Check the level (locate the tank based on your manual, or prior knowledge!). Top it up (based on the recommendation for appropriate coolant in the manual - the type escapes me right now) and take it in pronto if you notice the leak or a reduction in level again. If its overflow, you're ok - if not, I imagine they should check the system for leaks etc.
Another pink fluid that it might be is automatic transmission fluid. Do you have an automatic?
Other manufacturers have used and maybe still use other colours (GM orange and VW/Audi blue come to mind). It's important to check this (with your dealer and in your manual and obviously in the coolant overflow bin and radiator) and not assume that green will do it on every car.
Dinu
Oh yeah, if it turns out to be transmission fluid, when you top it off, don't forget to leave the car idling in park. After you check the fluid and add (if needed), run the transmission through the gears (with your foot on the brake) and check it again. Don't overfill it......next, go to the dealer.
Detailing discussion forums exist here and elsewhere - ask the experts!
I have a grey interior in mine, and this also exhibits the same staining on door materials. Wiping with a damp cloth, then Armor All (paper) has done the trick for me. Some of them are more stubborn!
Dinu
I have a few thoughts. First, I am not sure that this rust issue will be catastrophic, as many have suggested. It may well be, but it may also be a relatively simple problem to address – time will tell. For those of you who work or have worked in the industry, are you surprised that the service manager was not aware of this problem? Are there so many TSBs coming across their desks that they do not automatically read them all – or scan them, at least? I would have thought that Mazda USA would have publicized this issue to the dealers fairly heavily. I told her that there was LOTS of information about the rust/stain on the internet (thank goodness!!)
I was also surprised that no one else had presented to this dealer with this problem. I live in a major metropolitan area and this is a very busy dealership. Either this problem is not as widespread as the newsgroups make it appear, or else there are numerous owners who have not yet learned to look under their weather stripping. I asked the service manager to look around the lot to see if they had any cars with rust/stain and consider “practicing” the fix on one of their cars before doing mine – she’s going to investigate and call once she has a plan to propose.
Finally, for those of you considering the purchase of a Mazda6, I am very happy with the car, despite the concern over the rust/stain. It is a blast to drive, and I could find no other car to match its performance/fun-to-drive/cost ratio. It’s a great car.
Perhaps when the holidays are over we'll make an effort to raise the money and get the tests... right now, most people are focusing on holiday shopping and preparations, and money is tighter.
My 6 is back to the dealer for the 4th time in 2 months. The front brakes squeal loudly when going at low speeds while turning. They've installed a "kit", replaced boots, reallinged the shield, all to no avail. I also have an intermittant front wheel hop/shudder when starting out. I can't duplicate it, but when it happens it feels like the front wheels are going to shake off of the car. This might happen several times in one day, then not again for a week. Hot or cold, turning or straight, doesn't matter. I had the wheels rotated and balanced-no change. The car tracks and stops straight. I, as well as the service manager are at a loss. We both thought that maybe the two problems may be connected?
A factory rep will be looking at the car tomorrow. I thought that I remembered a long time ago a post(s) about improper torquing of some front end parts. Any ideas? I'd like to be able to call them in the AM if anyone remembers this. (sorry about spelling-in a hurry)
Thanks in advance.
PS Just a little bit of rust in the "notched" part of the door frame.
Does your 6 have a manual tranny? The 3rd Gen Protege (99-03) had a similar problem, but only during cold take-offs. The problem is clutch chatter caused by certain materials in the flywheel and clutch cover. A TSB was released calling for the replacement of both parts with new revised parts. If your dealership can replicate the problem, replacing the clutch disc (or flywheel and clutch cover) might be in order to rectify. Here is a link to that TSB:
Protege TSB MT000003848
If that preliminary test comes back positive, then go for the $$$$ test.
my 2 cents.
I called my service manager this morning-he told me that they were aware of the subframe problem, and that they check every 6 that come into the shop and that so far they have found only one that was not done right at the factory. He told me that mine has been checked. I also told him about the clutch problem with the pro-he knew about this also, and think he was telling the truth as I let him talk about it after I mentioned it and he told me the correct info according to the TSB-I call back tomorrow AM to see how they made out.
coakleysd-
I agree 110%. Go to any fast food drive thru with your window down-the squeal resonates off the building making it twice as bad. Someone posted a while back about a co. having aftermarket front pads for the six, I checked the site and they do exist. If I remember right they ran about 60.00 for the pair. They are supposed to reduce the dust issue. If this fix doesn't work I think I'll just order them and have my local shop install them. I'll look thru the posts and re post with the one that has the site on. My dealer is 45 min away, so I travel 1,5 hours 4-5 times so far, it would be much less frustrating to just put the aftermarket pads on and leave it at that.
Go to brakeworld.com- they stock Rotex kevlar/metallic front and rear pads for the 6. They say it virtually elimates brake dust and reduces squeal.
Has anyone out there tried these. I'm looking to get rid of the squeal, but dust free pads on the front for my car would be fantastic.
I know there are lots of complaints out there about the dust. Anyone want to be a guinea pig for these pads??
I picked it up this morning. Here's the story. The service manager drove my car all day yesterday-he said once or twice he thought he could "kind of" feel what I was talking about. They brought the car in, rechecked all possible bolts and found all to be okay. He tells me that the rep has it noted in my file and then gave me an invoice copy with the reps name stating that they will give me a 5 year, 75,000mi warranty on the clutch and related parts. If it get worse just bring it in and they'll fix it. (Sounds to me like the rep knows that a TSB is coming out soon-this keeps me quiet for now) I guess that I'm somewhat satisfied with that.
The brake squeal is another story. He told me that he really didn't think that the problem was with the pads, HOWEVER, he "sanded" them and applied brake quiet, and it seemed to help. I don't quite understand that if he didn't think it was the pads, then why did he alter them. Kind of like me going to the ER and the doctor telling me that the blood dripping from my hand is probably not from the gash in my palm, but we'll stitch it up anyway. Hmmm, sounds a bit incompetent to me. The brakes still squeal when turning with light pedal pressure. Not quite as bad though, which cemented my decision to order the kevlar pads. I just ordered them from brakeworld. I'm not sure if I'll install them or have my local shop do it. It's been a long time since I've turned a wrench. If that doesn't fix the problem, at least these pads are supposed to be pretty much dust free. Then what I'll have is "squeaky clean" wheels. (Sorry, couldn't resist)
BTW could you email me the "other board" with the reference to the clutch problem. cop414@hotmail.com
Thanks for your help-I'll keep you posted on the new pads.
The 2 silver 6s in the showroom had rust without a doubt. This wasn't a stain the metal was affected and it couldn't be rubbed-off. The Yellow and blue ones didn't - I couldn't see it. The black one had it, but it was extremelly hard to notice it.
I can't describe the feeling when you see it in person - it's like a major let-down. Let's just say that I started checking the Mazda3s the had inside too.
Dinu
I also was at a dealer a few weeks ago and test drove and inspected a 04' Sepang Green.There was some discoloration in the seam areas around the doors.This car had a build date of 10/03.It had only been exposed to the elements for 6 or 7 weeks! If the problem "Has been resolved",and If the cars you inspected have newer build dates,whats up?
Do you own the Mazda 6 yet, or are you still looking? My concern, while feeling bad for the owners with this problem,is weather this is affecting recently built cars.I would love to buy a Mazda 6 but I am scared to *#%@ of ending up with the same delema.
Please !! More details !!
John
Milwaukee,Wis. U.S.A
It's the first time I actually saw rust on the 6 in person and had to post - it's one thing when yuou see it on the net, but when you see it in person it hits you.
Dinu
Dinu
At this point I think being patient is or best appraoch.I was going to wait until spring when all the salt is off the roads.Might hold off a little longer until I can get some straight answers from the dealer.When I asked the dealer here if this problem has eliminated he could not give me a definate answer.
At this point Mazda has a 5 year "Rust Through"corrosion warranty.Let me tell you from experence, a car that starts rusting looks pretty bad by the time the rust starts making it way all the way through the metal.They won't fix it until they see day light on the other side.I owned a 85" Pontiac Grand Am that looked like it was more rust than not.They would'nt do a thing about it because they deemed it as being surface rust.
liquid0715 I feel your pain! I've been There.
Dinu , be patient! All the rest of us need to do the same. Mazda is a good company and I have to believe they will stand by their product.I'm sure if they have not solved this problem at this point , they are working hard to do so.They stand to loose alot of money and reputation if they don't.It might take some time.Production changes if major,take time.
Good Luck if you buy one ! That *@$&in car rocks!
It's killing me to wait,but wait I must!AAAaaaaa
John
Not the 3 too. I'll drop by next week and check it out.
Dinu
I'd rather not think about it.
Dinu
See my posts on this board #'s 731, 733 & 736.
I don't really want to be the guines pig for this fix, but I can't stand the noise any more:(
If it doesn't work and my car is plagued with unsightly "surface rust" and Mazda refuses to fix it because the metal is not perforated, there are other avenues to take.
There's nothing corporate America/Canada hates more than a class action suit. There's nothing corporate American/Canadian lawyers love more than class action suits. Be patient- if Mazda screws this up, they will be held accountable.
