How can I disable the A/C compressor during winter?
My 2000 SE has 26,000 miles and is under warranty. I'm not anxious to make any modifications before the warranty expires in June '03 but the lack of flexibility in the manual climate control is unacceptable. According to the factory manual and Haynes, the A/C compressor is only supposed to run when outdoor air temperature is above 50F. Wrong! The compressor runs on every setting except the 11 O'clock position where air enters the passenger compartment via the dashboard diffuser ports. My '93 Taurus had the same problem. My '91 Explorer has a simple compressor on/off factory pushbutton that works great! In my opinion, Taurus engineering does not seem to be getting the message that the A/C on/off should be a user option unrelated to outdoor air temperature or air flow selection mode.
So here's my proposed solution: I've looked over the schematics and think I can install a toggle switch in the compressor clutch circuit to manually select when the compressor runs. I'd probably hide the switch in an easy to reach location below the dash for rapid winter defog or normal summer operation. Question is: Will interrupting compressor clutch power cause any harmful side effects?
If it is running when you have other settings maybe there is a problem. The four settings mentioned above are proper, as you want to dehumidify any defrost air and then reheat it to dry this air so the moisture does not condense on the windshield under certain high humidity situations. I have never found the factory setup to really be a problem, and have been driving Tauri in the Snowbelt-all kinds of different climates-since 1990.
It makes sense for the defroster, as it minimizes window fogging during rainy winter days. I never quite understood why the compressor is on for the footwell vents. (Maybe drying the feet will reduce athlete's foot ?)
Anyhow, I wouldn't disable the A/C compressor, because you'll never know when you may simply want to use it to remove moisture from the cabin air.
Most definitely will.
Kinley hit it right on the head.
The compressor needs the oil to keep it from seizing.
Your A/C compressor will run (as was stated) in defrost, that way, the A/C system still runs and the A/C system also helps to dry out the vehicle (as was stated).
The A/C switch on the Rangers is for A/C max. It should still come on with the defrost. At least the 02 Rangers we have at work do.
If you disable the A/C for any length of time, there is a chance that by the time you go to use it again, there may be a problem with it.
The compressor needs the oil circulating to keep it from seizing.
I suspect that this recurs on the basis of somebody saying it will save you gas, save the whales, whatever. it's a trade-off along the lines of putting the widest tires availiable on the option list on your car.
ain't worth fooling with.
The system is designed to be run to lubricate it.
Why not use it as it was designed? Maybe keep it from going belly up. I have seen vehicles with 300,000 miles on them, with the original AC system, even after a replacement long block went into it.
Do what ever you want. That is up to you, but the person asked if it could harm the system, Yes.
Moisture can contaminate the system, just from sitting. Just like brake fluid can absorb moisture.
You ever flush the brake fluid system on your vehicles? Didn't think so.
New compressor clutch
New dryer and pipe repair and R134 conversion
Replace hose that broke a year later after repair (broke in different spot)
Ok, maybe more like $800-900, but pricey to keep the cooling.
And my grandmother had the compressor replaced when she owned the car.
FWIW,
TB
Badgerfan is right. The compressor should run in the A/C mode, the defrost mode, or the Defrost/floor (mix) mode. It does not run in the vent or floor mode.
Even on older Explorers or Rangers that had the button to activate the A/C would automatically turn on the compressor in the defrost mode if the outside temperature was above a certain level.
Jeffleav and Haspelbein, if the compressor is running in the floor mode on Taurus or Ranger, I think you have an electrical gremlin.
brucelinc,
I am pretty certain that in floor and vent, your A/C compressor isn't running. I would have to double check that, but it is pretty much a standard.
Today, I experimented with my Ranger. It is about 25 degrees here in Minneapolis and the only way I could get the compressor to run was in "max A/C" mode. It would not run anywhere else as long as the truck was outside. After I parked it in the garage (about 55 degrees) for an hour or so, the compressor would run on the defrost or defrost/floor mix mode but not run in the floor or vent positions.
This seems like very logical operation. Why would anyone want to change it?
for a weekly 5 or 10 minute run, it would be like idling 7 or 15 minutes with the a/c off, maybe.
there's a hit, but less than the cost of manufacturing replacement parts, installing them, recycling the offal, as well as the impact of the lost refrigerant on the environment... if you go the green route and total up all the costs of the transaction.
looks to me like the best thing to do is run it.
These are fleet vehicles. They see a regular maintenance routine. As for the age of them, years range from 84-95. Some have more than the 300,000 miles on them. Like I said, they are fleet vehicles.
