Jeep Liberty Diesel
1120121123125126224
  • zachinmizachinmi Member Posts: 228
    "zachinmi: One issue is the Bio fuel only is good for a short period of time. How do you know if your Bio diesel is "fresh"? I would also add that consistency of Bio fuel above B-5 is a serious issue. As I asked Winter2 what about the makers of the many parts that are in contact with the fuel, that say do not use above B-5? In Missouri it is hard to find much above B-2. I just am not convinced Bio fuel above B-5 is a wise choice, I want to see stats on all the claims made. Are there many over the road truckers jumping on board with Bio fuel? I honestly do not know. What do you think? "
    Farout, I am not an expert on biodiesel, I simply have done a lot of reading. My understanding is that properly made biodiesel is fine for about 6 months and then gradually goes stale til it's fairly bad after 12 months. My understanding is that petrodiesel has virtually identical storage properties unless it is stabilized with additives (which is not automatic for commercial fuel).
    I do not personally know any long-haul truckers but I strongly suspect that they buy whatever is cheapest, which only rarely is B20, since they use huge amounts of fuel and have a low profit margin. If anyone on here is a trucker, I'd like to know what you think! The large engines in semis seem less picky about fuel quality than small diesels like our CRD (or VW TDI).
    I personally think that B20 is just fine if the biodiesel portion is made properly. Unfortunately I can't tell you how to ensure that the biodiesel portion is made properly. You can quiz the retailer on where they get it and what their quality tests are. They should know, and if they don't you might want to hesitate.
    One thing to keep in mind is that problems caused by bad fuel are not covered by the engine warranty regardless of whether they involve petrodiesel or biodiesel. However, the retailer who sold you bad fuel is generally liable for any damage caused by it. I keep all my fuel receipts and buy from a limited number of stations (except when out of state when that's not an option). If I ever have fuel-related problems I will try to trace it to a particular supplier and take it up with them. I can't guarantee that this will work, but it's better than not keeping any records, I think.
    Pure biodiesel (B99 or B100) is a good solvent that can loosen accumulated dirt and can damage seals made from natural or butyl rubber. Most diesels made since 1997 have seals made of other materials that won't be harmed. B20 or lower percentages does not have the same solvent properties and won't normally loosen up dirt to clog your fuel lines or filter.
    Lastly, a lot of bus fleet operators are using B20 because it qualifies as an alternative fuel for air quality purposes. These operators pick one supplier, test their fuel for quality, and have thorogh records on their vehicle reliability. In fleets of school buses (including some here in Michigan - St. Johns) and in city buses B20 has been shown to have no problems relative to petrodiesel when the fuel quality is correct.
    There is a ton of reading on www.biodiesel.org, which is where I found much of the information that I "know."
  • bvcrdbvcrd Member Posts: 196
    Know that I am a Kansas grad, and I can asure you that I am getting high 20s, like 28-29 mpg easily every tank, and 32.8 was my highest with straight highway driving.
    I have never seen a cloud behind my CRD, even when I blow it's nose.
  • lewilewi Member Posts: 4
    I have filled mine up twice now. The first time I got 22.3 mpg. The second time I got .....22.3 mpg. So it would seem I am getting around 22.3 mpg. The second tank included 2 hours of it sitting out in a pasture at a job site, idling with the keys securely locked up inside while waiting for my Mother in law to bring me the spare set. Sure was nice and cool when I got back in it.
    At least it didn't overheat.
  • winter2winter2 Member Posts: 1,801
    Smoke at 10 F is normal. My guess is that it was white or blue-white.
    As to using biodiesel over B5 concentration, the engine in our CRD will run properly and without damage on B20. DCX's problem is that the lack of consistent quality of the biodiesel so they are limiting us to B5. One more note about biodiesel. In the EU, the source of the majority their biodiesel is from rapeseed. It has somewhat different characteristics from our soybean based product.
    The more I research this engine, the happier I am with it. People from Europe who I have spoken with know VM Motori quite well. They have a very,very, good reputation over there and are exceedingly reliable. This is a very stoutly built engine. As long as you maintain the engine properly, and use good quality fuel, lubricants and additives, 250+K miles is not out of the question. The question is, what about the rest of the Jeep. ;)
    $2.239 for E85? How much do you think that stuff costs without all the federal subsidies?
    Without the subsidies, you are probably looking at about $2.90/gallon. :surprise:
    I will take this small clock before I touch a Powerstroke.
    Economists are still debating the extent to which oil is subsidized by the defense budget.
  • faroutfarout Member Posts: 1,609
    Winter2: I appreciate your answers and frank honest opinions. You bring up a point that many don't know. The farmer gets a subsidy for growing the corn for Ethanol fuel, and the fuel gets a tax brake for making even the lowest 10% gas/ethanol and I am not sure if there is a bigger tax brake for E-85 or not. However, I might think with all these subsidies the true cost might exceed $3.50 a gallon. Also this E-10 or E-85 gets significantly less mpg. Now I do not understand how this is saving our Ozone or our air. I heard recently that Hemp was much better to get ethenol than any other plant, flax was listed as well, and flax is a weed. We need to re-evaluate just what and how these BIO fuels are made, and make much better choices.
    Farout
    "Corn...is the "welfare queen of crops." Every bushel of corn currently enjoys a 50-cent subsidy from the U.S. government. The American corn diet is really an oil diet. Corn...is the SUV of plants. Growing it the way we do requires it to guzzle fuel in the form of fertilizer, about a quarter to a third of a gallon of petroleum for each bushel."
    Quotes from The Omnivore's Dilemma. Interesting read.
    bvcrd: I use to have to "blow it's nose" about every 300 to 500 miles. After the tec changed out the PCM which now has been about 1,000 mile ago I have not needed to do that. In fact after that PCM change my mpg went from 22 mpg to 24+ mpg, and that's all local driving. I have no idea what a real trip would do for mpg.
    I noticed this AM when I went to get the mail, that the engine was much more quiet than normal. Maybe it's the 93f temperature it likes better. ( I do not like 93 degrees and 80% humidity) What ever it is the engine is doing real darn good after the PCM was changed. Maybe now if I tried a cetain booster it might do something I could actually notice. I had to add a quart od 5-40 Rotella, as it took 6,000 miles to be down a quart compared to 2,800 miles when it was new. But I could sell the oil for black paint, and that's what it's supposed to look like.
    I continue to check for codes with the on and off with the key ignition, it still says donE, so that's cool.
    What size tires do you have? I have GoodYear Wrangler Silent Armor 245 70 16 T. They are a wider tire and intended for gravel/dirt roads and work well in snow and fairly well on ice. (I have never had to drive on ice yet) Maybe the wider heavy tires might effect the MPG?
    Farout
    Steve: Most of us don't really understand futures and storage and how it all works. But I heard on the farm report on PBS that we have an abundance of corn still in storage from 2004! Some day someone will have to pay for all these subsidies down the road. More than likely our grandchildren's children might have to declare the United States in bankruptcy. We are bailing out all these companies retirement funds that have gone sour, and the jerks that robbed the funds get their hands slapped. These farmers taking these subsidies in reality are working for the US government. One of these days Uncle Sam's pockets and wallet is going to be empty, then what?
    Farout
    Everyone is sympathetic to the farmers but it's big ag (ADM, Cargill, Monsanto, etc.) that seems to benefit the most from the subsidizes. One thing you can do is drive your Liberty to the local farmers market instead of buying tasteless square tomatoes shipped from 2,000 miles away. :shades:
    Steve: In our area there is a farmers auction every week. Mostly Almish type of farmers. These fine farmers take pride in what they grow, and the value is there for the added price. Often the price is higher, but the quality is well worth the price. By the way my wife has almost 50 tomatoe plants, with 4 different kinds of tomatoes. Just about anyone can grow a small garden and get better than store bought.
    Cargill has chicken, trukey, and pork growers by the hundreds here. As well Tyson, which does most if not all of WalMart's chicken, pork, and beef too.
    Can you remember a movie titled Solent Green? Ever wonder whats in WalMarts hamberger? Beef parts are still beef, think about it.
    Farout
    Farmer's Markets are great. Even better is to grow your own tomatoes, they are so much better than any bought in a store. You are right about the mega farms getting the subsidies. I tried farming for 3 years and spent all my money. Had to go back to work in Alaska. No subsidies for the little farmer. They don't have any lobbyist in DC.
    Parts is parts, but there's a big difference in how they are grown and fed. I get eggs from the 4H kid across the street and his chickens eat grubs, not antibiotic laden corn.
    Sort of like buying OEM parts versus getting a stamped fender from some counterfeit operation (how's that for trying to keep barely topical on the weekend?).
    Oh, interesting post/link about CR and their Liberty gas mileage (I guess I mean the diesel mileage):
    avrguy73, "Toyota RAV4 2006+" #3812, 10 Jun 2006 4:14 pm.
  • atvqueenatvqueen Member Posts: 1
    I have read back to April and never saw anyone else doing something so stupid. We visited Phoenix AZ two weeks ago and when filling up, they had a green nozzle on the regular gas pump and also the diesel pump. My husband pumped one gallon of gas into our 06 Liberty tank when it was around half full. We filled the rest with diesel upon realizing. We headed home to Vegas about a 400 mile trip. We kept waiting for something bad to happen. Finally after refueling twice, it "lurched" a few times, but that was it. It actually felt like the tires were out of round. Not sure if that is related but do you think we caused any damage? We actually got fairly good mileage that trip, averaging around 25.5, with husband driving 70. Hot desert dry air the entire trip, lots of hills, etc.
    My second inquiry is that I never get the glow plug light when starting my CRD. I wait for all the lites to go out but none of them is the squiggly thing shown in the manual. Is it possible that due to high heat in Vegas, we don't need to wait for the glow plugs to kick in? We have a Chevy diesel truck so I am not totally new at diesels, although I probably sound like it. Thanks. :confuse:
    I just ordered "The Omnivore's Dilemma" from Amazon. Looks important. Thanks Steve!
  • mdamickmdamick Member Posts: 277
    The glow plugs light off when cold, you won't see that in Las Vegas.
    As far as the gas you had about a 5% mixture at the beginning and less as you refueled. I think you should be OK. The "lurch" could be the infamous "shudder".
    My cousin did that to a U-Haul once. We would refuel every 100 mi or so and it seemed to run OK. The gas stations really should pay attention. BP stations in our area have black for diesel and yellow for gas, a non-standard they should reconsider.
  • lightnin3lightnin3 Member Posts: 153
    Farout , Thanks for the constructive critizm .
    It is true I did the math and by my calculations,you were right !
    27mpg..
    497 miles,with 18.4 gal.U.S in the tank.
    My mistake is I read the OH.console ,but didn't realize it goes down in tight traffic in town.
    Luckily most of my commutes are hiway,so my figures are skewed.
    I have gotten better mileage in the past, I must say,but unlike some meticulous people who record their mileage I haven't.
    Lately on Tuesday and Wednesday leaving work I noticed on the hiway the OH,console peaked at 35mpg at 61mph,on cruise.I was laughing..
    probably due to the recent oil change,and K&N air filter change.
    That 'll bring my average mpg's, up.. over a tank full,
    I'll let you know how I faired.
    I am a bit dissapointed as well, about DCX dropping the 2.8L diesel in the Libby.
    I did let the marketing boys know across the river at DCX headquarters that This vehicle was an exceptional performer,and that I was hoping we could come out with more ,as these are competitive times.
    I think there is another diesel in the works though ,as rumour has it the Asian companies will also start selling their diesel vehicles here in North America as well.
    And with pressure like that, It is possible that they'll re-introduce the option again.
    Zachinmi ..Which Fuel stations do you fill up at in Michigan to get your Bio-Diesel??
    I am thinking of trying the fuel out.
    I commute through Detroit periodically,up to pontiac and northern Michigan,from Windsor,Canada.
    Any info is appreciated.
    Thanks guys
    Lightnin3...
  • whitgallmanwhitgallman Member Posts: 121
    As a forum, can we put together a table showing build date vs problems see? One column could be miles at inception of the problem.
    With a good formal table like this, some of us could fortell when problems might happen or we could guess when DC made corrections that we might ask for OR we could make our case for a class settlement.
    Tables don't work well in the posts because the formatting gets lost. Tabs don't work for spacing either unfortunately. You could post a graphic of a table or spreadsheet though.
    Keeping a FAQ board would be another option.
    Maybe someone could maintain a table on their CarSpace page?
    I get most of my B20 from Swan Fuel Service in Dansville (SE of Lansing) and some from Wacker Oil in Manchester (SW of Ann Arbor). The Meijer stations in AA and Ypsilanti also have B20. Generally it's available in soybean farming areas, but none of that is really in the densely populated Detroit sprawl. I've had zero fuel problems with any of my stations, but I think Wacker Oil is the longest in the biodiesel business, and they also sell B99 if you want it.
    Steve: CR stands for Creative Resource. In my words CR magazine stands for P P. Potty paper, is what it is best used for, and at that it's not much good either. Maybe cat box liner would be better.
    Farout
    Lightnin3: I read that DCX will make some small improvements for 2007, wind noise, and some comfort things. But the 2008 Liberty will be a make over. Perhaps it will be longer like the NITRO. That might be the time they will reintroduce the MB Bluetec, which would have to have more room that it has now under the hood. In my 2005 Limited Liberty, the mpg displayed was usually off by 2 to 4 mpg. I don't miss it at least that feature I don't. Now heated seats, and the better sound system I wish I had back.
    Farout
  • twocycle2twocycle2 Member Posts: 55
    Farout, can you list the exact procedure for doing this? Do you have a list that cross-references the code with the problem?
    thx!
    Twocycle2
    twocycle2: Glad to share what little I know, maybe someone else can add more to help us both.
    Turn you ignition key on and off four times and on the fifth stop with it in the on position. This must be done rather quickly. Do not start the engine. Under normal conditions where the speedometer miles driven are located it will "donE" if there is no codes. If there is a code you can go to www.3800pro.com/lists/obd2codes.html
    or just call your dealer to tell you what the code means. This is not unique to Jeeps, all DCX vehicles have this code check. Hope this helps. Any problems write back.
    Farout
    It's not that I have to blow it's nose. I just choose to. I have gotten high mpg since new on my 2006. I think they got most of the bugs worked out of the '06s.
    Just tried your method several times and no good for me. Can't get it to do anything but tell me the miles.
  • siberiasiberia Member Posts: 520
    crd owners,
    have 12,000 miles on my crd. looks like i am supposed to change the front and rear differential fluid. this seems like very little mileage for this service. is this correct?
    Follow up to Ethom4321:
    I changed the fluid in both differentials for the first time this morning (22k miles) and it took 1 hour and 20 minutes, start to finish. The fluid in the front diff was surprisingly dirty and dark given that it does not get used much - mostly just goes along for the ride. The drain plug was very loose, not even snug, but apparently does not need to be very tight since it has an o-ring.
    The fluid in the rear diff was relatively clean apparently due to a magnet embedded in the bottom of the gear case. There was a fuzzy layer of metal on the magnet which is okay if it has mostly stopped. The original machining marks are not worn off the ring gear, yet. Side case gears and shaft could be a little tighter. Rear cover is indeed sealed with red RTV. Machine marks on mating surface of diff housing look to require a sealer even if a gasket is used.
    Given the magnet and how clean the fluid was, I think I will use a suction pump next time or two rather than pull off the cover. Also, some good news to hands-on people, the side case bearings appear to be preloaded with adjustable collars (requiring a special spanner) rather than using time consuming shims.
  • dmkkengdmkkeng Member Posts: 11
    I have noticed when travelling at 60 mph (100 kph) the engine revs can be at 1700 or 1900 rpm. I'm not sure what changes to drop the engine rpm from 1900 down to 1700 - anyone experience this same scenario?
    Also, at 55 mph (90 kph) with the cruise set and climbing a hill, the transmission doesn't seem to know which gear to shift to resulting in several repeated up/ down shifts -this only appears to happen at this particular speed. Has anyone else had this problem?
  • nescosmonescosmo Member Posts: 453
    bvcr.... When you do it make sure you live your door open. I found that when I do this it work all the time. Also is better to do it after you run the engine... Good l...
    Dmkkeng,
    When the transmission shifts from 4th to 5th gear the RPM drops from 1900 to 1700 at around 60 mph. Cruise is worthless in hilly terrain at 55 mph unless you turn off the overdrives (4th and 5th) using the button on the gearshift. Right before a big hill push the button and turn off the overdrives to lock the tranny in 3rd gear. When you go over the top of the hill turn the overdrives back on or just leave it in 3rd if there is another hill right away. You will do just as good or better on fuel without the transmission constantly hunting for a gear and the transmission will last longer. This is not the only vehicle that hunts for the right gear under this condition.
    Or, you can turn off the cruise and just drive. That usually gives me the best mileage in the hills at 55 mph.
  • dirtmoverdirtmover Member Posts: 14
    Yeah, it shifts to 5th at around 90kph and the torque converter will lock at 100-105kph.
    In the 85-90 range the shift points are too close to work with cruise on an incline. The whole system becomes unstable and oscillates!
  • boilermaker2boilermaker2 Member Posts: 131
    Well, I have been enjoying my jeep for over 18,000 miles now. We've even been through a hail storm together :cry: .
    Mileage (by the tank method) has averaged 21-22 miles per gallon. The best mileage was achieved on a 200 mile 61 mph jaunt (25.4 mpg). I'm certain it can do better but the area in which we live and my right foot does not allow it.
    This Thursday I take my jeep in for the THIRD time to assess/address the same problem.
    Here are the error codes:
    P 0110
    P 0299
    P 0410
    Astute owners/researchers will note that this is an air flow problem affiliated with the turbo.
    Per this discussion board, I tightened all of the hose clamps (6k miles) and replaced the air filter at 6,12 & 18,000 miles.
    It seams to handle pretty much like it has always handled except that the check engine light has been on for 6+ weeks. The last time I took it in for service, it didn't even it make it down the alley-way before the check-engine light came back on :mad: If it weren't after hours and I hadn't already dropped off the loaner keys, I would have left it.
    The one handling issue that I have noted is that is that the engine will get "lost" on a rolling stop followed by acceleration. It really lunges bad and will belch out nice black smoke out the back. Blowing its nose does not help. 90-95% of all of the mileage was done with a premium blend of B2 or B5 Soy Biodiesel.
    Is there anything else I should look for before I take 'er back into the shop this Thursday? Or anything else I should do? BTW, P 0110 will come on AFTER the other two codes.
    Scott
  • caribou1caribou1 Member Posts: 1,354
    Are you not at 2000 rpm in 5th gear when driving at 100 Km/h?
    I have to reach 97 Km/h in 4th under no load to catch the 5th gear.
    I can stay in 4th until I run out of fuel if I don't reach 97! The nice counterpart is that my 4th gear will remain locked down
    to 1400 rpm, until the truck starts to shiver. Thank you for behaving like a diesel, my forgotten egr!
    Hi Scott,
    There is no secret, if you huff and puff black smoke it's the valve again.
    The error codes you posted are related to air flow + temperature. When the valve is stuck open too much exhaust mixes with the intake air, the temperature goes up and there isn't enough oxygen to burn the fuel completely.
    Out here you're caught to pay 600 Euros or get your hands dirty. The 'nose bleeding' as I called it a long time ago comes from the local 'Road Angels' who do emergency service on the european diesels.
    Saturday I heard from a relative working in a Renault factory that the normal life expectancy of an EGR is 30,000 Km (20,000 miles). What do want to do about it?
    It's a simple dilemma: clean it or change it :sick:
    Concerning the "rolling stop", the transmission doesn't downshift if you don't reduce the speed enough. I'm sure it's a safety feature developed by the police.
  • new2dieselnew2diesel Member Posts: 148
    I pulled up to the pump this morning at one of the two stations I use and noticed the cetane rating sticker had been changed from 40 min cetane to 47 min cetane. Looking a little closer I noticed the low-sulphur sticker on the pump as well. To make things even better, the price dropped by 2 cents a gallon ($2.87). This station is a BP station in a rural area so I was surprised. After driving about 25 miles on the new fuel, I haven't noticed a difference so far. I still get the same black smoke when "kicking it" and the noise levels seem to be the same. To be fair, I did have two gallons of regular diesel still in the tank so that may have an impact also. I'll keep you posted over the next week or two as I check the MPG and monitor how she runs. I hope it will improve things a bit. If nothing else, maybe it will be easier on the EGR. Knock on wood but after 18,000 I still have my original EGR in an 05 with July 05 build date. :shades:
  • dzl_loudzl_lou Member Posts: 16
    Hopefully this great book, "The Omnivore's Dilemma" also discusses that the Government does not allow a free-market economy in agriculture. For example, the Government tells farmers how much acreage then can plant and in what grain can be planted in those acres. They also have plans for what is called "set aside acres", i.e. (sorry you can't plant anything there, never mind that it's your land and your farm equipment, and your machinery).
    In exchange for the farmer compliance, the Government subsidizes the bushel of Corn that the farmer does produce.
    Now keep in mind all this interference by the Government, and does the realization large quantities of Bio fuels really make sense that they will be made available? Not really!
    Why?
    Think of a large shift in Corn feed going to Corn fuel. Now think how much your staple meats poultry and beef will cost you.
    Two things the government has to do to prevent Anarchy. Cheap fuel and Cheap food.
    The possible saving grace is that a Liberty could run on ethanol made from straw or wood chips or other non-food fiber. Maybe we should be planting switch grass in all the highway medians?
    bvcrd: Let me say it again in a different way. You must do this in 5 seconds or it will not work. Turn you keep on (to the point the warning lights come on) then off. The switch must reach the off position where you take the key out. here are the exact steps.
    1.Turn key on and off. 2.Turn key on and off. 3.Turn key on and off. 4.Turn key on and off. 5.Turn on and keep the switch on. Within a few seconds either donE or a code will show where the miles or Km's driven show below the speedometer.
    When I do this if I don't get it done quick enough nothing will happen. Then I wait about 5 min. to try again. Try this and tell me how it works.
    Farout
    Steve: What engine can run on ethanol? Surely not the CRD? If it's the 3.7 I thought only 10% ethanol would work, am I wrong?
    Farout
    siberia. Did you do very much trailer hauling? On my Dodge Dakota it said to change these at 30,000 miles but never did any hauling at all. Do ya think it should be changed id no hauling was done?
    Farout
    Thanks farout. Maybe I wasn't quick enough.
    Tried again several times. Still nothing, except the 7321 mileage. I did it flawlessly in under 5 seconds. Bummer!
    Hi Farout,
    When differentials are assembled the pinion and the side case bearings are preloaded under considerable force. The bearings, the pinion gear and the ring gear "run-in" over time. The mating surfaces become nice and smooth and wear slows dramatically but not totally.
    The first fluid change gets rid of the break-in metal particles and probably should be done very early. After that, it really depends on usage. On my V8 Dakota the recommendation was to change to synthetic if towing at capacity for a distance of more than 50 miles. The frequency was 12k miles if towing and 24k miles if not towing - which is what I followed, mostly.
    The CRD is a heavier vehicle with an engine that can throw a lot of low speed torque at the differential(s) especially if you have a heavy foot. I think this is why the recommendation is every 12k miles.
    Anyway, the indication that I got from changing fluid at 22k miles was that the front differential should have been changed sooner. 12k miles was probably about right. The rear diff on the other hand was probably okay to change and 24k miles given that I don't do much towing right now with the Liberty and there is a magnet in the rear housing to clear out the metal particles.
    All those steep hills in central MO are a good argument for 12k changes even if not towing. Load creates wear and wear puts metal particles in the fluid but not nearly so much as the first change. If there is a lot of metal in the fluid each change, the diff is probably not going to last a very long time.
    Another reason to change the diff fluids early is if the vehicle is driven through water as deep as the differentials. A hot diff can suck water past the seals and the fluid must be changed.
    Final point, if you go with synthetic, I have to believe that there is less heat and less wear and the change interval can be extended to maybe twice as long or longer. If you have the dealer change your fluid, have your good service tech give you his opinion on the quality of the fluid that is removed.
    Nope, I said "a" Liberty, not "your" Liberty. Gotta watch for my weasel language. :shades:
    I'm assuming many of y'all want to get away from gas since you're posting about your CRDs ... well, ethanol would be another alternative down the road with the appropriate engine and fuel system, although it may not offer the towing ability and longevitity that diesel use implies.
    I have had times when mine would not read either, Bvcrd. Try putting the odometer on trip. Then go on-acc-on-acc-on and wait a few seconds. It seems like if I do it too fast or too slow it does not work.
  • crdblazrcrdblazr Member Posts: 12
    I've seen a couple of posts here indicating that their CRDs are shifting to 5th at 56-60 mph (90-97 kph).
    I still can't get mine into 5th until I'm at 65 mph (105 kph). What have others experienced here?
