What's harder on a car, age or mileage
I have two cars, and one of them has to go for financial reasons. I'd like to keep the one that will be the most dependable.
The problem is the first one, a '95 T-Bird with a 4.6L motor, while it runs good, has nearly 216,000 miles on it. I'm not 100% faithful in a car that's been driven that far.
So, I bought an '82 Mercury Grand Marquis last summer with a 5.0, and only (at the time) 41,000 miles. Since then, I've had to replace front brake calipers (one froze up), front brake line (one ruptured) the muffles, the dsitributor cap, rotor, plugs and wires (all looked vintage 1982), the A/C doesn't work, the heater core went out, and she leaks power steering fluid (Sometimes barely a drip, sometime a hemmorage). I figured with a low mileage car, I could buy it cheap, and put a lot of miles on it. However, if she's gonna be nickle-and-diming me to death for the next 100,000 miles, I don't want to keep her.
On the other hand, if the 216,000 mile T-Bird is a time bomb waiting to go off at that mileage, I don't want to keep her. So, generally speaking, what would require less maintainence, a newer, higher mileage car, or an older, lower mileage car?
The '95 has been well exercised, and if you have not let lots of maintenance and repair issues go unaddressed, that is definitely the one to keep.
You don't get cars to 216,000 miles when you let lots of maintenance issues go unaddressed.
As far as toughness goes, I think it would be a toss-up. Remember, this is a full-size '82 Mercury we're talking about, not an '82 Honda CVCC or something. Full frame, heavy chrome bumpers, the works. I beleive airbags are the only safety feature the T-Bird has the Mercury doesn't. I've thought about parts, and while its true its easier to find parts for new cars, the old Mercury has a 5.0 engine and an AOD transmision, so, if nothing else, gearheads with Mustangs will keep parts available for a long, long time. In fact, I have a hard time imagining parts not being available for a 5.0. You can find parts for a Ford flathead!
Anyway, I'm thinking the consensus is to go with the high mileage Thunderchicken. I suppose the hail damage and dent on the LF bumper and fender on the T-Bird, as well as the mileage, would kill any resale value on that car anyway.
Then you start to look. First, that power steering high pressure hose has been leaking for 4.5 years - owner says "no problem, I just put in a fresh pint of ATF each week". You look underneath and see the CV boots with jagged holes in them, owner says "yeah, the tire place told me about it, but they said it wouldn't cause a breakdown right away, so I left it for now"...which causes him/her to remember "oh yeah, and they said the alignment was off and the suspension was kind of shot too, but it seems to drive fine, so I just left it".
You go back under the hood briefly, and the rust in the coolant has turned everything brown when you open the cap. And, of course, every gasket that can leak oil is leaking it - the valve cover(s), the oil pan, the crankshaft seals. You point it out as the last straw, owner says "yeah, I have to put in some oil every 1000 miles or so, but the point is I kept all the maintenance up - look, fresh spark plugs!"
And a car like this can very easily be a daily driver, even at 200K+. I can't tell you how many I have seen. Of course, its prospects for the future are dim: it needs well over $1000 just in delayed maintenance items, and that does not even address the repair issues that can be expected to crop up on a car with these miles.
The older car with 41K could indeed continue to nickel and dime you to death, as there are perhaps 15,000 parts in the car, and we have no idea of what has deteriorated.
If I HAD to choose between your two, I'd take the '82, but very reluctantly.
Basically, I see you putting money into two vehicles with no substantial value and not a prayer of appreciation in value no matter how many repairs you make to them or how much you fix them up.
Given that they are depreciating assets with no rosy future in store, I'd cash them both in for something you can work with and rely on.
if I were in the latter state, I would keep the 41K car, but only if was > NOT < a maintenance hog. in either case, I would get a mason jar or mug, and every time I bought $10 of gas, I would put $10 in the jug for a small parts fund. take that jug to a bank that is NOT your normal one after a couple weeks, a month, whatever, and start a savings account. every week or two, dump the mug into that savings account. you want an out of your habits bank because you want to make it hard to get that cash until you REALLY need to fix something or lose your job because you can't get to it.
unless you get into dire straights, I would keep that savings account for parts. running parts, not wheel covers, trim replacements, or washer fluid purchases. not emergency party money. parts. it won't replace a failed transmission, but it will cover most if not all the nickel and dime stuff that has to be fixed for the car to run and be legal.
and again, as I seem to remember the 41K car was a sure boat payment every month for your mechanic, if possible I would trade 'em both in.
I don't know how hard a heater core would be to get to on a Panther-bodied car. I know the smaller Fox-based cars were some of the most labor-intensive in the industry for the time (something like 7+ hours), but the bigger cars are probably better in that regard.
One word of warning though...Ford's early attempts at a 4-speed overdrive automatic weren't too good. The earlier units were prone to early failure, as it took 'em a few years to get the bugs worked out. That's not a Ford-only problem though...also took GM a few years to work 'em out of their overdrive tranny. And Chrysler? Well here it is over a decade later and it seems the bugs have yet to completely bail!
As for trading, I doubt you'd get jack for either one. Probably better to just try selling them outright, if you decide to get rid of them.
That Merc will probably keep nickel-and-diming you, as all old cars do, but it should most likely still be easier and cheaper to fix than the Bird when things do break. Just don't let the fluids get too low, and if anything starts leaking profusely, try to get it fixed ASAP. Once those fluids get out, they can wreak havoc on other things they get into. For example, an oil leak can kill your engine mounts, suspension bushings, and anything else rubber it gets onto. I'm sure power steering fluid and tranny fluid can do nasty things too, and brake fluid is highly corrosive.
As far as fluid leaks go, I have an interesting one on the '82. It intermittantly hemmorages power steering fluid. It'll go weeks without leaking a drop, and then I'll come out, and there will be a big puddle of it under the car, and I'll have to top up the resevoir. Dangdest thing I ever saw. Like I said, the car seems to like to nickle-and-dime me. Neither car has had such a catastrophic failure they left me stranded when I needed to go somewhere (not counting the time I ran out of gas on the way to work!), but I've had to fix a bunch of little stuff on the Merc, and the T-Bird's extremly high mileage has me concerned that she's living on borrowed time, despite the fact that she's been super-reliable up until now. Anyway, I wasn't planning on keeping either of them forever. Just something until I can get my finances turned around, and get something decent.
If you sold both cars, you wouldn't have much cash in hand to upgrade.
The T-Bird has already gone much farther than most. With those miles, it's on borrowed time.
The Merc is *probably* the car to keep until you get back on your feet. Respect it's age and be gentle with it. Keep a close eye on the fluid levels and otherwise put as little money into it as possible.
Harry
if you really have to go for "right now" and not right on the fixes, glass and build out on the backside, and once that's solid, dig out the crack a little on the front and run some filler into there with a plastic applicator. it'll keep the fender on if you're not in 40 below territory.
Paid $ 2400
Are these belts not what they're cracked up to be?
