Spark Knock
I have a 2002 Mustang V6 coupe with 13K miles. At 12K miles, I noticed a metallic rattle from the driver's side of the engine when slowing applying the gas at 50 mph or higher (It is especially noticeable going up hills). I took it to the dealer where I bought the car and they told me there is a service advisory on the Mustang for spark knock. They initially replaced the Differential Pressure Feedback (DPFE) due to a fault code but that did not stop the problem. On the second visit, the mechanic drove the car with me and he was able to hear the rattle. The next step was to adjust the octane level. It has been in two more times (four total) and the spark knock is not as bad but it's still there. On my last visit, the mechanic went with me but was unable to hear the rattle. The mechanic told me there are no codes and nothing else to adjust. They indicated it is now documented so if the problem causes damage, Ford would help fix it. Has anyone had a problem like mine? I decided to sell the car since I can't live with any unusual noises from the engine. My problem is I feel obligated to tell a prospective buyer about the problem but if I do, I may never sell the car. The warranty is transferable.
Only reason to dump it at this point IMO would be to go to a GT.
Besides, if you like your rocker panel stripes ( I personally love 'em, but I seem to be in the minority on this), they're not available on the 2003s. : (
The dealer ran some kind of stuff through the engine that burned out the carbon that caused the knock. I filled up with premium and there were no more problems. One year ago we bumped the timing back up to within 1 degree of factory specs. No problem.
The service manager is suspicious of the gasoline. You see in St. Louis we have additives that burn cleaner fuel since the EPA has declared the St. Louis area as polluted (Like L.A.). This "additive" has been known to ruin the gaskets in the older carburetor vehicles in our area (although we own a Corolla with a carb and that car has 210,000 miles with no problems).
So, like smithmga....has anyone else had spark knock problems? The truck in question here is a 4 cylinder 22RE.
Do you guys have additives in your gasoline and the hulking-big gas hoses that suck back the fumes from the gas tank like we do in St. Louis?
BN+
ethanol and MTBE are the oxygenates in general use for boosting octane. you can run up to 10% ethanol in fords from 90 on, unless you have an E-85 capable engine, in which case you can run up to 85% ethanol (the 4-poppers in the line are about all "green leaf" engines.)
recapturing gasoline vapors in the gas station tank is NOT a contributor to engine rot, but to pocketbook rot
the state has been told what the makeup of your area gas is, and the refineries are probably boasting about the formulation as well. AFAIK, only Chevron and (formerly Koch) Flint Hills have busted their butts to make a majority of their fuel meet the 2005 oxygenation standards now.
