Stratus R/T - MPH higher than clocked/Odo higher than driven
I purchased my 2002 Stratus R/T 3 days ago. The dealership was over 100 miles from my home. On the drive home I noticed that my odometer was adding more miles then what the mile markers were saying I was driving; about 1/10 mile per 3 miles driven. My husband, who had just purchased a 2003 Dodge Dakota 2 weeks before, and I decided to make a test drive to see exactly what was happening. His truck adds miles properly as per miles accumulated based on the highway mile markers. We both drove our cars, with him following me, and I set my cruise control dead center on the 60MPH mark. While he was following me, my husband's speedometer said he was traveling 56MPH. Also it took me 63 seconds to travel from mile marker to the next mile marker. The trip was over twenty miles. In the end, his trip showed his truck traveling 24.5 miles whereas the Stratus showed a trip of 25.3 miles. I took it to the dealership who test drove it by stop watch & by the mile marker method but said they cannot reproduce the problem so are not sure what they can do about it. Are there any suggestions as to how to solve this issue and get my vehicle fixed under warranty?
I would recommend a much longer drive to determine fault, but DO NOT use the mile marker system as it can vary over 100 meters - have another vehicle get involved, drive quite a few miles, logging an exact measurement; then use the Dakota, then the Stratus - only my recommendation.
Bear in mind your car will not measure mileage perfectly due to several reasons, the main one being that your speedo is not a radically calibrated tool. No car's speedo is, unfortunately.
As someone here said, speedos aren't precision instruments, I suppose due to cost concerns, but they always read a little high (or a lot high in the case of certain German cars) instead of a little low. I always assumed this was automaker CYA.
I've noticed this whenever I drive past one of those machines the cops park by the side of the road that give you a reading on your speed. Even at 35 or so they're usually a mph or so higher than what the speedo shows.
However, the odometer is usually correct.
Other than that, I would assume the 2 mph to be an acceptable tolerance.
For some reason this reminds me of a '62 Chevy I had that someone had put 4.11s in without changing the gear in the tranny that drives the speedo. The stock gears had probably been 3.36s or something close. Around town the speedo error wasn't too large but on the freeway an indicated 75 was more like 55 IIRC. Of course with 4.11s you're always in the slow lane. Just thought I'd share.
There is no need for repair. Everyone who owns a car deals with this.
Really, this might work. If you run something like a 215/55-16 then a 225/55-16 is about 1.7% larger, or even closer to what the speedo reads. So a plus zero tire upgrade would give you a more accurate speedo and perhaps a bit better handling.
However, 3% really is nothing in the grand scheme of things.
Besides, when you calculate MPG, you'll get better numbers this way, LOL.
TB
Thinks this might be a new "conspiracy" to run warranties out 3% sooner, LOL
First off, zueslewis, you are right, in this day and age people have to accept problems and not be satisfied. In fact I found someone with a GPS that shows the Speedometer is showing 3 MPH more than I'm actually driving. That's a 5.2% error, well out of scope of the acceptable limit. Do I now accept the problem?
Now, tboner, I loved your post. I have a 17" wheel but maybe that will help. I'll look into it when I buy my tires maybe even get a 4-5% increase in size.
And finally, speedshift, thx too. Yes there is fine print in the warranty about an inaccurate odometer voiding it, and boy did I have a discussion with one person about this saying just that. The dealerships and shops don't believe what was said when it's a manufacturing defect this is causing the problem.
Anyway things are being worked on and I heard from one of the people I'm dealing with that mine is not the only vehicle seeing this problem. I'm not being provided with the quantity and I'm wondering how many out there have this problem and do not realize it. If it hadn't been for a long drive home I wouldn't have discovered the issue.
Oh well, thanks for listening all. Hope your Thanksgiving was a happy one.
