Lincoln LS Power Windows
(2002 LS, owned for 11 months). Before buying my vehicle, I read messages on rear power window problems but decided to buy anyway since some messages spoke of future fixes/recall. My story: used the left rear window and then it wouldn't go up or down. Since I was on the road (8 hrs from home) I took the door apart to take a look and see if I could get the window to close. VERY POOR DESIGN! Cable had come off the pulley assembly and wrapped itself around the motor/regulator and could not be unwound. Fortunately, it wasn't raining, although the temp was 45 degs, and at 70mph, it was a very noisy and uncomfortable ride. I was pissed! A car of this caliber shouldn't be of such poor design! Luckily, I found a dealership 2 hours later and they fixed the window in a little over an hour. How “fortunate” that they had the part on hand... Hmm?
What is being done to service and replace this KNOWN DEFECT? Probably not much and the company is just buying time until warranties expire. LS owners beware!!!!! If you’re not using your windows you’re bound to be surprised at some point down the road (I’ve only used mine a dozen times). I will contact the BBB to file a complaint.
So, all I can add is this story. A cop friend of mine has a Cadillac Deville. I don't know who the subcontractor is who makes their power window mechanisms, but his rear windows have both failed 7 times now. SEVEN TIMES! He finally had to take them apart himself and screw them into the up position making them inoperative, because the car is now out of warranty, and GM won't fix them anymore.
I'll tell him to file a complaint with the BBB. Obviously, ohm, you have a low tolerance for machinery. One failure, one fix? In an hour? What more do you want? You weren't walking! Cars are machines. They break. Actually, it's a miracle they run at all! It's mildly annoying when they do, but if the dealer can take care of me in an hour or so with no hassle, I'm a happy customer! If you can hate your car over this one issue, I don't know how to help ya.
Article No. 02-7-3
04/15/02
ELECTRICAL - POWER WINDOW - REAR POWER
WINDOW INOPERATIVE - VEHICLES BUILT THROUGH 1/22/2002
LINCOLN: 2000-2002 LS
This article is being republished in its entirety to update the vehicle applications and the parts involved.
ISSUE
The rear door power window regulator may become inoperative, leaving the customer unable to raise or lower the rear window glass. This may be caused by the rear window regulator malfunctioning.
ACTION
If inspection and diagnostics lead to an inoperative rear window regulator, install the revised design window regulators in BOTH rear doors per the procedure in the appropriate model year Lincoln LS Workshop Manual, Section 501-11 (Window Regulator - Rear Door Removal and Installation).
Part number Part name
2W4Z-5427008-AA Window Regulator - RH
2W4Z-5427009-AA window Regulator - LH
This window problem has been magnified greatly by the fact that the LS has been remarkably trouble-free overall since it's introduction. My '00 has 60k miles and has not had a single problem other than one window failure. My experience has been typical, and I speak as a member of an owners' club with over 1000 members and a two-yr. veteran of the Edmunds Lincoln LS discussion board.
Pretend you're a tester and your job is to test these windows. What would you do? You'd exercise them to death to make sure they hold up for years in the field. And they did - just fine. No problems found. Would you have thought to NOT use them and let them sit in the heat for several months? Many took months or even a year or two before they failed initially. This was simply not something any normal test procedure would have found. They tried a redesigned plastic part which did not fix the problem so they took the final step and went with metal. That's just not something you can do in a month or two.
Annoying? Yes. Poor dealer service in some cases? Absolutely. But put yourselves in Lincoln's place and say (with a straight face) that you could have done better. I don't think so. You just have to chalk this one up to Murphy's law.
ls1bmw0 "Lincoln LS" Oct 20, 2001 5:52pm
Apparently that's the last post I read.
If ride is important, and your roads aren't as smooth as glass, buy an LS without the handling package. Quick way to tell is the 17" wheels. You want the base package with the 16 inchers. Base cars also have minimal chrome trim on the front and rear bumpers.
The V6 has only adequate power but gets good mpg. The V8 is much smoother but fairly thirsty. If mpg isn't a concern then the V8 is the way to go.
Most of her driving is 60%/40% city/highway, and the car's computer reads 18.8 to 19.1 average MPG. I reset the computer to clear it's memory before we go on vacation, which is mostly highway driving, and we average 26-26.5 MPG. Seems pretty good to me.....
The V8 is rated 17/24 EPA. Based on my experience with EPA numbers 17 is about what I could expect (I drive mostly around town). That's what I was getting with my previous car and it was killing me, especially paying for premium, but maybe that's just me.
Nomoregms should go to MSN's Carpoint and read Danial Heraud's review. He seems to be the most impartial of the reviewers I've read.
Speedshift's advice is sound; if smooth ride is of prime importance you will be happier with a car without the Sport package. The LS has been criticized for road noise; it's the price we pay for the high performance suspension. But, if you find a good deal on a Sport model, you can smooth, and especially quiet, the ride by putting the right tires on it.
Our experience is that there is little difference in fuel economy between the V8 and the V6. My V8 gets 23-24 mpg in mostly highway commuting, 26 on the open interstate. "Adequate" is the word for the V6 power, although aftermarket exhaust and upgrading the air intake with the '02 part makes a significant difference. The V8 is just a blast; not really a drag racer, but a monster from 60 mph or so.
Whoops, there I go. Sorry, forgot this is about power windows. I'd recommend this car to anybody. This ends this commercial message.
Dozens of different polymers and polymer compounds (plastics) are used in every vehicle used today Each "plastic " used is picked for its specific properties/combined with a specific part design and tested in the specific environment it will see. All of the automakers test in the southwest for extreme heat conditions, and all have initial rules of thumb for max temps in different parts of the car ( the interior is 235F for example). If a part is made of a material not up to these temperatures, distortion or failure can occur. Excessive design stress aggravates the situation.
These failure were probably caused by a poor part design or material selection that was not sufficiently tested - not by "plastic"
These days FoMoCo are all feeding voracious purchasing organizations that are measured by what dollars they can squezze from their component suppliers and in their zeal engineering and quality are often compromised .
IMHO this is one reason why Ford has gone from having more cash than they knew what to do with to struggling.
BTW, my rear power window falied 1/2 way up on July 4th weekend after 1 hr parked in 95deg heat.
LM was very responsive, especially after I told them that ther $40K BMW beater would be driving around with silver duct tape holding the window shut.(my 2000LS was out of warranty but they fixed for free)
we can all guess the rest... which has a shorthand version as well, "lowest bidder."
regardless, if the window on the sunny side is jammed in a warped slide and the shaded side isn't wrecked, it's an engineered failure that needs correcting.
I'm not sure what it looks like in there but the offending part could be made of nylon,polycarbonate,acetal,PBT,PET or various alloys and reinforced compunds of the above depending on many things we don't know.
The LS probably went to an interim plastic part as a means of containment action until a permanent solution could be found. Remember that the fix has to tested and new tooling set up. This is a common approach used in the automotive industry.
it's cheap to mold plastic, and there are less steps in production. metal costs more.
At one point I could have quoted the cost difference between a plastic slider and a metal reinforced one. The cost difference is not significant. I am sure Ford would not have initially gone this route had they realized the potential for this magnitude of failure.
I did mention it would be dumb.:)
seriously... I have two keyrings and two control fobs in my pocket, and occasionally one's keys will push another's buttons.
unseriously, that usually happens when I put on my camoflauge suit and am winched up into the chopper.
