Transfer Case Fluid in Jimmys/Blazers
A few days ago I noticed that I wasn't able to shift from 2 wheel to 4 wheel drive when the truck was cold. I would like to check/change my transfer case fluid but have no experience in doing so.
1. How hard is it?
2. What do I need to buy?
3. How do I do it?
I have a copy of Chilton's for this car, but I wanted to know if it was worth trying first.
Thanks, Fritz
1. How hard is it?
3. How do I do it?
Thanks, Fritz
The lower one is the drain, the upper one is the fill. Pull the upper plug and then the bottom one and drain the case, let it drain for some time. Once drained, replace the lower plug and fill the transfer case thru the upper plug until it overflows. Then replace the plug adn clean up the mess.
There are two different transfer cases used in the blazers.
New Process 231, which is a manual shift transfer case. Uses 2.5 pints of Dexron IIE or equivelant.
New Process 233, electronic shift transfer cases. Uses 2.5 pints of Dexron IIE or equivelant.
Borg Warner 4472 AWD transfer case. Uses 3 pints of Dexron IIE or equivelant.
The best thing is to replace the fluid with DexronIII, since it exceeds DexronII's specifications and is readily available.
Also, being a 1995 Jimmy with automatic transmission and not all wheel drive, I suppose mine is the New Process 233? Sorry for the redundant questions. I just like to know exactly what I'm doing before I start, less the process turn into an unexpected cluster.
This DexronIII, what does it cost and you're sure its safe to put into this thing?
Thanks again! Fritz
The plugs on the transfer case will either be female 3/8" square plugs that require a 3/8" ratchet or breaker bar to fit into the square hole, or they will be 3/8" or 7/16" square plugs and use a cresent wrench [ouch] or 3/8" or 7/16" wrench to remove them.
Caution should be used if the are the internal square drive (female) plugs, it is extremely easy to strip out the square hole. Use a quality breaker bar if the plugs have never been removed. Use eye protection for the dirt and garbage that can fall in you eyes and in case you slip with the ratchet or breaker bar. I would suggest a pair of gloves too, to prevent tearing knuckles up.
Have a good weekend.
Thanks for the help guys, Fritz
