LeSabre
fordnightmare
Member Posts: 40
All 4 windows go up and down very slow. I find it hard to believe that all 4 motors are bad, but I guess it's possible.
I was thinking I may have a voltage problem. I Haven't measured the voltage though.
Any ideas?
Thanks..
Any ideas?
Thanks..
which brings up the question of whether you feel adventurous enough to take the inside door panels off and clean and lube up the running gear of the window assemblies. it's work, but that might be exactly what is wrong in the first place.
If the door panels are not going to be too much of a hassle, what sort of lubrication should be used? Grease? WD-40? Triflow?
Another thing is that if you wait until the water level inside the car is the same as the outside you can open the door because the pressure is equal inside and out, basically 3/4 of the interior will have to be flooded. Of course you will be under water, so be ready to swim. This is not only or ice fishers but for the people that might have the unfortunate opportunity to slide off the road and into the drink.
I know I have some silicone spray kicking around my garage, so I will try that (on the passenger side first, of course ).
Any other suggestions? I am definitely NOT shelling out $$ to have new motors put in.
I guess I need to tear into one of the doors.
Thanks for all the info...
