Jon
The "rears-before-the-fronts" thing is a documented Passat experience, but may not be universal. You may have noticed that the rear wheels collect alot more brake dust than the fronts.
Some have hypothesized that the rears are "under braked," meaning they have a pretty small pad on the rears. Others have suggested the car has a brake bias that favors the rears under light braking. Pick one.
Could you describe the conditions under which the car is driven? City? Highway? Is your wife an easy-going driver?
1 1/2 yr old 2002 Passat GLS 1.8T manual transmission, with only 7,500 miles on it. Have had SO many problems with this car and many trips to the dealer. Have spent ALOT of time in rentals.
Problems have ranged from the ignition coils - all were replaced TWICE now, and could possibly be going on third time....check engine light stayed on this week and car has been hesitating and sluggish. Have had emissions problems (2x) cvboot/axle squeaking in cold temps- that took forever to fix..sounded like the suspension was shot, ashtrays falling out when hit bumps, windshield wipers that don't clear the windshield and scrape, headlight and license plate lamps burned out already and don't forget the heat shield recall. And keypoint...it only has 7500 miles!!!!! I wonder if the car will make it to see 10,000??
Am thinking of selling it this spring, but want to check into lemon laws first. Any suggestions would be greatly appreciated. Thanks!
http://autopedia.com/html/LemonLaw/MN_lemonlaw.html
Passat but I can account for mine. We have 25,000
miles on our '02 1.8T GLS wagon. The only problem
we have had is one burned out headlight. It gets
driven hard in Houston's hellish traffic and its
well known bad streets. It is as tight as new.
It is much more enjoyable to drive than any of the
previous 5 Accords that I have owned. Also more
trouble-free as well.
It is my first VW and it will not be my last.
Great dealer sevice for oil changes as well.
It can best be described as a slipping then re-engagement(a lurching)of something in the drive train. It varies in severity, but yesterday while pulling in our driveway it was very pronounced and actually felt like someone rear-ended us at a very low speed. The sensation was actually jarring.
Steps to reproduce:
1. Decelerate to a very low speed (< 5 mph) with the brake applied,
2. Release foot from the brake pedal
3. Then accelerating again. (gently as if to move further up the driveway for example).The re-acceleration may not be required; it’s just what we’ve noticed so far.
It feels as if something has disengaged and then re-engaged. The re-engaging can be quite harsh. As mentioned above, yesterday for the first time it seemed more clearly identifiable coming from the rear-end.
Whatever is happening I believe now almost always happens, it’s just that if the brakes are constantly applied then effect is very subtle.
We brought it in for serive and the problem got better. But it's coming back again althought not quite as pronounced as it was.
I read a post on the web about a similar problem with the Passat W8 during a test drive and have heard similar things from casual discussion with Audi Quattro owners.
Anyway I have this sense that their maybe an underlying problem out there and I wanted to start a message thread for others to benefit from and/or to see if there any thoughts on the problem.
We've had some cold up here in Northern Mass. The proper "appears" to happen less when it is very cold.
Thanks in advance!
Jeremy
I guess it wouldn't hurt to hope they don't find sludge in the engine...
Jeremy
Anyway, this is going to be my winter car. My 1st car is a Miata(!). I'm guessing that I will only put 5-7k miles on it a year but I want to make sure the car last.
From reading the previous posts, I gathered that I should have the brake lines flushed(?). I got a 30-day dealer warranty. What else should I do to make sure my Passat makes it thru this winter and the next? Let me know what you recommend. thx
I but the new bulb, and when I get home to install it, I discover that the T-handle that pops out under the hood when you pull the hood release inside the car has broken. You pull it, and it's not connected to the device that disengages the hood latch! I used a screw driver to disengage the hood latch and replaced my bulb.
I compared the T-handle on the 99 Passat with the one on our 2003 Passat, and it appears that on the 99 passat one of the fork-like tines that engaged around a pin has broken off.
So it looks like I'll be making a trip to the dealer for a new T-handle. I have a feeling I'll have to get more than the latch pull because I bet it's not sold as a single part.
Anyway, I am wondering if anyone else has had problems with the T-handle and what it cost to replace.
Regarding other suggestions:
1) Oil and filter change unless someone can give you positive proof that it was done recently.
2) I'd recommend synthetic oil for the 1.8T, in the viscosity recommended in the owner's manual.
3) Make sure that the turbocharger's oil supply lines have the correct heat shield. Early models did not, and this allows the lines to clog, essentially starving the turbo for lubricant.
4) Review the original warranty and any other warranty you may have. VW has a 105K mile change recommendation for the timing belt and tensioner. But if you are out of warranty, get this done ASAP (broken belt = destroyed engine, since the 1.8T is an interference engine). I'd also get the water pump done at the same time, since you'll save labor in the long run. BTW, this is not an inexpensive job.
5) There was a recall on the rear wheel liner. Make sure this was done...it's to protect the fuel filler in case the right rear tire self-destructs from a blow out.
6) There was a recall on the ignition coils, but I'm not sure that your year is affected. Call VWoA with the VIN and they should be able to clarify that.
This is probably not what you want to hear. Just my thoughts.
Here's an edit from Click and Clack on the topic:
>>I have a 1998 Audi A4 with 30,500 miles. I was recently told that the left front control arm has to be replaced and that the right front control arm will soon need replacing. I was told by the dealer's service representative that this is normal wear and tear for a car after four years. I have a hard time buying that. What do you think? -- Tina
Ray: Well, he would have been telling the truth if he had said it's normal wear and tear for THIS car.<<
PS: The Audi in question and the Passat share the same front end design.
Hey, I haven't dropped off the check from my bank to the dealer yet but I have discovered that I can't open my trunk. I didn't notice before because weather was below zero/snowing & I never thought the trunk could be a problem. Is this a common glitch w/Passats? I told dealer that I would bring the car by tommorrow so they can fix it & then I would give them the bank check once it was corrected. I can't believe they would sell me a car w/broken trunk & not tell me. That's kinda lame.
Enjoy your ride and don't let these boards scare you.
Hey fish8, your comments are dead-on. My wife's Honda Accord has been bullet-proof (until this week). Engine computer is muerta, $800 plus labor. I'm finally cashing in on the extended warranty I bought. And if nothing else goes wrong before it expires at the end of this year, I lost money on the deal!
Are you dealing with a VW dealer, or other? Do you plan to have the work done at an indie shop or VW dealer?
Can't help you on the trunk lid thing. Perhaps someone else here can comment.
Hey, I also got a good reference for an independent VW dealer too. They are near-by. I think that's gonna help a lot.
I think the warranty reverts to 50,000 miles for all other second owners. I'm only working from memory here, so don't take this as gospel...maybe somebody else can pipe in or, and this might be the best idea, you should call VWoA. That's the only way to be sure. Or even call a local VW dealership and ask the service writer. They might be able to tell you the real deal.
Thanks in advance.
I am fortunate to have an excellent VW dealership where I live. The sales and service staff are very courteous, patient, and knowledgeable when it comes to dealing with customers.
Now for the juicy stuff - starting at the 40k service, the car needed new control arms ($800)and a new head gasket (warranty) Then the oil oil seals blews blew at 43k (which was 6 weeks ago). The seals were covered under warranty. Then the seals leaked 3weeks ago, and had to be replaced again(warranty). We took a trip in the car, and when we came home, the check engine light came on, and guess what, the oil cooler and one of the pistons had to be replaced ($800). When I called VW of America for some kind of $ help, they didn't even have a record of the car in their system (even with the VIN number) and they called me back 2 days later to say that VW will not help at all. When I asked the girl on the phone if I could speak with someone else, her response was, "this is the final decision of VW and I am empowered by our Chairman and our response is final" - Then she hung up on me.
At this point, I called my dealer service mgr and got the manu. rep, called him, told him all the money I just had to pour into the car, and he knocked off $200 from my latest bill.
To date, I have put over $3500 in this car (which includes tires and brakes) at 47k miles. I have a 98 Nissan Maxima with 82k miles and all I've ever done is put oil in, 1 set of tires and brakes. That's it. SO LONG VW...SO LONG GERMAN CARS...HELLO HONDA OR NISSAN!
Oh, just on a whim, I asked the VW dealer what they would give me for a trade in - $11,500! The car was $29.5 new and has less than 50k on it!
I can tell by your post that your are fuming!!!!
Hope everything works out for you.
I did get my area manu. rep to pick up the cost of the parts, thus I only had to pay the labor ($450). They also charged me $90 to plug the car into the computer. I have to call the srv. mgr. back.
I am looking at a Volvo tomorrow and a Honda Pilot. We'll see what happens.
What do I do first?
The hard braking hellped for a week or so but the squeak is back worse than ever. I'll be calling the dealership again but wanted feedback from anyone else who might have experienced this.
Also, I notice an intermittent humming sometimes from my right rear wheel after driving and parking the car. Anyone else experience this?
You just use a pair of needle nose pliers to pull off the end cap (I suggest wrapping some cloth or a paper towel around it, to prevent marring). I seem to recall that they needed a pretty good tug to get them off. Get a good grip and just pull!
Then you will see on one end a small metal tab that's bent to hold the original rubber in place. Slightly unbend that tab with the pliers to release the rubber, then slip out the old rubber. Slide in the new rubber, cut off any excess, re-bend the metal tab, and slip the end caps back on. The job's finished!
8/27/02-replaced coil #4
9/30/02- replaced passenger side headlight
12/9/02-replaced coil #2, replaced left front low beam harness
12/10/02- replaced coils 1+3 assured us we had all new coils
2/21/03-replaced front headligh wiring harness and made new grounds for low beams
4/7/03 replaced coil #1 again! assured us we had all new coils again!
5/14/03 replaced headligh bulbs
10/9/03 replaced passenger headlight, driver fog light, rear passenger and driver front turn signals
2/10/04 replaced coil #3 again! and new catalytic converter
My dealer also knows me by name, as I have been in there WAY too often. I also experienced multiple coil problems...supposedly, I now have all new ones. I have had emissions problems twice. I have had a loud squeak over the right tire - spring related.
At first, the dealer was very accomodating and made repairs swiftly. Now, they are a living nightmare to deal with.
I too feel my car is a lemon. I know many others who have Passats and have had no problems whatsoever.
I am getting out of mine, only because it was involved in a car wreck - $6200 worth of front end damage....$4200 in parts alone.
Love the look of the car, but just don't know if I can trust it anymore. Am looking at Subuaru Legacy's and Toyota Camrys. Toying with the idea of a 2004 Passat, but am VERY gunshy based off the above problems.
Good luck with yours.
2001 Passat 1.8T Turbo; Manual Tranny
39,500 on the odometer.
Maintenance, except for what appears below- just the standard oil changes, tire rotations. Nothing out of the ordinary. Ignition coil pack and rear fuel liner replaced, per specs of VWofA recall.
History:
2/11/204: MIL on; "Emissions Workshop" displays on console.
2/12/204: Per Gossett VW in Alpharetta GA- a vacuum hose has failed. They show me where the hose is clearly compromised where it mates with the engine. Hose is basically a non-decsript rubber issue, diameter no larger than your pinkie-surrounded by a fabric webbing. Fault is not a fray as I would expect, but appears to be a clean cut right next to the securing clamp. No moving parts anywhere nearby to cause rubbing/abrasion.
Advisor quotes me $400 for parts and labor. I keep pressing the advisor that I wanted only the failed hose replaced, not both (there are two such hoses) "Well sir, you never know when the other hose is going fail, besides- it would save you only $50". Advisor also points out rear passenger brake pads where in the initial phases of going into the rotors. I assumed the rotors could be rotated and pads replaced. Nope. Both have to replaced. VW's OEM rotors can't be machined. Another $400. Dealer gives me a loaner, with work to be completed the next day.
2/13/2004 Noon: Car ready as promised. Invoice details two hoses, five clamps, a PUMP, 2 bulbs (?); 1 disk brake, 1 brake lining. Original service advisor was not anywhere to be found. Paid bill, drove away.
2/13/2004 1:30PM: After returning to work - popped the hood (sorry, "bonnet") to discover NONE of the five clamps had been attached.
2/14/2004: Left message in the original service advisor's voice mail to pull my records and call me on Tuesday.
In summary- I feel it is *I* who has been "hosed" here. Clearly, work was done that did not need to be done, and in the case of the clamps- steam is coming out of my ears. The entire vacuum issue was built up only to build up a bigger invoice. My CC has been pinged $897.00
Caveat to those about to come out of warranty: find a reputable, independent VW technician.
I'm not even going to waste my time with VWofA. From what I have read on these boards, they are about as effective as catching water with a sieve. I'm going to give Gossett fair chance to resolve this. If resolution is not to my satisfaction- I'm going to file a grievance with AMEX. Think I have a chance? Anyone else have a similar story?
1) My right side mirror cracked.
2) When braking the car feels like it's pulsating.
3) When idling the car makes a noise like a spoon hitting a pot continously (sorry, only way to describe it).
Now, a few days later only the brake-pulsating feeling is happening. Does anyone have any idea as to what is causing problems 2 and 3?
Carrie ~2003 1.8T GLS Passat AT, Candy White w/ tan leather interior~ carrying precious cargo Aidan (Graco Snugride infant seat) and Alyssa (Graco Turbo Booster seat)
I have been carefully watching these boards for common problems etc. as well as the Jetta/Golf and also the Honda and Toyota.
What's interesting is perception vs. reality. Honda and Toyota seemingly have these "get out of jail free" cards when it comes to shirking the wrath of quality issues. A good example I believe is the 99 accords with the tranny issues. I still think quality control is better than VW et. al. but I beleive in general it is on the decline in the interest of continuing profitability.
OK so the Passat is built in Germany, my question to you well educated folks: is it reasonable to assume that, excluding the coil recall issue, i)the quality of 2001.5+ models exceeds that of the 1998-2001 models and if the answer is YES ii) you would strongly consider the redesigned 2005 passat (perhaps build year #2 which works some of the kinks out, make that 2006) based on your experience with the 2001.5+.
PS: Could be viewed as a dumb question given that, over time, any model will improve if made long enough.
I am taking the long weekend off from my new, used '98 1.8t Passat w/84k miles. I took it to the dealer to change timing belt/water pump/tensioners and 90k(?) maintenance check and the new factory replacement timing belt was faulty!? So, with the car tore all apart, they told me it would take several days to get a "good" timing belt delivered. I got a free rental so life isn't so bad - Toyota 4 runner.
Oh, they told me the the rear brake pads are real thin. Since, I was as already shelling out $750 for timing belt & another3-400 for 90k, he told me I could probably get-by for a "little" longer on the brakes. I've done my research. I know the rear brakes go first on Passat & pads & rotors are $450 at the dealer. So, I wasn't real shocked. I would have prefer not to hear it though. Oh, but the dealer did say the car was in good shape otherwise!
That's not what bothering me. What's bothering is my crazy alarm system. I open the door w/key cause I think my remote battery is weak and then alarm goes off when I try to start it! That's bothering me. Everything else, I strike up to maintenance. What's up w/the alarm systems. Should I just have them disconnect it or is it an easy fix?
