No Tune Up
I just wanted say I've 103k on my car with no tune up.I'm still geting good fuel mileage.
Mr_Shiftright I've only replaced my front brakes.
Battery still the original had some trouble cleaned off the corosion filled it with water was fine after that.
In fact, I never changed the oil on my first car. It leaked so much that I thought it wouldn't be necessary. I gave it away after two years, but the engine ran fine.
I'm pretty positive that you could drive a Honda Accord up to 100K miles with maybe three oil changes. Plugs can easily go up to 100K miles if they're not too hot. (I just ran copper plugs up to 60K without a problem.) Brakes are a little more touchy. Even a careful driver would probably push it at 70K or so.
Battery live seems to be mostly a question of time, not mileage. In a warm climate, 7-8 years are definitely possible.
The coolant is probably also a time bomb. I'd guess 5-7 years before you run into problems by not changing cooleant.
What happens after 100K, well..that is a different story.
One of my supervisors has a '92 or '93 Civic, a base model with a stick shift and drum brakes in back. He has about 160,000 miles on it. Somehow, the front pads lasted long enough that they were only recently replaced, and the rear drums are still original! I think he has about a 60 mile commute each way though, and it's just about all highway. Still, it seems incredible to get mileage like that out of a set of brakes! Does a manual tranny really let you get that much more life out of them?
The scenario (mainly highway) is pretty easy on the clutch, as little shifting is involved. If your driving style isn't aggressive, you can milk a lot of mileage out of a manual transmission without changing the clutch.
Aside from the clutch, I would expect a manual transmission to last longer than the average slushbox, as it is a simpler design with far less stress on the lubricant.
Since I don't put that many miles on a single car, I've never driven my vehicles for much more than 80K miles. I've never had clutch problems so far.
Ever since this whole "100K miles without a tune-up" thing started a few years back, I was wondering how valid those claims were going to turn out to be as the years passed. It seems like at least for this sentra they were valid, eh? What about air filters? Yes, OK, the plugs can go 105K, or 110K (Honda's claim) or whatever, but surely you must have to change the air filters a lot more frequently than that?
