Early first oil change for 2003 Accord?
I just bought a 2003 Accord. The owner manual says that part of the break in procedure is to NOT change the oil earlier than the maintenance schedule (10,000 miles) for the first oil change because they have a special oil in new cars to help break in the engine. I talked to my mechanic and he said it is better to change the oil every 3,000 miles. What do you think? Is it o.k. to change the oil at 3K or should I wait until 10K for the first oil change?
The only way I know of to be sure your oil is still doing its job is by lab analysis. But oil changes are pretty darned cheap and are very beneficial obviously. You might want to do a quick cost/benefit analysis along with the lab analysis to determine when it makes sense for you to change your oil. That way you know for sure and don't have to guess or rely on others who may not have your best interests at heart.
Also check the dealership how stingy they are about 5w20 oil.
1. Severe Driving - change oil every 5,000 miles or every 6 months, which ever comes first.
Severe = a) most trips less than 5 miles, in cold conditions, or less than 10 miles otherwise; b) lots of driving in 90 degree + weather; c)lots of idling/stop and go; d) towing; e) off-road (paved) driving.
2. Normal Driving - change oil every 10k miles or 6 months.
Normal = living in Southern California or Florida, and commuting at 5 am, 2pm to avoid any stop/go traffic.
Also I drive 20 miles to work against traffic each day and that is the bulk of my driving so I think I am a "Normal Driving" type of guy. I am still going to change the oil every 3K miles after this first confusing oil change.
**** from the honda owner link website ***
Why should I wait to change the oil the first time?
Your Honda engine was delivered with an oil that is specially formulated for new engines that have not yet developed their "natural" wear patterns and may contain minute particles from the manufacturing process.
American Honda strongly recommends this special oil be left in the engine long enough for these wear patterns to develop, usually until the first maintenance interval specified in your Owner's Manual, based on your specific driving conditions.
5w20 is also more difficult to find right now.
So a lot of people run 5w30 oil, instead.
Ford is the other company that mandates 5w20 oil, and they do mean it (voided warranty).
My intention is probably the same as my Trailblazer. Change myself every 5k miles w/ syn blend. =o)
BEcause the fine print says, other oil weights will void the warranty. Ford earlier had issues with people using 5w30 and its complications...and left people stranded with voided powertrain warranties.
If you're local dealership will stand behind the 5w30....by all means (make sure you get an official statement from them saying it beforehand, just in case)
If you check the maintenance schedule, there are two spots, one for oil change, one for oil and filter change... kinda strange how they set it up.
www.theautochannel.com/news/press/date/20000907/press024948.html
Greg
