VW Passat TDI
cegledi
Member Posts: 11
in Volkswagen
I heard rumors about VW putting out a diesel version of its Passat. If this is true, sign me up. I have been looking for the diesel version of a quality vehicle like the Passat for a long time now and hopefully it will come true. Any ideas?
or torque, I guess its diesel here...
Krzys
VW will be offering the following engines for '04, 1.9 Liter PD, 100 HP (New Beetle, Golf and Jetta), 2.0 Liter twin-cam, 134 HP (New Passat, with an SOP of 45/03), 5.0 Liter V10, 310 HP (New Touareg SUV, SOP week 45/03).
All of these engines will be "45 State" legal and can't be sold in CA, MA, NY, VT, and ME which all adhere to "CA emission Standards".
This may change because California is looking at their current (diesel) standards and may roll the back due to their impact on this issue.
VW is working on this problem an anticipates a "50 state car" at some point.
2.0L TDI? Is this a new engine? I am ecstatic about a TDI Passat.
The 1996 and 1997 Passat diesels still sell for a premium.
6-speed: 0-62 mph: 9.6s; top speed: 137 mph; 40.4 mpg (combined cycle)
5-sp. auto: 0-62 mph: 10.7s; top speed: 133 mph; 34.9 mpg (combined cycle)
For the 1.9L TDI PD four-cylinder, it's:
6-speed: 0-62 mph: 10.2s; top speed: 125 mph; 47.1 mpg (combined cycle)
5-sp. auto: 0-62 mph: 11.9s; top speed: 122 mph; 38.7 mpg (combined cycle)
The 1.9 TDI PD is also available with a 6-speed and 4Motion (Quattro) AWD, which slows 0-62 mph acceleration to 10.5s, costs 3 mph in top speed, and 4.3 mpg in the combined cycle.
Note that these are official VW test numbers, and acceleration times are 0-100 kph (62 mph); 0-60 mph would be a tick or two quicker.
40 mpg is killer tho
Add a chip or a tuning box (though the tuning box tends to interfere with the MFA a bit)
Krzys
PS US and British mile are identical - how come ?
The end of all conversion problems! US and UK are the only two countries that I know of to persist with the foot/inch/mile system. And they even can't agree on the definition of the gallon
(first number is 6-speed, second is Tiptronic)
l/100k -- mpg
Passat Sport 1.9 TDI 130: 5.6/7.1 -- 42.2/33.3
Passat Carat 2.5 TDI V-6: 6.9/8.0 -- 34.3/29.6
Not as impressive as the Imperial mpg, but not bad.
Just realized that '98 was the first year for the current body style. A used Passat TDI would be acceptable for the time being...
The diesel V-6, with 228 lbs-ft of torque, represents about the limits of the Multitronic transmission's present torque capacity, however, and Audi still has not worked out how to make the CVT compatible with Quattro, so it's only used in FWD applications.
Future Passats are rumored to be returning to a transverse engine layout, so the W8 engine and the bigger Audi engines will no longer fit. VW AG will probably develop a version of Multitronic for transverse engine layouts, so I'd expect it to appear on Golfs and Passats as well as Audis at some point.
I imagine they're working on making it compatible with Quattro, although they haven't gotten it sorted yet. In any case, future transverse-engine Passats would have to use the Haldex all-wheel drive system (like the European-spec Golf 4Motion) rather than Quattro, so that might present even more complications.
(The brand names are a little bit confusing. "Quattro" and "4Motion" are used generically for Audi and VW all-wheel drive cars, but only longitudinal-engine models -- A4/A6/Passat/A8 -- use the Audi Quattro system. transverse-engine models like the Audi A3/S3/TT and the Golf actually use the Haldex system, whatever the badge says.)
1) it's relatively difficult to get turbodiesels to pass current U.S. federal emissions standards (Euro III and Euro IV emissions have separate, more generous allowances for diesels);
2) each powertrain combination (engine+transmission) has to be tested and certified separately, which is expensive;
and 3) more than 80% of U.S. cars are sold with automatic
(it may also be easier to get the diesel to pass emissions tests in autobox form, but I don't know for sure).
With all that in mind, it makes sense that VW would not want to put a huge investment into EPA certification for different powertrain combos for what's likely to be a pretty narrow sales market. So they may not think it's worth their while to go to the expense and trouble of certifying the manual-diesel combo based on how many they'd sell here.
using the logic above, then lets kill the golf jetta and beetle diesels.
Autos do not = more mpg all the time. Acura TSX is one of several examples that obtain better mpg with auto than manual.
Any Passat diesel is appreciated at this point. This may be the last Passat diesel available and will be the only B5 Passat diesel in North America.
And to repeat what was said earlier, over 80% of US buyers want the automatic.
Sort of off topic but has anyone checked out the CrossLander diesel? www.crosslander4x4.com
It is only offered in a 5 speed;)
Now, whether in auto fashion it gets more or less mpg I don't know (there's no such thing as an auto Diesel Passat here, only Audis AFAIK so I can't compare), but it will largely depend on the gearing. Same for the Acura...
Looks like you'll get the 2.0l TDI, BTW, an all new design, and the first design in which VW manages to put 4 valves per cylinder AND pump nozzles... The advantage of going for an all new design, I guess. The 1.9l TDI is already 10 years old and couldn't have both at the same time
The best feature of a diesel is it's mpg - it should be highlighted (a diesel with an automatic is like Michael Johnson in hiking boots). I doubt they will leave out the manual tranny. When they have their advertisements that show how frugal the diesel is they can use the numbers from the manual to really bring the point home.
mpg 5-speed: 30.4(city), 51.1 (Hwy)
mpg automatic: 23.4 (city), 42.8 (Hwy)
and acceleration from 0 - 62mph:
5-speed: 9.9 sec
automatic: 11.5 sec
There's no contest!
I have also heard that VW will offer the diesel in California and the Northeast.
I'd be fine with a tip tranny. It's a decent compromise for now. I'm sure there will be auto and manual versions in the coming years, but they have to enter the market with the broadest appeal tranny, and I think a tip does that.
I am strongly considering buying a Jetta and if it had more back seat room it would be ideal. Improving that would be my first choice then a close second would be a diesel Passat.
Right now the best option available to me is the current Jetta/diesel. I'd wait until the next model year if they'd bring out the Passat/diesel combo. Not knowing, I'll probably be buying a Jetta soon.
Now if they'd make more practical keys [and fix the leg room] I'd deem the Jetta near perfect.
kirstie_h
Jetta owner
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
8-)
They will all be automatics at first ... standard is not even an option!
But at least its the Tip-tronic and not that old 4-spd POS used in the cheaper cars!
(Actually, the only problem with the 4-spd auto in her '91 Passat was the connections to the "brain" under the back seat ... not the tranny itself)
I think the CVT would be ideal mated to a diesel if they kept it at peak torque.
If not the CVT, I'd take the 6-speed tip-tronic that's in the New Beetle Convertible.
But its my wife's car, and she's tired of the 5-speed in her Eurovan.
Now if only we could talk VW into that 6-speed, DSG tranny that's in the 3.2L Audi TT....
My guess why automatic only is:
- most americans buy automatics
- Passat diesels are low-volume sales, not like Jetta diesels, so they're picking a single configuration for simplicity.
But we're just glad they're going to sell a diesel Passat again ... and we're getting one before they change their mind
I suspect the dealer or salesperson is blowing some smoke in your direction.
