Volkswagen Passat Maintenance and Repair
1404143454665
    wondering74wondering74 Member Posts: 1
    New member here. (Female so please respond accordingly)
    I just purchased 99 Passat 1.8 Turbo, automatic. I have no maintenance records from previous owners. What all do I need to check first? What maintenance do you suggest I go ahead and do? Problems found so far: (1) ABS/Brake light on. Already found a company in FL that would rebuild the ABS module for around $200 with 3 yr warranty. Even gives instructions on how to remove module. (2) Slight oil leak, found problem with one hose. (3) Coolant leak somewhere. Just know it keeps going down slowly. (4) Turbo makes very loud whirly noise. (louder than it should).
    Okay so any advice would be greatly appreciated! :)
    feilofeilo Member Posts: 128
    Anyway the latest....when I put the signal to turn left or right....the tic-tac sounds stay on
    Replies to this message:
    It may be the HAZARD switch relay acting up - I have the same problem and another website suggested that replacing the relay is the answer. This relay is linked to the turn signals. The HAZARD switch needs to be removed to get to the relay. Haven't done it yet, so I can't elaborate on the "How To" just yet - sorry. Will post the result as and when I get to it...
    balzeebalzee Member Posts: 2
    I have 2000 Passat GLS with 90K miles on it. I recently started getting this weird problem. When I drive, all of a sudden, I get a jerk and the vehicle starts making a noise as if there is lot of stress on the engine and the engine struggles to pull at high speed. Also, in dashboard all the indicators ('D', 'P', 'N', 'R' 1, 2, 3) are in RED instead of just the 'D'. Any ideas...??
    altair4altair4 Member Posts: 1,469
    Sounds like the transmission is going into failsafe, protect mode....
    Thanks altair for the reply. So, is this a problem with transmission or something else?? Any guess how much it would cost??
    I think the best thing you could do is get to an Advance or Autzone store and get the codes pulled. They'll do it for free. Then post them here or check the web for solutions.
    There are some specific Passat forums that may be able to give you more help on this. It's never happened to me, so I can't tell you anything from firsthand experience.
    It's possible that the TCM, which lives under the front footwell carpets, is wet. But that's just a guess. Water intrusion into the passenger compartment of Passats is not an unheard of event....
    jdanos44jdanos44 Member Posts: 1
    I am the proud owner of a 2001-1/2 VW Passat. Has 73K miles and occasionally fails to start. It happens mostly when running errands and alot of start & stops. It may go 30 starts and crank as normal, and then bam! no start. Then I let it sit for 30 minutes and then it starts?
    Puzzled?!@#$% Never stalls when running. Currently at the VW dealer trying to fix problem and of course they are saying their diagnostics show nothing. Therefore unless they can reproduce the problem, they are ready to return the car to me. WHAT!!! How's this for service. Any help would be greatly appreciated.
    2000passat2000passat Member Posts: 2
    I have a 2000 Passat 1.8l 4-dr sedan with 70,123 miles on it. It is in the shop (again) for repairs. This time it is the ABS Module, 780.00 to repair. I am 2nd owner, bought with 24,560 miles in 2003 and have had 2713.31 in repairs since then. Anyone else with similar issues? It is frustrating. I'd like to keep car, but what else can go wrong? Any comments welcome. Thanks
    I have a 2000 Passat 1.8 l 4-dr sedan with 70,123 miles on it. BOTH drivers side window regulators went out within 2 weeks in July 2006. Then in March 2007 the front passenger side regulator went out. All together, Ive spent $1250+ repairing the windows! I'm scared to even roll them down at this point. If anyone does have info as to action taken against VW, let me know. And I've tried the advocacy line also, no help at all.
    krzysskrzyss Member Posts: 849
    "but what else can go wrong?"
    What oil are you using?
    Krzys
    Good one, Krzys!
    gw1998gw1998 Member Posts: 6
    Has anyone had any major problems with a 2002 Passat?
    harubhnharubhn Member Posts: 5
    My '02 had the coil packs fail at 18k miles, and the water pump failed at 40k. Both those issues, and several other niggling problems, were covered under warranty, but rendered the car inoperable for days. Fortunately I had another, more reliable car.
    The Passat now has 69k, and has been problem free for the last 20k or so.
    pheokcpheokc Member Posts: 2
    Recently, water entered my 2002 passat and i noticed that the drivers side was completely filled with water.I tried to drain it up, but the car wouldnt start.A friend told me to check the central locking circuit hidden under the foot mat of the drivers side.When i brought out the black plastic container, i found out it was covered with water.I cleaned it up and dried it in the sun for a while and tried to replace the circuit back.The car started and all the inner lights came up again, but the central lock will not work!Does any body know how i can make it work again?I cant drive out with the car anylonger because of security.Do i need to reprogramme my remote control?
    soli1978soli1978 Member Posts: 2
    Probably it is too late now and you already purchased the car. If you haven't, don't! I wasn't happy that I bought it and I will NEVER buy a VW again. The most horrible service, the most horrible attitude, and the most horrible reliability.
    djcdjc Member Posts: 10
    The knob snapped off my remote mirror control. Where is the bext place to order a replacement switch, and how do I remove the damaged one from the door panel?
    Online OEM parts can be found at 1stvwparts.com, drewparts.com. There may be others, but these are actual dealers.
    I believe that the door card must be removed to rep[lace the switch....
    3screwsloose3screwsloose Member Posts: 116
    122K mi on mine. I am getting ready to replace the axle shaft boots for the 3rd and 4th time. Started at 57K mi. Replaced the timing belt/tensioner/idler/thermostat/water pump/belts at 105K mi. No problemo! Still has orig frnt brake pads. Rear pads/rotors were replaced at 83K mi - rotors warped - now warped again - lasts about 25K mi before warping. Replaced flasher when turn signals went inop. Now occasionally the flasher flashes, but no lights while driving - just clicking. Hitting steering wheel, or pulling to one side helps. That is the only gremlin.
    jdhebert23jdhebert23 Member Posts: 19
    Well, I loaded a few posts in here about my 2001.5 Passat and how well the car has run since I bought it in March 2004 with 35k miles. It now has 113k miles and at the end of February the oil inter cooler, thermostat and belt-driven cooling fan :confuse: went out. It caused it to overheat as "STOP!" and "CHECK COOLANT" displayed in big, bold red letters on my driver display. $450 later, it's up and running. I thought it was strange that the oil inter cooler went out because I am careful about allowing the car to idle after "spirited" driving.
    Now, I have a whole new problem. A few months ago I noticed a fast-paced rattle, almost like a vibration, as I cold-start my car. The sound went away within seconds, almost after the fuel injection system did its job. Lately, I've noticed the sound takes longer to go away, and usually after I rev the engine a few times up to about 2,000 RPM's to get rid of the sound.
    I had my mechanic (who works for a VW dealer but does work for me on the side :blush: ) about it and he diagnosed it to be the cam shaft tensioner. I think it's a little weird that my car has only 113k miles and now I have to sink another $500 into it (which I still think is one hell of a deal) to get that fixed. Last year I had the front brakes replaced ($255), timing belt/tensioner pulley and thermostat ($450) and new tires ($450). Looks like I'll be putting a lot of money into it this year as well.
    Has anyone else had to replace their cam shaft tensioner this soon? I've never had to replace one in any of my previous 8 vehicles (only one of which was a 1990 Passat that succomed to a snapped timing belt). Any help would be appreciated.
    Based on what I've read on Passat-specific forums across the web, I'd say it ain't uncommon at all!
    quizzomanquizzoman Member Posts: 1
    Hey - My experience might be similiar to the fast paced rattle you are hearing. At about 100K on my 2000 1.8t Passat I started noticing a low-engine rattle that would come and go. It sounded like a tinging noise almost like the engine was loosing oil, but the oil was fine. I really started bothering me in places like drive through food places where I could hear the engine loud and clear while idling. When I would hear the noise I could push the throttle to about 2.5k and the noise would stop. Eventually, it got so bad that the low oil pressure light started coming one, which gave me a clue to what was up.
    Come to find out that the common sludge problem with the Passat was affecting my car. I ended up pulling the oil pan to find that sludge had completely filled the oil pickup screen for the oil pump. Which explaines why oil wasn't getting to the engine correctly. After replacing the oil pump the car is running better than ever.
    However, this process did involve a lot of work. For the oil pan to be removed the engine needs to be hoited on the half frame about 6 to 12 inched, but not totally removed. This is very dooable with the tools and a hoist. I might still have instructions on how to do it.
    If you have any questions or want the instructions or pics I took e-mail me at danpemberton@comcast.net.
    Good luck...
    lilengineerboylilengineerboy Member Posts: 4,116
    Has oil consumption increased at all? Sometimes valve guides can fail without lubrication, as can the the bearing surfaces and piston rings can wear. It pays to be very aware of what is going on with your vehicle, it sounds like you might have caught it when it was just an oil pump vs a new motor.
    patpat Member Posts: 10,421
    You know what would be great is if you would put together a CarSpace guide. You can include your pictures there and it will be available to anyone anytime.
    And welcome! :)
    I posted the original "A Few Bumps in the Road" post and here's a follow up:
    I got the car back from the mechanic this evening and he also had to replace the timing belt again because the timing tensioner hydraulic :confuse: leaked all the hydraulic fluid out which caused my timing belt to become loose. Thankfully we caught it before it jumped. Back to the cam shaft tensioner and the rattle: I asked him about the sludge and he assured me that my car is sludge free and that's due to my religious Mobil 1 oil changes that I give it as well as the 2-3 minute idle rule after "spirited" driving. I'm still mystified that all this is going on at only 113k miles, but all I can figure is that this is the consequence of my former mechanic not replacing the timing tensioner pulley when he replaced the timing belt and water pump. Thankfully my new mechanic is certified by VW (he is a tech at a dealer :blush: ) so he knows my VW better than my former mechanic. I should be good to go now. The whole job cost just under $1k. Add that to the cooling system failure I experienced in February, that's already $1,500 this year alone in repairs. Hopefully it will be the last of them. :sick:
    Another thing I noticed when merging on the highway this morning was that the turbo charger isn't boosting like it should. I can clearly hear the whine when it actuates but I don't feel the thrust I used to feel when accelerating. I spoke to my mechanic about this issue today and he is going to look at it. I suggested maybe a loose/busted vacuum hose because the engine seems to be producing a little "white noise" similar to the sound of a vacuum hose gasping for air.
    My question is this: At what mileage is typical to warrant a turbo charger rebuild? I've heard the K3/K4 is capable of being rebuilt but I am unsure of the mileage. Also, if estimated cost could be included, I'd appreciate that information as well.
    waid10waid10 Member Posts: 21
    I have a 2001 Passat. I went to a local Autozone to get new wiper blades. I bought some mid level Rain-X blades. The guy at Autozone tried for 30 minutes to fit the new wiper blades onto my car but could not find a connector that would make them fit. He said that their (Autozone's) selection of blades fit about 98% of cars, but they have had trouble with Volkswagen in the past. He said that I will have to take the car to a VW dealer to get new blades. The closest VW dealer is over an hour away. Plus, I just can't believe that I can't get new blades at an auto parts store. Anyone else have experience with this issue?
    I've never had problems putting blades on my car (01.5 Passat). Maybe you should consider taking it to another auto parts store. I've always been able to snap the old ones off and put the new ones on in less than a minute in the Wal Mart parking lot. I usually buy the Michelin brand wipers. They seem to perform very satisfactorily, and they are very reasonably priced. Can you maybe post some pictures of what your wiper arms look like? :confuse:
    pinhigh1pinhigh1 Member Posts: 3
    Help! The timing belt just snapped on my 2001 Passat 1.8T while driving on interstate 70mph / 2500-3000 rpm. Has 109k miles. VW dealer est is $2K if no damage to head; $4500 worst case. Edmund's estimates my trade value at $5K in a private sale before this issue. Have no idea of $$ value for scrap. Can should this car be repaired? Any / all input welcomed!
    Had it been changed previously? If it had been changed at the interval and still failed, I would expect some support from the manufacturer, especially if the service had been done at a dealer.
    You might also want to cross shop the price of a new/rebuilt motor/head from an independent VW place.
    then you have changed the belt 4k miles ago, haven't you?
    wipers
    If you have aero wipers then you need to buy set
    http://jobs.boschusa.com/AutoParts/PartFinder/partfinder.asp
    Krzys
    Thanks for suggestion.
    No hadn't yet been changed. A few K miles over the recommended change date...figures.
    Dealer indicates $2000 to $4500 to fix depending on level of damage, which they can't tell till they remove the head. But likely towards upper end. Used engines going for $$$ these days as well. And if I trade I've likely lost $4 to 5K in trade value. Ugly.
    That's why so many people recommend actually changing out the TB early on the Passat. The damage is devastating if it goes out on you. I think in order to better evaluate your situation, you need to reveal whether you can afford to take on a car payment for new/new-to-you wheels. Also, what is the condition of the rest of the car?
    I would suggest finding an independant mechanic who works on VW's to repair your car. The dealer is going to screw you bad with labor and not even give a reacharound. It's still going to be expensive though. If the car is in good condition other than the engine, it might be worth reparing. Ask around--surely someone know someone who can work on your car. At 109k, you don't have to worry about warranties, etc. If you live in Houston area, I can recommend a VW-certified mechanic.
    I am interested in changing my OEM antenna on my 01.5 Passat to a shark fin antenna. I wanted to know if anyone could tell me where I can find a multifunctional shark fin antenna that will catch AM/FM + Satellite. I heard the BMW 7-series uses a multifunctional antenna, and possibly the Touareg as well as some Audis. If anyone can help me with this, I'd appreciate it. I know it would probably be a lot of trouble to set it up, but I still want to know if it can be done, and how.
    One more thing--if there isn't a multifunctional shark fin available that I'm looking for, will the 06 Passat antenna fit on mine?
    iowavwiowavw Member Posts: 2
    Please let us know if you have fixed this problem. We own a 1996 Passat GlX Wagon and have the exact same problem. We have already spent 200 on what the mechanic thought was the problem with the starter and haven't gotten anywhere. Our new mechanic thinks it may have to do with the security electrics. What do you know?
    djkcpadjkcpa Member Posts: 4
    I noticed today the antenna mast on my Passat is broken. It's hanging at about a 90 degree angle. I just got it back from an oil change yesterday so I'm thinking it could have happened there.
    Anyway, has anyone changed one of these? If so, would you let me know what's involved in replacing it? Does the mast just attach to the base? It doesn't look like it should be too hard to do, but with VW's you never know. It looks like you can get the part for around $15 online. I'm sure the VW dealer would charge at least $100 for the part and installation so any help would be appreciated.
    Thanks in advance. :)
    cosmocosmo Member Posts: 203
    Just unscrew the broken one and screw in the new one. If you search the Internet, you will find a great variety of alternate styles.
    600kgolfgt600kgolfgt Member Posts: 690
    For 1998-2005 Passat 1.8T owners:
    I just had the timing belt service done on my wife's 2003 Passat GLS 1.8T at 66,000 miles. I decided to have this done early based on the fact that when I had the timing belt service done on my 2003 Wolfsburg Jetta at 73,000 miles, the plastic impeller on the waterpump was on the verge of disintegrating when it was removed. The same thing happened when they removed the waterpump from my wife's Passat.
    In preparation for the timing belt service (which was done at a private VW mechanic), I ordered the complete timing belt change kit from germanautoparts.com - which includes the timing belt, two sepentine belts, aftermarket water pump (with the metal impeller), tensioners, and thermostat.
    My mechanic recommended timing belt changes every 65,000 miles with the plastic waterpump (due to its tendency to disintegrate and possibly jam the pump - which may result in timing belt damage). With the metal waterpump, they recommend changing the belt at 90,000 miles.
    This next section is for 1998-early 2003 1.8T Passat owners (prior to VW's 2004 Technical Service Bulletin (TSB) concerning sludge)
    If conventional oil has been used in your engine for any length of time and your timing belt hasn't failed as of yet - I would highly recommend taking the car to your mechanic and have him check two items:
    1) Remove the engine's oil pan, and check the screen inside the oil pump pickup for any signs of sludge.
    2) Check the camshaft chain guide in the cylinder head for excessive wear. The chain guide is usually made of high-temp plastic and will usually last as long as it is properly lubricated.
    My mechanic has rebuilt many engines with damage caused by the oil pump pickup screen being clogged with sludge - thus starving the oil pump and the rest of the engine - and leading to a chain-reaction of events leading to excessive wear of the plastic camshaft chain guide in the cylinder head, which results in the camshaft seizing, and ultimately causing the timing belt to break.
    By the time the timing belt breaks, nine times out of ten the damage has already been done prior to the timing belt breaking.
    After the oil pickup screen and the cylinder head camshaft chain guide have been checked and/or cleaned/replaced, I would make sure that VW 502.00 spec synthetic oil is used and changed every 3500 (city driving) or 5000 miles. DO NOT DRIVE THE CAR beyond the 5000 mile interval between oil changes - NO EXCEPTIONS.
    HTH...
    shiposhipo Member Posts: 9,148
    Nice post. ;-)
    There is one sentence that I might be inclined to change. Instead of saying, "...I would make sure that VW 502.00 spec synthetic oil is used and changed every 3500 (city driving) or 5000 miles."
    I would instead say, "...I would make sure that you use an oil that is certified to meet the VW 502.00 synthetic oil spec (or better -- i.e. 503.01) and changed every 3500 (city driving) or 5000 miles."
    Best Regards,
    Shipo
    Thanks for the assist, Shipo - I knew there was an update to the 502.00 spec, the actual number escaped me at the time I posted... :shades:
    Got'cher back man. ;-)
    Best Regards,
    Shipo
    68orion6868orion68 Member Posts: 10
    i have '04 passat wagon 1.8. can't figure how to support car with jack-stands. points i choose deform when i lower the car on them. any help out there?
    zscottiezscottie Member Posts: 23
    I've got a 2005 Passat GLS 1.8T 4motion wagon. I noticed the "auto up" feature of the driver's window stopped working. Would this be an issue with a fuse? If it's a warranty problem, I have to take it to the dealer (I've got 10K miles left on the warranty), which isn't known for "great service" in these parts. :(
    Depending on what you are doing, and where you need to get to, I would use the suspension/sub-frame anchor points in the front and rear. I have used them quite successfully and safely.
    dave_ldave_l Member Posts: 1
    I've got a 1999 Passat with the trouble code P1136.
    Should I replace the O2 sensors or give the mass airflow sensor a shot first?
    Any help is appreciated.
    Dave
    colshubcolshub Member Posts: 1
    '00 Passat 1.8T sedan, 75k miles
    I've been having problems with water in the front passenger footwell. Sunroof drains are clear, battery box drains are clear. It only happens when the a/c is used. I took out the glove box to track down the source and here's what I found- If you look at the ductwork on top of the "hump", I see one white and one red lever, both less than 2" long. The water is coming thru the center of the red lever. Does anyone have any information on how to dissemble this so I can find out what's going on inside? It sounds to me to be a blocked evap drain but I see a trickle of water under the car after running the a/c. Just to be sure it isn't the evap drain- can anyone tell me how to clear them?
    thanks for your advice.
    brozhnikbrozhnik Member Posts: 172
    Other than an occasional OLF in cars I owned 20 years ago, and topping up fluids, I'm not experienced at automotive DIY. But with the 80K service approaching on my 2003 Passat 1.8T, visions of poverty are egging me on to trying whatever I can myself. (It's at 78,900 right now.) First weekend project: it looks like replacing the spark plugs is pretty easy, even for the average idiot (e.g., me). Here's a how-to page:
    http://www.ehow.com/how_110_replace-spark-plugs.html
    And I can buy four plugs for my car at Germanautoparts for about $11 a piece.
    Anything wrong with this picture? Anything that's harder than I think, or that I should be especially careful of? Should I let the mechanic do this? Or should I go for it? (I admit, it looks like fun.)
    PS While I'm at it, I'd think replacing the air filter would be easy. One question, though: what kind of filter, and where to buy it? For ordinary highway driving, not performance-minded.
    PPS If all this works, I might try the pollen filter. More on that later, though.
    Brozhnik -
    If you have a few simple tools like a rachet wrench, sparkplug socket and inexpensive torque wrench, doing some of the simple maintenance on your Passat can save you some money and be rewarding. For my 40K service, I bought OEM NGK replacement spark plugs, an air filter, cabin filter, fuel filter, and new Bosch wipers for the front and back of my wagon. I paid $120 at getcoolparts.com (buy more than $50, get free shipping).
    I had my dealer inspect the timing belt, change out the oil and filter (their filter, my 0w-40 Mobil 1 oil, to keep my sludge warranty in place), and chase down a engine code problem for another $116. I did all other checks, except those covered by my state inspection (brakes, suspension, exhaust).
    I have seen people quote over $400 for the 40K service - I figure doing the maintenance and service checks myself saved me about $150.
    There's a Passat specific forum on the web that has an information-base loaded with DIY advice, many include pictures. Worth the search, IMHO.
    BTW, the cabin filter is a snap to replace; the air filter, not so much. Like every VW I've owned over the last 25 years, you can expect to suffer some scrapes and cuts to your hands getting that filter changed out. If you have the 1.8T, you need to remove a heat shield (4 screws) and undo 4 clips to gain access to the air filter, but it's still a tight fit.
    I'd stick with OEM or similar - not a K&N filter. I think I used a Mann filter (made in Germany) last time.
    vinay_svinay_s Member Posts: 4
    I have a 2000 Passat 1.8T which has done about 73K miles.
    I bought it used at 33K miles and I've not had much trouble with it till now. However I have three concerns for which I seek advice/opinions:
    1: The last couple of months I have noticed a jingling noise coming from the front suspension. It sounds like a bunch of coins and increases when I drive over speedbumps or rough pavement. Took it to a Meineke shop which said I needed new shocks and struts (Approx $600 for Front only) . I then took it to a VW dealer. They said they could not find anything wrong with the car and advised against changing the shocks/struts. The noise is still there...any thoughts?
    2: I have read and heard that the Passat needs to have its timing-belt and related mechanisms changed around the 75K mark. IS this true?. My car is not showing any signs of needing this repair. what should I lookout for?
    3: On one rare occasion that I had an oil-change done outside the VW dealership ( at Lube Express), the mechanic warned me that my car has some sludge accumulated and recommended a 100$ "clean-up". When I checked with the VW dealership during my next oil change, they mentioned that VW does not recommend any clean-up and if the car was not giving me any trouble I should leave the sludge alone. Any thoughts??
