Dodge Ram Pickup - which one??
 canadacraig
                    Member Posts: 34
canadacraig
                    Member Posts: 34
                    I KNOW that I'd like to own a RAM 1500 with the 5.7 litre Hemi engine AND I KNOW it must have the 5-speed automatic, the premium cloth seats [with the 8-way power drivers seat] and the leather wrapped steering wheel. But beyond that - I'm not so sure. I can't make up my mind as to what 'body' to get - the regular cab or the Quad Cab. OR if I should get the 2wd version or the 4wd. Have any of you bought the new Ram and WISH you ordered a different model?? [or wish you ordered more options - or wish you DIDN'T order some options??] For instance - is it worth getting those 20" wheels?? Is the Infinity stereo impressive enough to spend the extra money?? [etc., etc.]
I'd love to know what you think.
Craig
Craig
I prefer the LOOK of the regular-cab but the dealer I go to told me that IT [in fact - any 'regular-cab' pickup] loses considerably more [resale value wise] than a Quad [or 'extra'] cab. Is that true - do you think?? Assuming that's true - the better resale value and the extra interior room afforded by the QuadCab might be the 'way' to go. I'd probably appreciate [in the long run] having room to having a 'sportier' look. I don't NEED 4wd so that could save me about $3000 CDN.
As for the SIZE of your RAM... do you often have to avoid underground parking lots [because the trucks too high] or anything like that?? Is it easy enough to manuever around town. I ask this because I would be trading in a Jeep TJ [aka 'Wrangler'] which is a bit like driving the Mad-Hatter's tea cup. [almost as long as it is wide - or so it seems]
Thanks again,
Craig
With all the incentives today, the price wouldn't be much different.Get the quad cab-you won't regret it.
Dave Huber
The value of a used vehicle is dependent on a number of things, ie.: condition, miles, equipment, geographical location, and local market conditions, to name a few.
All other things considered being equal, a vehicle's value at any given time must be subtracted from the list price or the actual price paid when new. The RAM Quad may in fact be worth more at term than a conventional cab version of the same truck (miles, equipment, etc. the same), but the Quad will cost more. The more practical way to determine used value is to calculate the difference between list price and current market value of the two different vehicles.
And there are some things that cannot always be foreseen in resale value. For example, the used car market around here (Rochester, NY) has been full of Ford Explorers, either from program, lease, or private owners putting them on the used market. The selection is good, from a used car buyers perspective, and so is the price because there are so many around that the market is near or above saturation for these vehicles.
My point here is, today a truck like a quad (4-door) is very popular new, but a war in the middle east or some other such reason could drive fuel prices up. When this happens vehicles of this type may not be so attractive to used car buyers. Also, heavily leased vehicles, like my Ford Explorer example, make used prices drop as these 2, 3, and 4 year leases expire putting them increasingly on the used market.
Good luck on your decision.
Dusty
Did you compute the actual miles driven divided by the number of gallons used? (The old fashioned way.)
Be interested in how that compares.
Dusty
Dave Huber
CC: Critical point in choosing QC--Are you a golfer? If yes, you'll want the interior storage space.
Venturagal,
In a good design the material difference between the head and the block should not be a factor. There are some aircraft engines that do this and a lot of race car motors, too. And this arrangement usually works well, again, in a good design. I agree that there are some designs that seem to have a higher incidence of head gasket failure than others and I would say that many of them are in fact aluminum head/cast iron block. However, some designs don't, like the Nissan GA16 motor or any of the Honda engines. And some iron head/iron block motors have had more head gasket failures than others.
Many, if not most, head gasket failures are due to corrosion in the water jacket seal area. Some, like older Chrysler 4-cyl (American made, 2.2 versions) leaked oil. In my experience few have actually "blown" out in the chamber area, although in my aging memory I seem to recall that some of these were the old Chevrolet (GM) straight sixes (BlueStreak motor), and I have seen a few 302 Fords. The GM V6s are probably the most notable for this in recent years, along with the Ford 3.8 V6 of certain vintage.
It just so happens that the 3.9 V6 used in the Dakota is actually a 318 V8 with two of the center cylinders removed. It's a very old design that goes back to 1967 and in all my experience I don't ever remember seeing or even hearing of a 318 or a 3.9 head gasket failure. I'm sure there have been some, because just about everything fails sometime, somewhere. But I believe it's pretty rare.
But be careful. This could be sort of like men, you know. I'd hate to see you run from any aluminum head/iron block design into something else with another type of problem.
Best of luck,
Dusty
Just a plug for me, I have a regular cab Dakota R/T that I want to sell so I can buy a Ram. It's a rare yellow color for 2000 (only 5 RC R/Ts made in this color for 2000) and only has 18,000 miles on it. No v-6, and no manual, a good hot rod and arguable the best handling production pickup ever made. I was asking $13,700.
Thanks again
