Shop did Radiator Pressure Check-Now water in Oil
My husband took our 1992 Pontiac Grand Prix,3.1L to a Repair Shop to have them do a pressure check on the radiator. Jeff (my husband) has replaced and done everything to the cooling system,including just having the radiator rodded out. He still didn't think there was good circulation.The Mechanic told Jeff when the other employee came back from lunch they were going to do test at 16lbs.Jeff picked up our car and told him "no charge". On the way home the car died. Jeff thinking he was out of gas,(gauge doesn't work)put gas in and heavy tapping from engine is now being heard. Jeff checked the oil and it was brown colored. He changed the oil (kept it) and no change.There was absolutely nothing wrong besides circulation! This occured today,1-6-03.He's going to shop tomarrow.Need Advice Please!! "Thank You"
http://www.petitiononline.com/mod_perl/signed.cgi?GMcnsmrs&1301
It's easy to blame a shop for something they didn't cause.
Hold on now.
There is no way that pressurizing the cooling system "wrong" is going to do anything more than blow hoses. If the headgasket failed after pressurizing the cooling system, then you had a problem to start with.
Pressurizing the cooling system is a time tested diagnosis and only harms the system if you already have a problem. More than likely, it started to dislodge a head gasket that was already failing and once the vehicle got up to operating temp, it finally failed.
Don't go blaming the mechanic until you are sure what you and anyone you are getting info from, know exactly what you are talkig about.
As Alcan pointed out, these engines have known cooling system problems and more than likely, is the cause of your problem, not pressure testing the cooling system.
now, if somebody came back from welding class saying "looky what a neat tool I made here," and it happened to couple shop air to the cooling system, I would suspect 120 psi and up is likely to wreck the cooling system as surely as a sledgehammer.
technicians who know their subject instinctively avoid such gonzo approaches....
sorry you have a premature repair, 0patience said it way better than I was trying to say, it was already dead. I suspect you had reason to want the test done, and that reason was correct, the issue bugging you ended up being a big one.
