I like to clean it out after offroading and sucking in dirt, so the re-usable ones are nice.
-mike
About the Tornado, best not get me started....talk about snake oil!
For what its worth. I was also having a slight rattle in my steering box when doing some offroading on washboard and very rocky terrain. I had the tech check that, and as with the belt, this was an early production issues and has since been fixed with a different steering tube assembly for the newer vehicles. They can't fix the early production issues because of the way that part is installed...which i assume is permanent. Iv'e been told the slight rattleing noise is normal and that no harm is being done. We will see about that. I'll let you know if I have any more problems with that.
Hope this helps. Take care.
Anyway, here are some issues I have to address to my service people. (1) Anti-Corrosion wax application, (2) Poor radio reception for both AM and FM, (3) Non-working horn (4) Rattle in the center console area, (5) Adhesive tape for the body cladding is peeling off.
BTW, I bought mine in December. I don't think we have the early production Sorentos. The Korean were driving this for almost a year before we do.
dlb14frost - Mine isn't like that. Most FM and all AM stations are very poor like without an antenna at all. I will check it out tomorrow.
-- Dave
To remove the radio, all you have to do is open the little drawer above the ashtray. You will see the inside edges of the trim (phoney wood on EX, black plastic on LX) that surrounds the center stack and incorporates the A/C vents. Use a flat bladed screwdriver to pull the trim toward the rear of the vehicle. Once you get the bottom part of the trim free, just work your way up, but be careful not to lose the little metal clips that are mounted on trim. Once both sides of the trim are off, you can see the 4 screws that hold the radio in the dash. Just remove them and pull the radio out. The antenna lead is inserted into a socket at the rear of the radio. It should seat in the socket with a "click".
BTW, my Sorento SERVICE manual shows a power antenna mounted in the rear quarter panel (fender). The electrical schematics also show a power antenna connected to the radio. Seems like a good idea since the Sorento OWNERS manual says to remove the antenna mast (rod) before going through a car wash. (Kind of a pain, but I always do it.)
-mike
Right now I have no complaints about my Sorento. I hope something works out for you!
What was the nationality of the former owner?
lok888- there are several items in the SERVICE manual that are not specific to the North American market. I guess that other markets might get a retractable antenna, but not us. FWIW, retractable antennas and New England weather don't mix all that well. I replace the one on my Saab every couple of years when the teeth on the rack take a beating from trying to retract an ice coated mast. I'm with you on in-the-glass antennas, my '71 Firebird (lapse of judgement in early 20's!) had one and reception was no worse than an externally mounted antenna.
brooklyn1951 - I had retractable antenna (on A-pillar) on my '91 Toyota Corolla and power antenna on my '93 Honda Accord. Both had good radio reception except I replaced the power antenna mast once (not the motor). I have no experience with in-glass antenna. But my brother's '00 Civic has no problem with it. I think the fixed radio antenna (Sorento) has the best reception beside the appearance issue. The roof mounted antenna and those XM radio antenna are very good looking.
Michelin has always been a French company though I think now the French gov. has a hand in owning a percentage. But the tires that they put out have been rated as very good.
I beleive that many Sorrento's were coming in to dealers with the tires over inflatted and after getting down to the proper psi most vibrations went away.
Yes, but I believe that most of the products Michelin sells are manufactured outside the country.
So tell me this. Why would Kia make the rear compartment cover out of some sort of fiber/composite material? Turns out, it warps and sinks into the compartment very easily! I went camping this weekend and had some problems with rain. All of our tents, sleeping bags, etc were soaked. Well, we put all the wet items into the back of the vehicle...like anybody would. Well, seems that the rear compartment cover (floor) soaked up some mosture and warped. Now I have a compartment floor/lid that is sunkin about an inch! I am not very happy about this and am talking with the dealership as we speak.
Has anybody else had this problem?
It's called discussion and people add to it. With a little luck, we all learn from the interaction and enjoy the experience.
My personal theory is that the wet materials in the rear of the truck and the high heat inside the vehicle (when it was sitting in the sun while we rode our bikes) caused the moisture in the materials to vaporize and seep into anything that would absorb it. With all the wieght of the camping gear, food, water, etc...I would say I had about 200-250 lbs...sitting on the floor, this caused the warpage.
When we opened the doors after our ride...I was amazed at how humid the air was...and how hot it was. I did not realize the floor had warped until we drove home that night and I removed all the camping gear.
And just for reference, I have gone camping in the Sorento with the same gear about 15 times since I bought the truck, and never had this problem before.
The plastic hidden tray beneath is not warped.
Oh, and by the way. My dealership is replacing my front Michelin tires because of out of roundness issues and a failure to balance them. I've had all 4 tires rebalanced 2 times. And it seems like each time they rebalance them, the shaking at speeds of 75mph and above gets worse. Hopefully the replacements fixes the issue. Because when the truck was new, I could drive at 90-95 mph with no problems at all.
Specifically I am now getting the vibration at around 75-80 miles an hour that didn't appear before - I have rotated tires, etc. but am concerned having read about drive shaft issues, other Michelins being out of round, etc. My car does sit at the airport for 3-4 days at a time and wonder (almost hope) it is the tires.
Seat tear - I have the leather package in the Sorento. The passenger side seat is tearing in the bottom cushion - as it has opened up, it appears there is an extremely thin layer of leather with a thicker vinyl backing. The KIA dealer is replacing, but I am concerned about how fast the seats will deteriorate over time.
Finally, my rear hatch occasionally will not open after using the keyless entry (all doors are unlocked, but it will not open.)
Has anyone else seen these issues?
I drove my Sorento EX 4WD with TOD (just over 7500 miles) into a parking lot yesterday afternoon. When I made a turn at low speed to a parking space, I could hear a noise and felt a variation. It sounded and felt like I was engaged the 4Lo when making turn. I checked the switch and it was on AUTO (not 4Lo). It was a first sign of trouble.
Then I went home and went out again after dinner. It was even worse. I was checking my Sorento by switching it into 4Lo. I drove some distant and stopped. Man! I couldn't switch it back to AUTO. I tried so many times by shifting it in "N" and turned the knob from "4Lo" to "AUTO". It was stuck in "4Lo".
I drove it around the blocks at very low speed. Then I stopped the car and somehow it allowed me to shift it back to "AUTO".
I drove my Sorento to the service this morning. By the way, they replaced the mast antenna (for poor radio reception) and ordered a new horn rely. The horn was not working most of the time even when pressing the PANIC button on the remote.
In the meanwhile, they offered me a rental car while my car is in service. Of course, it is a 2001 Kia Sephia. The horn rely will arrive tomorrow and they are still in the process of diagnosis what is the problem. I don't know what is wrong and I hope they will fix it by the end of the week.
Oh! This 2001 Sephia reminds me my 1992 Toyota Corolla DX. I sold it almost two years ago with 180K miles on it. This car looks like a base model with no power windows, locks or mirrors. Just 4 wheels & tires and 4 doors. My personal opinion about Kia is the 2001 was a year of change. I would say some 2001 & prior Kia vehicles are like few years behind most Japanese cars until the 2002 model came out.
I thought I read someone had a similar problem with the 4WD system. He had to call to tow his Sorento.
Also, I have been getting the same vibration between 75-80 mph. At first I thought it was coming through the steering wheel mostly but now I am convinced that I feel it most in the floorboards.
I haven't lost my faith yet but it isn't a good feeling to hear other people experiencing the same exact thing as me. Keep us posted if you get anything solved.
I have 6200 miles and seem to be experiencing my problems a little earlier than some. Definitely not good.
lilac044 - I think you are not the only one with the rear hatch problem. Did you bring this to the service? It looks like something wrong with the rear hatch lock.
