Heater not working properly?
                    Today, temperature was near freezing.  Set the heater to 89.6F and the fan speed to max.  All I got was slightly warm air (engine fully warmed up).  Something is definitly wrong with the heater.  Any idea what might have gone wrong here?  Thanks.
Year, make, model, engine, auto/manual climate controls will make it a lot easier when trying to figure things like this out. Some of us view all topics so we don't see exactly what thread coming from.
I checked the coolant based on jgmilberg's advice.
It looks fine (I changed it this summer). Can anyone explain more about sticking blend door to the heat core? Can a bad thermostat cause this problem. The car now seems to warm up slightly faster than before but this could be just my imagination. Thanks in advance.
The blend door is the door that shuts the A/C core from the heater core. Door oopen, cold air.
Door closed, warm air.
Your vehicle has an electric blend door actuator.
The electronic blend door actuator is located in the side of the evaporator case assembly on the driver's side. The actuator control the position of the temperature blend door based on a low current signal from the FATC module. Internally an electronic circuit accepts the signal and positions the blend door with a small DC motor. Also included is a blend door position potentiometer which provide feedback to the FATC module. The blend door actuator operates based on input information of the temperature setting lever setting signal. The in-vehicle, ambient, engine temperature sensor signal. And this A/C control module actuates the DC motor according to these signals, also controls the motor operation to adjust the air mix/blend door opening.
A bad thermostat could cause the problem too, but if the temp gauge on the dash is saying that the engine is running at normal temp I would not think the t-stat would be causing the problem.
If you only have 24k miles on it can you take it to the dealer and have it serviced under warranty? I know that in certain countries they have different factory warranties, that's why I ask. Is that 24,000 mile or kilometers? Here in the states everything comes with a 3 year 36,000 mile factory warranty. Even with that you are on the edge of the warranty just on the age of the vehicle, so if you can get it in ASAP before the warranty runs out, that is if it is still applicable.
Keep us informed on what you find out.
Unfortunately, Hyundai warranty in Korea is way too short compared to what they offer in the States. Engine and transmission are covered for 3 years or 25K miles. I believe bumper-to-bumper warranty is even shorter than the powertrain warranty.
In any case, it only cost me $32 for the replacement part, coolant and labor so I am quite happy. Thanks guys for your inputs--helped me greatly.
Oh well, the main thing is that it's fixed and you are warm while cruising around town.
Although the heater has worked right after the replacement of the thermostat, it was back to square one the next morning. Also, the temperature guage showed that the engine was operating at the normal operating temperature all the time (before mistakenly replacing the thermostat and coolant).
I am going to take the car back to the mechanic next wednesday. He said that he is going to replace the heat core this time. But now, after reading Opatience reply, I am a bit concerned. Will replacing the heat core cure the blend door problem? I hope he doesn't replace the parts that do not need to be replaced.
The blend door senario seems much more likely.
I think it's the blend door, but don't discount a plugged heater core. Engine blocks are made from a sand casting, and sometimes (yes it does happen) all the casting is not removed. It can end up in an area with small orifices (or tubes in a core) and plug it up.
Is there a valve in-line on the hoses? I haven't looked at my '02 sonata but most car manufacturers have a vacuum actuated valve to allow coolant flow. It could be just a case of a vacuum line fell off or has failed, any chance a new stereo was put in?
Does the air-conditioning work correctly? ie set the temp to 70 and it stays there, that would eliminate the internal cabin temp sensor as a fault.
The electronic [NOT VACUUM] blend door actuator is located in the side of the evaporator case assembly on the driver's side.
There is no vacuum actuated valve in this system.
There is no vacuum line to come loose on this vehicle. It is electronically controlled.
So, the options for the problem are........
The blend door actuator connector has come loose.
The fuse has blown.
The blend door actuator has a problem.
Or....... The Electronic Climate Control Module has a problem.
But, what do I know?
The defroster setting does not really mean anything, that is another issue, that actuator only controls where the air blows from, like A/C vents, floor defroster. The blend door controls how hot/cold the air is.
Maybe you can show this topic on the show (not an attack!, I will have to check out the show, It would be nice to be able to send questions to the hosts!!) Checking the fuse should be the first move. Can a blow-up diagram of the actuator assembly be accessed from your site? Can the connector for the door actuator be disconnected and the door moved manually to the correct position or is the gear reduction on the actuator to much to be overridden?
Not my show. Bruce is the movie guy. Ha ha.
Anyway.
Yes, if asked and the problem is explained, the guys may post it if they have time available.
No way to override the actuator by unplugging it, but..
You can unbolt it (2 screws) and use a pair of needle nose pliers to turn the shaft to close the flap. Fairly simple to check and will help to determine if it is a mechanical problem or electrical problem. Good call.
I apologize if I came off cross.
