I am going to stay with a CI-4+ rated oil even after ULSD is in place. There will be less soot to deal with but it will still be an issue over the long haul. I will use the Amsoil 15W-40 Synthetic year round. Pour point and flow values are similar to most synthetic 5W-40 oils. Plus,I am moving to Florida in a few months so 15W-40 will be ideal.
Thanks in advance,
Paul
Tom.
Thanks again,
Paul
Farout
The dealer has two 06 CRD's that run rotten, so they come from the factory this way. After my experience there maybe reason to fault the PCM for most of these issues that many of us have had. At least it give others another chance to see if this might help as much for others as it has for me. Has anyone else replaced their PCM, and if so what were your results?
Farout
The PCM is made by either Bosch or Siemens. My guess is that you had a bad chip in the thing and so that is why it gave you grief.
The other possibility is that the PCM was hit by a surge and a chip or two got damaged.
The last possibility is that it says "Intel Inside". They make poopy processors.
I will check to see if I can see what brand PCM it is.
Farout
Farout
Farout
So, since I really don't care that much about the oil (its the dealers problem) I use the 0w-40 that the dealer puts in. It seems then, that all the whining and chest thumping about how terrible the CF rated oil is seems like a bunch of bullsoot to me. After 12k mile oil change if both the soot carrying capacity and the TBN are fine I think that the Mobil 1 0w-40 certainly meets whatever standard is required.
http://www.petitiononline.com/kjcrd/petition.html
It's a good way of attempting to track how widespread the issue is and may also give some credibility when visiting the dealer.
this is the best post on this website. i changed my oil over to amsoil and based on their recomemdation i could go 25,000 miles with filter changes. but as i monitor the dip stick and look how black it is, this sometimes makes me a little nervous. thanks. i will stick with my once a year/12,000 mile plan.
now if someone could prove to me one way or another that turbo cool down in most cases is not needed. read a article from gale banks that says it is not. he now has the world speed record for a pick-up (of course it is a diesel). this guy has alot of credibility.
later
e.t.
If you're an Amsoil fan here's what they say:
"Most oil and especially diesel engine oil will turn black in the first few hours of operation due to contaminates generated by the combustion process and soot particles. The only way to accurately determine an oil's lubricating value or contamination level is through (spectrographic) oil analysis." (link)
Anyone know for sure?
Chief
I shutter to think we misunderestimated Trumpet Washer's question, but my guess is who knows. Jeep's probably afraid the market conditions aren't ripe yet - maybe after the new fuel standards go into effect? Or maybe they think the gas one will sell fine since the gas mpg is supposed to be pushing 30mph city. Maybe they just don't have enough engine production and will leave the CRD to known markets.
How do you wash a trumpet anyway? I bet it involves that icky spit valve. :shades:
Question: Did the dealer clean out the intercooler and air intake manifold? If there was that much oil in the hose, wouldn't the intercooler be full too? I would fear that the entire intake track would be clogging with oil....did the dealer address this? Or have an explanation for why this is happening?
The dealers keep dismissing things like these oil hoses, bad egr valves, shudders after hard acceleration as being "normal" for diesels.....but why then do the Cummins engines these dealers also service not have these problems? While mine has remained trouble free so far, I am growing more concerned as to what the future might hold.
Twocycle2
Twocycle2
Not a problem - it's easy to mix us up since we have the same last name: _HOST
And, yes, I was referring to the CRD that Trumpet was asking about.
As a concerned DCX employee and the means to email the right people,I had sent off a letter to the powers that be.
The letter described how dissappointed I was that the Caliber/Compass displayed at the North American Auto Show didn't have a Diesel engine available to North American markets.
I also pointed out ,how elated I was about about my Libby,and listed the good qualities and how practical I found it,and that I was hoping that the Caliber /Compass diesel could be available to buy here,and that would be a competitive edge on the companies part to let them be available .
I have heard that DCX is going to offer more diesel engines in future products.
It would seem feasable since the market conditions are there,and people are starting to change their minds on this technology.
Since fuel prices are not going down,alot of people are willing to put up with the change of engines,especially since the Asian companies are getting out of the hybrids and into something more realiable and proven,like the diesel.They always seem to be the litmus test to where we are going.
DCX's view is they have an advantage ,and are way ahead of the competition.
So it is possible ,but nothing is for sure until you see it on the lots,right?
I'll keep in touch ...
Lightnin3...
I'm having misgivings about the CRD designation; someone is going to start calling the engines CRuD. :confuse:
Farout
Farout
Because my '06 Libby was under waranty, I took it to the dealer Friday morning, waited my turn, told the service writer "When rotating the tires and torquing the lug nuts, one wouldn't load to torque. I marked it with an X." He writes on the service order "customer says lug nut won't tighten." Mechanic replaces the nut with the X and gives it back to me. Says it had a burr on it. (a burr on it would make it tougher to tighten but it would take torque at some point. He did his job, he got rid of the X.) I asked the service writer how much torque should I use. He said "80 ft/lbs I think".
I got it home, found where the owners manual said 95 ft/lbs. Pulling out my torque wrench, I found all the lug nuts loose and when tightening them, one wheel stud broke. Back to the dealer (torque wrench in hand), wait in line, got my turn. The mechanic walked by, I gave him the lug nut with broken stud. No apology. I told him "95 ft/lbs is what the manual calls for". I could bird dog the work from the garage window. Actually getting a torque wrench this time, he checks the remaining 4 lugs, yep, clicked at 95 ft/lbs. He took off the wheel and brake disk and pounded out the stud. On his way through the shop, I asked to see it. Fatigue cracked about 40% across and yielded the rest. After an hour of hem-hawing, I heard the torque wrench click 5 times and soon the Libby came around the corner. I pulled my wrench from behind the seat and checked all of the lugs in front of them before I left the lot.
To mechanics, are all customers idiots? $5 lug nut cost me 3 hours and $8 in fuel. Did anyone learn any lessons from this? They fully met my expectations.
5 star dealer!!!
I also added in the email that nobody knows what CRD is ,plus they don't advertise the CRD option.Well it's rare to find.
I suggested just putting the diesel logo on the back so most people can relate,in laymans terms.
Hopefully I can get a response soon,for you guys...
Cheers..
Lightnin3...
Farout
-S
DOE Biodiesel Handling and Use Guidlines
But until then we can only hope that they'll come out with better engines,that people want in a vehicle.
I have read in DCX's internet about 2 monthes ago something about Deter announcing that 30 % of DCX's fleet by 2008 will be a Diesel line up.
He probably meant outside the U.S. ,like in Canada where fuel is a dollar more per gallon,that it might be a feasable market condition.
I thought maybe he meant making the diesel option more readily available in these small cars.
I have read also about the possibility of the blue tech diesel being an option in the 08 Gr. Cherrokee,and revolutionary new eurea catylitic filter for reducing emissions.
I guess we'll just have to wait and see what DCX has up their sleeve.
And wait and hope..
Cheers ...
Lightnin3...
caribou1,
what do you mean by "I don't a closed loop." ??
(Caribou1, hope you don't mind my translating)
Caribou1 is a French mechanical engineer that works at the high energy particle accelerator in Switzerland (CERN). He knows his Libby in great detail and offers a unique perspective about what DC is doing outaide the US with diesels.
Farout
Farout
Farout.
Farout
What specific problems did you report to your dealer to get them to replace the PCM? I suspect that my Liberty could use the same thing. My 5th lockup doesn't normally occur until 65 mph.
Mileage has been a consistent 19-20 mpg in mixed city/hwy driving for every tank over the 3,000 miles I've had it. A couple of weeks ago the dealer replaced the torque converter, but it hasn't changed the shift points or mileage. No real difference from what I can tell.
CRDblazr
So my thinking is many of the CRD problems may really be in the PCM, not the trans, or engine. I am real ignorant about how all this works together, but it seems to have got mine in the shape it should have been from the first. Hope this helps.
Farout
