Toyota and Lexus have long been ahead of the curve in implementing these new aspects before they become law and I suspect that this is just another case of their "leading the pack".
The only answer I can see for the future is to only buy cars with the sequential shift feature and then always run it under at least that level of manual control.
For those of you who might be interested it appears that ALL of these new 5-speed transaxles have the three electrical inputs required for sequential shift mode/operations but no connections to tyhe cockpit.
I am NOT suggesting anyone immediately run down to the neighborhood automotive store to buy a performance enhancer, and yes, I am aware the device would probably void one's warranty. That's decidedly a no brainer.
My ONLY reason for raising the point was to show how solutions are already out there. This is, after all, a "problems and solutions" forum.
And yes, different makes/models of cars require different performance enhancing devices. That's why, when one buys one of these devices, it is necessary to specify which make/model one owns, so the appropriate device is purchased. They are make/model specific--look it up on the net.
They come in all styles and shapes, with a variety of operating characteristics and user features. The simplest ones are straight replacement CPU chips, non adjustable nor programmable. Some factory chips are non removeable, so in these cases the performance enhancing device installs in line with the transmission CPU harness. For some units, what's changed stays that way until the new chip is replaced or the unit running in parallel is removed. High end units are dashboard mount, infinitely programmable, and are capable of providing a variety of different performance characteristics, even while in motion.
No matter how one slices and dices this issue, it's not the deep, dark, unsolvable mystery that it's thought to be.
That's all I'm trying to say.
Were you to do so then your assumption would be that an aftermarket third party programming group is better than the factory and that's simply not going to happen.
If you were doing it to improve torque/HP for track use then the new bugs you will surely encounter might be tolerable, otherwise.........
Look my friend, all I was trying to do was illustrate there's more than one way to skin this "elusive" hesitation cat. It isn't that elusive, and I believe you, more than most,should know that.
These performance enhancement devices I've researched aren't for "track use" or "dragster application" or any other "competition" purposes. They're just another way to change one's transmission characteristics for a more user compatible attributes--assuming that's what the user desires. And they're cheap, easy to obtain, and there's lots of them around so the proof of their effectiveness is beyond question. Besides, any developer worth his or her salt knows the algorithms we're talking about in CPU transmission controls are about as simple as it gets. CPUs in these applications aren't quite the same as Lunar Landing Module controllers. I'm sure you have great programmers in your company, but they aren't any better or worse than a great many others out there. The application here is a relatively simple one, so it shouldn't be made to look more complex or difficult than it really is.
Now I will post twice, but the second time will be in that other forum you responded to me in--just in case you miss this one.
1. There is not more than one way to skin this hesitation cat. There is not even one way, or Lexus would have done it!
2. If this is a simple, inexpensive software problem, that is known to boot, Lexus would be providing a fix to be done under warranty.
3. Proof of effectiveness may be well known, but if you are referring to the complaint on this board, I take issue with your statement. This is the most active of the Edmund's ES300 board and there are still complaints.
I think your statements support and do not detract from the theory that if the transmission problem had a simple and known solution (software only) Lexus would simply ship an update to be implemented under warrantly. Problem solved; no more complaints.
But Lexus/Toyota has done no such thing, indicating that the fix is more than a simple software firmware solution.
In other words, I believe that your statements are true, which proves to me that the problem squawked on this board involves both hardware and software, which would be expensive to fix.
hylyner, I responded to your duplicate post in the Toyota-Lexus transaxle shift delay forum but all these duplicates in several different forums gets a little confusing, so I am not going to repeat it here. That forum may be the best venue for general discussion of the problem that is not specific to any one of the Toyota/Lexus models involved.
Initial complaints started in 2002.
No fix as of yet......
But you miss the real point. The part that seems to be the most elusive is the fact that a very few are experiencing the hesitation delay symptom. I have little doubt at this point that Toyota has already implemented all of the gas saving features described in the Sierra Research article within the firmware of all of the new 5-speed transaxles. But why has that resulted in a very few instances wherein this implementation results in a very noticeable, maybe even unsafe or hazardous circumstance?
Therein lies the elusive firmware "BUG".
My suggestion at this point is that Toyota should provide a transmission mode inverse to the "snow" mode. Basically a mode switch (shades of Edson DeCastro/Tracy Kidder) wherein the owner tells the transaxle to be aggressive with the shifting logic, "expect that I will floor the accelerator pedal at any, the very next, moment" and be prepared for same.
That said, I choose not to defend what I felt were helpful "food for thought" posts, nor will I take part in shooting them down with criticism when ideas like them appear.
I explained very clearly why I posted what I thought might be helpful, so perhaps it's best to just leave it at that.
If I come across any more constructive solutions, rest assured I'll do the same again.
My solution has been to drive the car (a 2003 Lexus ES 300) more like a manual transmission car. In any situation where I feel I possibly may need instant power, I manually shift the car into 3rd gear. I think the shifting around of the gear lever also affects the shifting algorithm in general (at least for a while).
In bumper to bumper traffic, I use 2nd gear much of the time and enjoy the engine braking affect.
Just as my input was not "the" solution, Wwest's are "other" solutions, and--what you propose is yet "another" solution. This is good stuff!
My feeling re what these forums have morphed into isn't what they were intended for. As I said above, there seems to be much more emphasis on "blame" than anything else. The process should be "define the problem" (that hasn't been done here)--then look for solutions, but it's gone the other way 'round IMO.
It seems to me the "solution" has already been agreed upon, regardless, and the problem is continually being adapted to the solution.
Wrong way to go about it, IMO.
Remember my idea of modifying the IAT? Or the one about it being the inappropriate use of a solenoid as a linear servomotor? Those went absolutely no where, and for good cause I now firmly believe.
Start to think of it as a back and forth discussion, a fully open discussion.
The fact that many companies are offering products/services to correct the problem does not mean that they work either. As an analogy, there are hundreds if not thousands of hair restoration remedies on the market but that doesn't mean that they all work. It just means that the problem is big enough that companies think they can capitalize on it.
Well, you could start by learning more about why it affects only a few vehicles and not most others. Is that a design anomaly, a driving style problem, a sensitivity thing, something unique to that particular vehicle, and so on. If it was part of a design thing, then ALL of them should have problems--but that's not happening at all.
No,don't bother to look elsewhere-- it's a big bad Toyota thing, blame it on a design flaw.
Then there's a big mystery about the TSB. Why does it apparently work for some and not others?
Could it be dealers aren't doing it right---or not doing it at all--or some aren't even having it done--or what?
But no, it's a big bad Toyota thing, blame it on the design flaw.
I could continue, but why bore you with a search for facts. I'm sure you're not interested, much less want to learn all there is to know about this issue. It's much easier to blame, blame, blame--that's become the predetermined name of this game IMO.
As for the TSB - my car is actually WORSE since the TSB. I know there are several people here in this forum for whom the TSB remedied the problem - so I would still suggest it to anyone who hasn't had it. It just didn't work for me....
This phenomenon is a combination of the following:
1. The fuel economy focus, whereby the transmission is told to shift into a higher gear as soon as possible, or into neutral, based on certain circumstances.
2. The concept someone touched on about protecting the clutch. When the car is in the higher gear, or neutral, and its now time to switch into a lower gear (or into gear) - some type of protection mechanism that is causing a delay.
3. The Drive By Wire (DBW) technology, which maybe does not react as quickly as a hard-wired cable (I've seen this in waterski boats - Mastercraft had a huge problem with this a couple of years ago - but they ultimately found a fix....- don't know the specifics though)
Those things make sense to me - based on what I experience in my car. The problem is that I haven't been able to pinpoint those exact circumstances where this delay occurs, such that I could stop doing whatever that is.
I have concluded this is in fact a design issue. I've come to that conclusion not only based on what I've experienced, and what I've read here - but the dealer and the Mfr Rep both said 'its doing what it was designed to do'.
As far as why only some cars do it, I've concluded that it is definitely driving style and circumstances based. I've come to that conclusion because I experience the same exact symptoms in EVERY Lexus ES I have driven (i.e. loaner cars at the dealer). And further, the dealer and the Mfr Rep both told me that this is something that only a percentage of the population experience, and they told me that I would experience it in all ES models.
So, given all of this, I don't understand why either the dealer, or the manufacturer, won't help me get out of this car at a price where neither of us will loose (or make) money.
There is another ES here in town that has written 'I hate my Lexus' on the windows.
I may actually try that myself....
Do you really want a solution to your problem or want to post the same tiresome tirade over and over again. Obviously, you are not pleased with the car. How many times do we have to listen to that same drivel. Why don't you just sell the car and be through with it ? Your success in arbitration or lemon law probably won't be that good. JUST SELL THE CAR. PROBLEM SOLVED.
First, let me tell you that I do not own a hesitating Toyota or Lexus. I own a pretty responsive Toyota Sequoia, but I have experienced the hesitation as a passenger and have family affected by the problem. That said, I wanted to comment on your experience of being able to replicate the problem in every Lexus you have driven. This may be your experience, but complicating matters, is that I don't think it is the experience of everyone. An interesting experiment would be for you to find someone with the same model year who does not experience the hesitation and trade out cars and see what happens. Have you had others drive your car? Do they feel the hesitation?
p.s. shepali, after reading the previous post, it appears that some do not like what you have to say. This is a problems forum and you have every right to express your opinion without someone calling what you write "drivel"-- getting a bit personal IMHO. Anyway, just wanted to say I appreciate your input and the light you have shedded on the issue.
Yes, the DBW system firmware has an acceleration delay incorporated but that is there to protect the drive train, give the downshifted transaxle clutches time to fully and firmly seat before the engine starts producing tons of torque.
Were the transaxle not so quick to upshift it might still be in the proper gear for acceleration and the delay would thus be unnecessary.
i am still holding onto a HW non-linearity theory (either pedal actuation or sensing, or Trottle body actuation or sensing) complicated by the learning software.
however, i'm also believing that we are talking about some different phenomenon here (lag for different reasons or gear hunting, or shift shock).
So, are you saying that other people that DO experience the problem, DO NOT experience it in every car they drive? I haven't heard anyone confirm or deny that, but may have missed it. I did see the guy who said he could get anyone's car to do this - some people didn't believe him - but I actually think that I could as well.
I am in the process of trying to get in touch with someone I know that does have the same model year car as me, to maybe try this experiment (if in fact she isn't experiencing the same symptoms) - but no, to date I have not. But, ALL of the ES loaner cars I have driven (3, I think) have exhibited the same symptoms, albeit in differing intensity - and I have to assume that other people don't have the problem in those cars.
Other people that drive my car do experience the hesitation - that would include my husband, the service people at the local dealer, and the Lexus Mfr Rep. And people that ride in my car notice it as well.
The explanation I was given by the dealer to this phenomenon is that it has to do with the learning ECU module, and that the module takes about a week to learn new habits. So, if my husband drives my car only once or twice a week (which is the case), that the module would still be programmed for my 'driving style'.
What that doesn't explain is why it doesn't take a week or so before I notice the symptoms. I mean, if that were true, and the loaner was driven by someone with 'Lexus approved' driving style, then I shouldn't experience the symptoms. So, that brings me back to - it must be SOMETHING I'm doing....but WHAT?????? :confuse:
So, what really is DBW? I thought it was just an electronic communication to the engine, rather than a mechanical communication. But I must be missing something based on your comment. I would have thought that any acceleration delay would have been a software attribute - and therefore adjustable.
And when you talk about the clutch and protection - again, I think software setting.
Having said all that, I think that what you described is in fact some (or all?) of the problem. That delay you describe sounds a lot like what I am feeling when the so-called hesitation occurs.
Here's an example - I'm driving around in a parking garage that goes up/down in circle, and each circle intersects with oncoming traffic. When I approach the intersection, I take my foot off of the gas pedal so that I can look both ways before I pull out to merge. I put my foot back on the gas pedal to pull out - but nothing happens. I keep pushing, instinctively, and then all of a sudden, the car figures out it needs to either downshift or actually engage into a gear (not sure how to tell the difference), and it 'jerks' or 'clunks' into gear, and 'lurches' forward throwing my body backwards into the seat. This then happens at each 'intersection' of each circle in the garage. Very annoying....
But user777 has a point - if what you are describing is true (which it seems to make sense to me), then why don't other people notice it? :confuse:
When I depress the gas pedal on the C4 the throttle plate follows in complete and total synchronization right up until the engine reaches the rev limiter. It is totally and completely my own personal responsibility to be in the proper gear ratio for the acceleration rate that I desire (no lugging the engine) and to coordinate the gas pedal position with the engaging of the clutch.
The DBW firmware in the Toyotas in question is seemingly different in that it "knows" that if it allows the engine to develop torque BEFORE the transaxle has completed the downshifting into the "most" appropriate gear for the acceleration level you desire then early transaxle clutch failure would probably result.
And therein is the "RUB".
The Toyota engine/transaxle ECU DBW firmware has no method, other than the current roadspeed and the current gas pedal position, of "knowing" just what level of acceleration you really desire.
The firmware controlling these transaxles has apparently been specifically designed to put you into the highest gear possible, 5th with lockup, or maybe even 4th with lockup, at the very earliest time possible.
That means that any time you release the gas pedal even slightly, and certainly fully released, it will quickly upshift into the highest gear ratio that is reasonable given the current roadspeed.
But now you suddenly change your mind and depress the gas pedal, possibly just after the firmware has begun the upshift sequence. So the ECU "asks" "just how serious is he/she?", there are at least two possible gear ratios for it to downshift into and given the edict of fuel economy FIRST unless that was a serious "punch" of the gas pedal it will always chose the most conservative gear ratio, say from 5th to 4th.
In the meantime you have noticed the delay in initial acceleration and human nature dictates that your reaction is to depress the gas pedal just a tad more.
Oops, says the ECU firmware, he/she really wants to accelerate more rapidly than I first thought! The ECU cannot cancel the previously commanded downshift into 4th, it must now wait for that to complete and then command a downshift into third.
With each downshift taking on the order of a second or so you may find situations wherein the throttle plate does not react to the gas pedal position for 1 to 2 seconds.
The above is only a theory of mine but seems to be validated by what I have learned about the transaxle in my 2001 AWD RX300 and the newer 5-speed transaxles.
Also, there have been indications here and there on these forums that quick and firm, non-hesitant, applications of the gas pedal alleviates the delay symptom.
My 2001 AWD RX300 exhibits much the same gear changing procedures as proposed by Sierra Research. My 2001 AWD RX300 does not have DBW so during the resultant downshifts the clutch surfaces must endure an unusual level of wear. That is very likely why the earlier RXes are showing a level of premature transaxle failures heretofore unheard of for Toyota vehicles.
Hesitating Lexus unsettling for owners
Hesitation issue goes beyond Toyota's luxury line
there are 49 comments on this story with other owners explaining there transmission problems
One of those other tasks may be to derate the engine when another subsystem detects wheel spin, or the vehicle is beginning to yaw excessively.
Not only does it open the door to better fuel economy, it is an integral part of coordinated automation for improved safety.
One of the ideas I posted was that perhaps the much sought after "fix" was already out there because there are a number of commercially available performance enhancing products which do exactly what many of you suggest should be done. My point was simply that the technology already exists.
My ideas were quickly dismissed as worthless, meaningless, etc., by some, and the discussion soon returned to what I've come to regard as somewhat of a blamefest with little or no interest in solutions.
So I said I wouldn't argue or defend with "ye of little faith" and would simply post any further ideas that I felt might be constructive or helpful in this neverendum search for whatever.
So I googled "Car Buyers Remorse", and found literally thousands of informative articles on how pervasive that phenomenon is. I honestly believe that phenomenon is hard at work in these forums!! Wow, 78 percent of car buyers have remorse about their purchase!!
From the googled info, I reached an important (IMO) conclusion--that is "An ounce of prevention is worth a pound of cure!!!" (Old, but very wise piece of advice)
Here's what one of many articles says (relevant advice highlighted) about one good way to prevent disappointment:
78% of Car Buyer's Suffer "Why Did I Ever Buy That? " Remorse
Majority of Car Buyers Have Wanted to Return a Vehicle Within First Few Days of Purchase
RICHMOND, Va., Feb. 1, 2006 -- A recent poll of almost 49,000 car shoppers conducted by CarMax, Inc. on the company's Web site shows that 78 percent of car purchasers have wished they could return a car within the first few days of buying it. Only 22 percent of respondents had never experienced buyer's remorse.
When asked the question, "Have you ever wished you could return a car within the first few days of buying it?" visitors to carmax.com answered:
Answer Number of Respondents Percentage of Respondents
Yes 38,421 78 percent
No 10,553 22 percent
"An easy way to prevent buyer's remorse is to check the seller's policy on returns or exchanges before purchase, much like you would if you were buying merchandise from a big box retailer," says Joe Kunkel, senior vice president of marketing and strategy for CarMax. "CarMax offers a five-day, or 250-mile, no-questions-asked, money-back guarantee. Traditional dealer policies overwhelmingly vary from no money-back or exchange policies at all to policies that only allow an exchange. This is just another piece of the car buying transaction where it pays to be fully informed before signing a purchase contract."
CarMax is the nation's leading specialty retailer of used cars. Headquartered in Richmond, Va., CarMax currently operates 48 used car superstores in 22 markets. CarMax also operates 12 new car franchises.
If you are reading this and you feel hesitation when you step on the gas pedal when driving around town, keep the transmission in position 4 when you are driving around town. You still get an occasional rough downshifts, but the hesitation issues will be much improved. You will notice a slight decrease in fuel economy.
I go a step further and shift down to position 3 in any situation where I feel I might need instant power (like accelerating onto the highway) and I am travelling in that dreaded near 30mph speed.
Once the car is above 45 mph, you can shift into D. When you drop below 45 mph, shift back into 4.
This shifting around I do defeats the shift logic of the transmission since I am overriding it.
If this is all too much for you (you really want a truly automatic transmission), sell the car and try a different brand. General Motors gets criticized for mainly selling vehicles with 4 speed automatic transmissions because they are not that "advanced;" but you are now aware of the downside (for a minority of drivers) of these "advanced" transmissions.
Question is - now what? Is there any way for me and the car to adapt to each other? Or, am I destined to not have a car with this technology?
And if the latter - how do I know when I'm evaluating a new car, whether it has this same technology? Cause right now, I am totally gun shy on buying a new car - for fear that I will make the same mistake again.....
Do any of you know if the Nissan Maxima uses this same technology? Or how I would find that out?
Once I figure a way out of my ES, that's what I've been considering as a short-term replacement....until I can get my head on straight again about what I really want in a car...
Just a heads up 4U re your Maxima query. It does have the same technology, with similar complaints BTW.
An excerpt from the Maxima board---I think you'll agree it sounds vaguely familiar...
"The problem you are having seems awfully akin to the surging we've been complaining about on the Maxima 5 speed. In our case, it's not the transmission, it is the ECU causing the problem. When you are using very light throttle, the ECU tends to take control from you making it hard to drive smoothly. This can give you whiplash trying to drive in 1st gear at parking lot speeds and causes car to surge a bit at highway speeds with the cruise control on (and some report much worse behavior going down long downgrades at highway speeds). The torque converter on the automatic will normally mask the problem but with the lockup clutch bypassing the torque converter engaged, you can probably feel it on the automatic.
Check out the first few posts about the 5 speed for a full description of the problem (note there is a TSB out for this problem as well). The TSB has been posted to the board."
Shepali, make sure you're not going to require another "Hate My Car" message on your car window. Also, probably not a good idea to say anything about this at your arbitration as well.
Also, find someone who has bought from the same dealership and see what they think about the customer service there and if they had any problems addressed under warranty. Nearly every new car I have purchased has had some warranty related issue and fortunately all were resolved satisfactorily, including probs with my current Sequoia, including a problem with a rotten egg smell that they corrected with a new cat. converter. It sounds like you aren't happy with the customer service you are getting from your Lexus dealer so you want to make sure you don't run into that again.
Toyota has made it quite plain, publically, that they will be the early adopters of any new technology that results in improved fuel economy and lower emissions.
Since Sierra Research is clearly a consulting resource for CARB Toyota has apparently decided to lead the "pack" yet again, still, by adopting these SRI "suggestions" before CARB manages to make them mandatory.
Question: Has anyone having these hesitation problems ever experienced any diagnostic indications that the accelerator position sensor is faulty or was intermittent?
I'm still not certain, by any means, that the fault doesn't lie, somehow, within the dual hall effect accelerator pedal position sensors.
personally i would not limit myself to the accelerator...there is a position encoder on the throttle body.
i think way back i suggested someone with a reproducable and acknowleged problem essentially beg for mercy at a dealership and suggest these components to be swapped...
remember the "no guts no glory" post?
ok - consider this as well, wonder if it's not a position encoding problem, but mechanical sticktion in the throttle body? woa. what a possibility.
Also the dual throttle position sensors and the throttle valve are driven by a common servomotor and were the sensor outputs not to "follow" the commanded movement of the servomotor that would be quickly detected and reported as a major component failure.
On the other hand since your foot is the "servomotor" the accelerator pedal sensors have no method of cross-checking other than the validity between the two sensors themselves, which, according to the manual is done continually.
If one of the two sensors was intermittent, occassionally gave a position reading not consistent with its opposite sensor then the ECU would undoubtedly consider that reading invalid and by default, failsafe, "report" the accelerator pedal to be in the "neutral" position.
It would be anyone's guess as to how many valid readings, contiguously, it would then take for the system to consider the sensors to be giving valid readings again.
I have no doubt that once an invalid accelerator pedal position reading occurs there would follow a period of defaulting to the pedal being at the neutral position.
Begins to sound as if it could be the exact thing ocurring, huh?
Think about this, the accelerator pedal sensor outputs are analog, and therefore must be "read" by the ECU via an A/D, analog to digital converter. Unless some sort of sample and hold circuit is used to trap both voltages absolutely simultaneously, the ECU first samples one sensor and then the other. In the normal scheme of things this occurs so very rapidly that for all intents and purposes the signals are sampled simultaneously.
But suppose some highly important "other" function (VSC Yaw sensor??) just happens to interrupt the ECU A/D converter sampling/processing between the two samples. "Highly important" because "normal" interrupts would be locked at at this stage.
In point of fact the industry standard CAN (Controller area network) handling the VSC/Trac/ABS, etc, communications is entirely separate from the Toyota propriatary BEAN (body electronic area network) handling everything else, including the engine/transaxle ECU communications.
I could readily see that an input from the CAN system would be allowed to interrupt almost any process in the BEAN system.
Hmmm...
Some posters have stated that the symptom often occurs during a turn, a time when the VSC system might be highly active.
then again, there may be a non-linearity due to slop between the mechanicals and the encoder(s)...
but you touch on another valid possibility, with all the integration and distributed subsystems, it's entirely possible a rouge subsystem is generating too much traffic, resulting in collisions, retransmits, and even missed parameter reception and/or time-slice "over-runs".
I honestly think much of what you're talking about here is way over most participant's heads. Besides, it doesn't really leave much room for others to participate.
Whaddya think? Any thoughts by Mr. Shiftright?
If you (or if the Lexus 300 owners) want a more technical discussion they should all be over in the "Shift Delay" discussion.
So if you a)don't own a Lexus 300 and/or you want to discuss the technical aspects of Lexus transmissions, you should be there, not here.
This discussion is intended mostly for people who don't particularly care what is causing the problem but want suggestions on how to get Lexus to fix it or how to arbitrate, etc. (service/consumer issues)
So if you are posting highly technical stuff here you are in the wrong discussion, yes.
thank you, and I hope that clarifies things.
suggest to your dealership they replace your throttle body assembly and road test the vehicle. if that doesn't work, suggest they replace your accelerator assembly and road test the vehicle.
report success or failure for one or both procedures to mitigate the issue here in this forum or the other forum on "Shift Delay". everyone would benefit by the effort and report.
i trust that if anyone had a problem following a previous post regarding "position encoding", "sticktion", "slop", "non-linearity", "time-slice overrun", etc, they'd either google the terms or ask. i don't presume people aren't able to follow a technical line of reasoning, but understand it may not be of interest to everyone.
unfortunately NOONE is providing definitive information as to WHY the hesitation exists or does not. therefore, there is a great deal of speculation and theorizing on the matter...
a few experiments have been suggested to narrow the problem down, some in a forum which has been marked read-only.
with the two suggestions above, the experiments i have proposed now total at least three. the other involves the use of an OBD-II interface and laptop computer.
http://townhall-talk.edmunds.com/direct/view/.efe9615
And, although I would be open to the experiments - given that I have experienced these symptoms in ALL ES330's I have driven - I'm not too hopeful that replacing these parts would do any good, unless they replaced them with different brands/versions of those parts.
On a side note - I don't mind all this technical talk, but I do not understand most of it. Having said that, I am starting to learn things from it. But, I do appreciate when you guys summarize into action items as you did in the reference post
it might be helpful to know if you are giving the vehicle just a little throttle or more.
tell us specifically what you are noticing with respect to the RPMs changing as you apply the throttle in these scenarios.
btw - do you live in an area where there is only one Lexus dealership? i ask because, even if the manufacturer's rep and your primary dealer rep aren't interested in trying anything else, another dealership just might, depending on how you approach them. again, even at your present dealership, you don't know if they are willing to try something else unless you ask (in the right way), and you have said they were working with you... hope you have all the things they did try documented.
lastly, if there is any technical jargon i'm using that is throwing you, as advised by the host, we can discuss it in the shift delay forum.
also know this - because you can repeatedly reproduce the hesitation (if it is a hesitation, not a hard shift for example), then you may be a candidate for the experiment proposed in the shift delay forum.
Poster after poster has beaten his or her head against the wall on this particular dead horse! Do a search on poster texas83, for example. He expended all kinds of energy on the problem, pursued the Lemon law and never received a satisfactory resolution to the issue. All he got was a replacement ES300 for his considerable efforts, and of course this did nothing to fix the problem.
Yes, it takes time and energy to read old posts, but not nearly as much time and effort as trying to get Lexus/Toyota to fix a problem that they do not even see as a problem!
These posts provide lessons learned and I can't understand why new posters do not take advantage of this! All I can say is "Geez Louise". Accept that this problem cannot be solved except by a major redesign - which Lexus is not going to do - and move on! Unless you want a major headache from beating it against the wall, that is!
PS - I guess I keep posting on the thread because I am addicted to it or a glutton for punishment or something!! No matter how much I vow to keep away from the thread out of frustration, I keep coming back. :-)
So I disconnected the MAF/IAT sensor connector on my 2001 AWD RX300 while the engine was running. The engine died almost immediately and wouldn't restart. When I reconnected the MAF/IAT it started right back up but with an engine & VSC failure indication.
After about 4 drive cycles the indications went out.
So for any of you that are experiencing the extended delay/hesitation symptom if you want to try and see if VSC is somehow related.....
