torque pull
Just bought a 2002 mazda protege 5 hatchback with 12,000 miles. Right front tire tread = 3/32 and left = 4/32. Rear treads were 6/32.
After rotating, balancing and alignment the tire dealer tells me the car's pronounced pull to the right happens in some cars as a result of "torque pull".
Assuming everything is now to spec what permanent fix is available and who should do it?
There's no real "fix", it's just a characteristic.
If you're rotating at 12,000 miles, you should rotate much more frequently.
TB
but on a FWD car, when you punch it up and the engine lays over to the side, generally to the right, it is also putting that extra weight on the driven wheels, not on the passive wheels. this will greatly exaggerate the effect, as you have discovered. I am told that in some cars, using counter-rotating camshafts and balance shafts reduces the torque shift of the engine, and in others the effects of torque shifts in the engine and transmission seem to add up for a greater side pull.
short of massive redesign and reconstruction efforts, there is little way to minimize this torque steer effect in a particular model of car. you have to decide if you can stand it in a particular vehicle during the test drive.
methods of living with it once you're stuck and decide you don't like the torque steer effect are driving like granny with eggs taped to the pedals, or cranking the wheel X amount left before pushing the gas down, X being dependent on your own reaction times and the amount of torque steer in a particular car.
sorry, but there is no real neat answer, and no "mechanic-in-a-can" that can correct this.
I distinctly recall the r/f tire in my Saab turbo wearing at a far greater rate than the l/f tire, regardless of how I drove or rotated or whatever.
Harry
P.S. Zues? Huh? Top to bottom/bottom to top? Axel length and angle have some effect, and a couple years on the "X" cars GM was putting a shim under one engine mount to minimize it. No 2002 automobile should have noticable torque steer at light throttle.
