- Entire power steering system (taken in three times before fixed)
- Auto Headlight sensor (been taken in 4 times, currently in still not fixed)Headlights will not turn off during the day- they are blaming it on my window tint - Hello! Got the car in June - Tinted in June and no issue until Oct
- 6 disc CD changer (CD changer error new one not working in shop again for this currently)
- Two tires (due to power steering and alin issues)
- Fornt right head cover and casing
- Ign switch replaced - due to stutter start - and then all gages stopped working when the key was in on position -all gages acted like I had used remote start and never put in the key- Again, new one stating to do samethings and in the shop currently AGAIN)
I have been to two different dealerships, two different service managers - one that really sucked and one that is trying hard - I contacted GM back in Sept- Started the whole claim thing - they offered to extend the warranty to 60K. With the issues stating at 1750 miles - what is that going to do really?! Finally receive call from GM rep- only took 3.5 months and I wait. He was trying to offer me a 75k mile powertrain extended... NOT HAVING ISSUES WITH POWERTRAIN!
The best part - I asked the current service manager to tell me what day of the week my car was made . . . (This has become an on going joke at work ) You guessed it, MONDAY - I have a Monday car! :lemon:
THing is, I love this car. When it runs, it purrs. If so fun to drive and easy to handle. Good take off - It is my car and I love it-
I'm not sure what is the next step - everyone else that I know that has one - no issues - Has anyone else had any kind of issues like these??!! :confuse:
With Auto Lights are you in headlight mode during entire day or only in morning/afternoon? Since the vehicle uses reduced intensity low beam headlights for DRLs, how do you usually detect that the vehicle is in Auto Light mode?
Regarding gages/ignition switch. What problem are you having again? The one where gages stop working? During a remote start not only are gages turned off but also the odometer display and most telltale indicators. It that the condition of instrument cluster or is it only an issue with the gages?
Thx
Gages - Not one stopped working all did - no odometer - RPM- gas level - temp - it was just like I had used the remote start and never turned the key - but was driving - took to the dealership at that exact time - they saw first had - ran it through the comp "NO ERRORS" The thing is- like everything else that is ever wrong with it - if you turn it off and then back on .... everything is fine :sick:
I feel kind of foolish, having over 20 years servicing machines from big John Deere Tractors to briggs & Strattons, and many different kind of vehicles in between.
I should be able to spot the oil filter.
Does anybody on here service there own cars? The Pontiac G6 to be more specific? If so, Where the heck is the oil filter? and how do you get to it?
you can get a special tool to remove the cap for a small chunk of change that should fit in there nicely.
on my last car ('04 Saturn Ion Redline), it was in the same location buried beneith the supercharger. needless to say the location under the supercharger and the requirements of 7.5 quarts of synthetic oil cause them to charge $80/oil change. that wasn't cool, even doing it yourself would cost around 50.
once you have the tool (or if you have one) to remove the cap, you'll be set to go. i don't think you need to remove the engine cover, but i could be wrong...
~replaced 2 tires already-the excuse was they were 17 inch tires and they don't last that long
~stiff steering only in the early morning when it's cold
~stutter starting
along with many other minor problems~ i'ts just the point and the inconvience of doing without the car and time to take it in
The dealership I went to had an excuse for everything. They did not fix anything other than the sunvisor covers and one is broke again already.
I love my car but for the cost I am very disappointed
I see by your profile that you have an 05 G6. Do you have the Monsoon system in it? If you do, what do you think of it?
As far a aftermarket systems I hate to point to any specific one since I don't have any first hand knowledge of them. I just have seen other folks post about them and have seen a few links to suppliers and pictures of their installed systems.
The only thing to keep in mind is that the aftermarket equipment would need to tie into the vehicles serial data system and so it had better work correctly because that same data bus is used to communicate a lot of important information required for vehicle operation.
All of this would not be such a PITA if GM would simply put RCA line-outs in their stereos, except if you were crazy about replacing the head unit. It would be nice to be able to add amps and replace speakers without losing functionality of your car.
I may have to wait for the Saturn Aura Greenline, with the 4cyl/simple hybrid - hopefully that car will be available with leather.
By the way, I think the 2.4L 4cyl in the G6 is rated at 167hp, the 2.4L in the Accord 166hp (both ~10hp stronger than a Camry 2.4L)
-Clayton
When vehicle is stationary and in Park push the MENU button until the setting you want to modify is displayed. In your case it will be "LOCK HORN ON" and "UNLOCK HORN ON". When you see it displayed press and hold the ENTER button until you see the display change to "OFF"
"The performance of the G6 is dramatically better," Lund says. The structure was maintained very well, there was minimal intrusion into the occupant compartment, and most injury measures were low.
This car is rated acceptable for side impact protection, but only when equipped with optional side curtain airbags designed to protect occupants' heads. All injury measures recorded on the driver dummy were low, but forces recorded on the rear passenger dummy indicated the possibility of rib fractures or internal organ injuries. Without side airbags, the G6 is rated poor in the side test. This car earns the second lowest rating of marginal for rear crash protection.
here: http://www.leftlanenews.com/2006/03/06/crash-test-results-ford-fusion-disappoint- s-video/
The one major criticism is the poor visibility/blind spots.
Looking over my left shoulder to merge/change lanes was difficult, and the rear window seemed a bit small.
Otherwise, it had plenty of power and nice interior.
I liked the XM satellite radio with the steering wheel controls. It was a nice car, but I don't think I would buy one.
Seems odd to put so much in a car and then screw up with something like that. Hopefully most people do not have this problem.
Did you rent a coupe or sedan?
The switch that turns it on is contained in the trunk latch.
When you see a convertible you will find the lamp is installed on a side trim panel since there is no rear package shelf.
For 2007 I would expect the G6 to get the new GM radio and possibly a 6 speed auto on GTP models. Since the Aura is getting the 6 speed I am optimistic that the G6 will get it this year as well.
http://media.gm.com/us/pontiac/en/product_services/r_cars/r_c_g6/index.html
I am not sure how i feel about the 270hp 3.9L. Is this the engine with the new 3-valve heads? B/c if its not then i cannot see how GM kept the fuel economy in check (the 6 speed?)
The current 3.9L, while refined is not so good on fuel economy (18/26), if they just made it more powerful meybe this would get even worse :surprise: IMO fuel economy in the high end range is what keeps many shoppers away.
If GM really has this new 3.9L with 270hp, then it needs to go into the Buick Lucern V6 and in the mid level Impala RIGHT NOW. This enine meets or beets Toyota and Hyndai in the power debt by a few hp. It is exactly what GM needs, a 270hp V6 Impala for 25K would be hard to resist.
The engine also needs to go into the Chevy Equinox and Pontiac Torrent, those two are badly in need of competetive power. The current 3.9L is enough to keep the cars on the radar screen, but with 270hp it will drive home sales!
I think eventually the G6 may offer the four cylinder, the 240hp engine in the GT and the 270hp engine in the GXP.
I hope to see more info on GM's new V6 soon
Doubt if they will keep all those permutations/models.
I also think the GXP is a bit overdone for my tastes. The 18inch wheels are perfect, the 19's on the GXP? I dunno, if it moves people into the showroom i guess it doesn't hurt. I'd like the regular GTP with that 270hp v6 and a nav system, with 6speed auto and NO SHIFTERS ON THE STEERING WHEEL, PLEASE KEEP IT WITH THE SHIFT KNOB!
Cool car, I really think GM has got a good thing going for it with this G6 name. They have lots of styles and options to choose from.
As for mileage, the Aura is not better than the GTP in spite of the 6 speed auto. It is rated at 18/27.
• All Models now get the G6 GTP's Hydraulic Power Steering, except base and SE models.
•GTP models now have a standard 6 speed automatic transmission featuring manual shift mode.
• New standard GTP engine 3.6L 250 HP, V6, DOHC, VVT.
•Available heated cloth seats on all models.
• Radios now OnStar "Turn-By-Turn Navigation Capable".
• New optional 17" Black Chrome Tech wheels.
• New exterior colour - Blue-Gold Crystal
• New - Air Bags: Driver and Passenger, Frontal Dual Stage, Side
Head Curtain Airbags and Passenger Sensing System standard on all models(except convertible).
• New wheels:
17” x 7” 5-Spoke Facia Painted Wheel
18" x 7” Aluminum Ultra-Bright Wheel
• Seat side airbags now optional on all models.
• 2.4L Ecotec standard on base and SE models.
3.5L V6 standard on GT models.
3.6L V6 standard on GTP models.
3.9L available on all GT models with optional 6 speed manual.
• 3.9L engine changes:
W/ 4 Speed Auto - 227hp
W/ 6 Speed manual - 240hp.
GT PERFORMANCE PACKAGE:
Includes 3.9L V6 (240HP), 18” Aluminum Painted Wheels, 6-Speed Manual Transmission,Dual Chrome Tip Exhaust, Stabilitrak.
GT CONVERTIBLE PERFORMANCE PACKAGE:
Includes 3.9L V6 (227HP), 18” Aluminum Ultrabright Wheels, Dual Chrome Tip Exhaust, 4-Speed Automatic Transmission, Auto HVAC, Leather Front Heated Bucket Seats with 6-Way Power Driver’s Seat with Lumbar.
