Transmission problems with Lexus ES?
1161719212228
    hylynerhylyner Member Posts: 216
    Our new Avalon has some "hesitation", if you want to call it that. But not for long. At speeds of approx. 25 to 30 MPH, when I floor it (WOT), there is a momentary hesitation while it downshifts--maybe .5 seconds (or less perhaps, because I've never timed it)
    Then it really goes like stink--I bet it pulls a "G" or two. Accelleration is really exhilarating!!
    No problem whatsoever from my perspective. Sorry folks. I think it's great.
    "....Personally I think not."
    Apparently Toyota disagrees with you. Somewhere I just read that the latest version of transaxle firmware is accomplishing downshifts in 0.5 seconds, "more than twice as fast as previously". That is in line with the shop manual stating that the shift from neutral to "drive" takes 1.2 seconds.
    What is the typical time it takes a stick shift driver to downshift from cruise to accelerate? That should be Toyota's transaxle downshift "target".
    "...something wrong..."
    Yes, IMMHO this whole episode begin with the earlier 4-speed transaxle versions being far too willing, too quick, to upshift. I have little doubt that that has resulted in the premature transaxle failures many RX300 owners are experiencing. The RX300 is not DBW so the engine torque is rising during the downshifts which would be needless were not priority given to upshifting so quickly.
    I don't think that's true. If the manual says 1.2 seconds for your RX--which is either AWD or 4WD, I believe, then you're comparing apples and oranges. The .5 downshift time you refer to is a quote from their just published press release for the 07 Camry--a 6 speed tranny BTW. Whole 'nuther thing.
    If 1.2 nseconds is what the book says, and that's what one gets in their vehicle, then it's performing as designed--ergo--"nothing wrong." But then again, you're reading from an RX shop manual. This forum is for the ES 330.
    Ahhh, What the heck. It's Happy Hour here in the East!!
    I would be willing to place bets that there is no difference between the 4-speed transaxle in my RX300 versus an equivalent MY V6/4-speed in any other Toyota/Lexus vehicle. I'll even carry that offer forward to any Toyota/Lexus V6/5-speed being the same as any other Toyota/Lexus V6/5-speed of equivalent engine capacity.
    Toyota is in business to make a profit, not to build unique transaxles for equivalent needs/applications.
    Otherwise the RX400h might very well be an RX270h using a "unique" I4.
    "....nothing wrong."
    And I don't disagree insofar as the transaxle taking 1.2 seconds to complete a downshift. What is actually wrong is that the firmware design as it is today, giving such high priority to quickly upshifting, results in far too many inadvertent downshifts.
    And as (bad) luck would have it all three of the circumtances described in the TSB are ones in which the inadvertent downshifts are amongst the most stressful the transaxle will be expected to endure.
    Going from "cruise" O/D lockup into quick and rapid acceleration.
    Not good.
    shocasershocaser Member Posts: 36
    Any company that uses the tag-line "The Relentless Pursuit of Perfection" should expect high expectations.
    I guess that my major problem with this, beyond the actual problem with the car, is this: I view the ES as an entry level Lexus. I would expect to move up the chain within the Lexus line. However, when I experience this type of problem and get the reaction that I have from Lexus, I will am seriously put off.
    Just make the car work right, Lexus. But I don't expect that to happen. The problems that I have had with my car go beyond the transmission. I am tired of taking my car to the dealer for the same problem and not getting it fixed.
    implied never reaching your goal the motto was changed.
    "The Passionate Pursuit of perfection"
    nvbankernvbanker Member Posts: 7,239
    You're sure it's the Transmission, and not the throttle by wire design, that takes a fraction of a second to respond to throttle input? That's what I've heard it is.....
    The DBW throttle is taking more than a second to respond to a newly depressed, or farther depressed, accelerator pedal but that aspect is intentional, embedded within the engine/transaxle ECU firmware.
    In order to protect the drivetrain, needless wearing of the frictional surfaces of the various clutches within the transaxle, the onset of engine torque is delayed via the DBW system until the resultant downshift is completed and the newly engaged clutches are fully and firmly seated.
    es4jbes4jb Member Posts: 17
    1. Drive like a bat out of hell.
    2. Start fast off the line.
    3. Live the motto "the relentless pursuit of acceleration".
    4. Forget about "D". Drive in 4th gear. Leave "D" (overdrive) for highway cruising speeds or geezers.
    5. Any time the transmission even considers downshifting, step on the accelerator like you MEAN it. Don't be a [non-permissible content removed].
    6. Downshift to 3rd gear just before entering a freeway on ramp.
    If you do this you will successfully train your Lexus to forget factory defaults entirely and drive like the real car it was meant to be. Help your vehicle find its real potential!
    scoti1scoti1 Member Posts: 676
    Where do you live? I want to stay off the highways when in your neck of the woods, lol.
    I don't think this is how the learning process on these dbw's works. wwest has explained it before (and maybe will enlighten us again here, since I am not very technically astute) but what I believe he explained was that it resets itself each time you start and determines driving style within a few minutes of driving. This allows multiple drivers of a single car.
    I agree that the problem is not actually the transmission. I do believe that the computer software is the problem, not the transmission hardware. However, I am using the word transmission to refer to the entire drivetrain.
    So the DBW throttle delays acceleration to reduce friction and wear and tear in the transmission? Why don't they also design the brakes to delay or slow the application of the brake pads to the rotor? Won't this also reduce wear and tear on the brake system? Of course this will not be done because it is a safety hazard.
    When I step on the gas, I expect the car to accelerate. When it delays, it can cause me to be hit by another car, whether I am trying to merge and the acceleration is delayed or I am trying to avoid an oncoming car and the acceleration is delayed. This is the safety hazard that I see with this built in hesitation.
    montiemontie Member Posts: 10
    There are a lot of unanswered questions in your post. NHTSA does not support the safety hazard condition you see. The wear and tear idea you mention isn't proven. It's just a concept tossed out by posters so there is no way of knowing if it's right or not. The built in heasitation theory does not appear to be there for everyone so how is that a done deal? Our ES 330 goes when you step on it so why does ours do it and yours doesn't? Just wondering.
    I have seen releases from Lexus stating that the transmission performs the way it does to protect the transmission. I have also seen articles that describe the exact problems that I have with my ES. Lexus' response to these articles is to say that the transmission is "operating within design perameters". When I had the firmware upgrade done on my ES last year, the low speed hesitation was dramatically reduced. However, the higher speed hesitation is still very present.
    motownusamotownusa Member Posts: 836
    I think some folks are passing their personal subjective opinion as facts which I think is a disservice to this board. While I understand some people might not like the way the transmission behaves; calling it a "problem" or "dangerous" without collaborating evidence is not called for. And yes Lexus has issued a TSB for those dissatisfied owners who don't like the way the tranny shifts. A TSB does not imply the transmission has a problem. It is just Toyota's/Lexus's attempt to satisfy the few owners who are unsatisfied with the tranny performance.
    I understand wher people are expressing personal opinions and that's alright with me. I think it's alright to question their opinions and that's what I did.
    Now I can't find any articles from Lexus about transmissions protecting the transmission or seen Lexus articles that describe the exact problems he says he has. All there is are posts like his saying that someone from Lexus said this or that. I question the existence of these articles and would be more sympathetic if I could find them but they don't seem to exist.
    billranbillran Member Posts: 113
    motownusa, you are absolutely correct. And it is the distorted and exaggerated statements, presented as facts when they are not, that cause so much controversy.
    As you stated those statements are not only just a disservice to this board, but also discredit to some extent the claims of the few people who do indeed actually have a problem.
    The drivetrain, as designed, performs perfectly for me, my two coworkers and obviously for most of the owners of the hundreds of thousands of the cars on the road today.
    user777user777 Member Posts: 3,341
    oh my, someone argues that the NHTSA hasn't even investigated hesitation, rather unintended acceleration, and we have you arguing NHTSA "does not support the safety condition you see".
    confused. to be fair, you're going to have to discuss this amongst yourselves so your position is consistent.
    montie, if a person driving their car feels unsafe, they are unsafe no matter what our opinions may be.
    A person's personal feeling about something DOES NOT
    establish it as a fact. It is that person's personal feeling. I think the NHTSA is the most objective body of people who can decipher the fact from all the hype and rhetoric.
    Gee, I wonder why ? I mean this discussion has been going on for four years now. Maybe the people running the NHTSA have concluded that the "problem" or "issue" or "glitch" or whatever else you want to call it does not constitute a safety concern. If you are really one of the owners who feel otherwise it would be better to just sell the car and buy something else. Regurgitating the same stale rhetoric day after day month after month does get a bit tiring.
    when those that clearly admit that don't have the problem, have never experienced the problem, go on to state emphatically that it isn't unsafe or hazardous.
    Obviously I assume these complaints are real and maybe that makes it easier for me to imagine myself in the circumstances described, or maybe I have enough lifelong driving experience that I have encountered "like" circumstances.
    In any case I don't have any problem believing that a 1 or 2 second delay in engine response could potentially be a very frightening and therefore hazardous circumstance in most situations described in the TSB.
    my position is - a driver who does not feel confident operating their vehicle, being unable to predict the automobile's response to control inputs, with system behaviors colliding or being discrepant with potentially decades of sub-conscious cause-and-effect learning *IS* at risk, including his/her passengers, and other people on the road. the degree to which this is an absolute truth will be a function of many factors, some of them under the control of the driver, and many which are not.
    this position is not limited to a particular manufacturer or particular vehicle, or isolated to an issue with hesitation in vehicle acceleration.
    regards.
    "...a person's personal feeling about something DOES NOT establish it as a fact..."
    Well it certainly does for the person having the experience!
    FEAR has differing levels of affect on each of us. Put almost any of us in a potentially life threatening situation, one that we haven't experienced before and came upon us unexpectedly, and the result oftentimes is to FREEZE our entire mental process.
    Are we all becoming shrinks here? We are supposed to be dealing with hesitation questions. Insted we get a bunch of psycological advice to the lovelorne and stuff like this.
    "montie, if a person driving their car feels unsafe, they are unsafe no matter what our opinions may be"
    Everyone knows that. I accept that also. I certainly don't doubt that poster's feelings about what he sees as a problem. All I said was NHTSA doesn't think it is a safety problem because they didn't investigate it. I don't think its a safety thing, NHTSA doesn't either, but that is not saying someone else can't feel different. Honest guys, I don't need all that councilling, but thanks anyway!
    Now then. Back on track please? I asked some questions about hesitation. Does anyone care to answer them?
    Where does Lexus say that a hesitation or delay is built in to all their transmissions?
    Why do most of them not do it and others do? Mine doesn't so why does someone elses?
    How many actually do this? Doesn't look like very many do.
    Where does Lexus say that the hesitation is there to protect against exces wear of some internal parts like Clutches?
    Where does Lexus describe their transmissions will have the same things people here say they have happening?
    Someone said there were articles about these questions. well I cannot find any so can someone point me in the right direction?
    shepalishepali Member Posts: 72
    Montie - goto http://www-odi.nhtsa.dot.gov/
    Select 'Consumer Complaints', 'Search Complaints'
    Then follow the right side prompts.
    Unfortunately, you have to start with a specific year, and then a specific model. This particular hesitation problem has been ongoing since 2002, so you have to search each year since then. And...the models are sometimes split between 'ES' and 'ES300' and 'ES330' - so you have to search each one separately. I have not counted - but I would venture to guess there are between 50-100 complaints, maybe more!
    Hope this helps.
    Thanks for the help. I did that already. There aren't as many as you guessed there are. I counted abot 20 since 2002. There are a lot of duplicate ones. there are some about unintended accelleration.
    In the announcement that the Camry was the top selling car for the 4th year in a row, they mention that in 2005 Toyota sold 432,000 Camrys. If only half of those were V-6s, then there were at least 200,000 V-6s Camry's sold. If you add to that the sales of ES-330s, RX-330s, V6 Highlanders and Siennas I would guess that at least 300,000 total new V-6 5 speed drivetrains were put on the road in 2005. Multiply that by the last 4 years and you have well over a million. And I believe that is a very conservative estimate.
    Now, if every single one of those cars had this glaring "safety" issue, where are the complaints? If even only 1 out of 10 people actually complained that you be over 100,000 complaints, and that would certainly get some attention. Yet all we can find is maybe 50?
    Over a Million people driving cars with a defective drivetrain and safety issue and only 50 complaints? Just does not add up.
    Now imagine this. I buy a car but don't like to way it performs. I complain but no one listens. Now, if I can portray it is a Huge Safety issue that affects all similar cars, mayby now somebody will listen
    I couldn't agree more with your 'title'!
    For those of you who don't have a problem, and don't have any advice for those of us who do - can you please refrain from posting.
    I too am VERY tired of hearing this is just MY problem. This problem is VERY REAL for those of us who experience it. I understand that not everyone one does - but that does NOT make it OK, NORMAL, or RIGHT. I have owned and driven a lot of cars in my life - and I have NEVER experienced a car THIS BAD!!!
    I'm not JUST experiencing a slight hesitation when accelerating. This car is absolutely HORRIBLE to drive - both from an experience perspective, AND a SAFETY perspective. This is a NON-STOP problem that I experience at ALL TIMES I am driving my car, EVERY DAY I drive my car. It is worse in slow maneuvering and stop-and-go traffic - but it occurs ALL THE TIME.
    But regardless of all of your opinions out there - when a car that you pay this much money for makes you THIS unhappy and is THIS HORRIBLE - then the dealer or the manufacturer should DO SOMETHING.
    I have asked both the dealer and the manufacturer to just buy this car back at an amount where they would either break-even, or maybe even MAKE money. But neither are interested. Thus, I am in the process of filing a DTPA suit against the local dealer, and a Lemon Law claim against the manufacturer - please wish me luck, and let me know if you have any pointers on either of those fronts.
    I also have messages via email, phone and fax into the NTHSA as to the status of my complaint and any investigation into the matter - but I'm not very hopeful on that front.
    Why ???? So the forum becomes a venue for anti Toyota/Lexus drivels most of them without merits. This forum is open for anybody who has an opinion about the issue. This forum certainly isn't only for "this car is a death trap", "this car is a piece of junk" crowd. And those of you who have this so called "hesitation issue" what exactly meaningful have you contributed. I see the same anti Toyota/Lexus message over and over again.
    in post #923 I proposed one possibility for which a very few owners might experience the hesitation problem. Post #940 goes into even more detail as to why the uniqueness of some FEW driving "styles" might more readily open the "trapdoor" type design flaw in the Toyota/Lexus engine/transaxle ECU firmware.
    For those of you not experiencing the hesitation symptom, obviously the clear and certain majority of owners, why not assume my theory is correct, that those experiencing the problem have an as yet undefined uniqueness in there driving style which by pure happenstance results in inadvertently exposing the otherwise MINOR firmware deisgn flaw.
    And for those of you who do not wish to think of it as a design flaw look at it this way.... With this type of adverse publicity going on continuously wouldn't Toyota immediately issue a TSB as a "fix" if they could nail the problem down?
    So why don't we proceed along those those lines? Then there will be no reason for anyone on either side of the "fence" to be insulted or offended by the discussion.
    Probably if participants strove to avoid genuinely hyperbolic statements on either extreme (e.g. "the problem is imaginary" or "it's a death trap") then most people would sit on their hands and avoid personal comments.
    jonpnjjonpnj Member Posts: 52
    I see this discussion is on the hot list. I have driven quite a few cars in my life. In a few of them, I have noticed what I consider a lag from initial acceleration. It can be annoying. It seems to be more pronounced in some cars than others. I am wondering if the transmission in the Lexus is the same as in its Camry sister. They are speed automatics, correct? I can't imagine the ES having its very own transmission when it shares so much of the Camry parts bin.
    Isn't that the truth!! Your questions are perfectly OK,and completely valid. Because no answers are forthcoming by those making the statements leads to a belief they were made out of frustation as opposed based on fact. Frustration by those who claim they have the issue runs high, so you'll have to excuse them if some responses aren't always friendly.
    Some advice: Try not to respond to "suggestions" that you're not welcome here and should not be posting. It's happened to others, myself included, and you just have to roll with it. I sometimes wonder if those comments aren't intended to throw everything off track, but it stands to reason that anyone who considers this hesitation issue a big deal will be a little testy when they think someone is challenging them.
    Don't allow a little testiness to discourage you from posting here and asking some good questions. They should be asked, and it's OK to do so.
    Worth a try.........??
    For those of you having hesitation problems you might try applying a (VERY) light touch with your left foot to the brake in instances where you foresee the possibility of a quick return to "acceleration" mode.
    The 2004 RX330 Lexus shop manual indicates that the transaxle will drop out of O/D the instant the brakes are applied. So just maybe it might prevent the upshifting of the transaxle during brief periods of coastdown.
    The engine/transaxle ECU firmware appears to be sensing that the driver wishes to go into cruise mode when the gas pedal is released or slightly released (coastdown..) and therefore it quickly upshifts to attain the best fuel economy.
    If instead you "apply" the brakes the ECU firmware is more likely to assume your wish is NOT to enter cruise mode but to slow the vehicle. It might therefore leave you in the current gear or maybe even downshift.
    Proposal for an aftermarket device to fix hesitation problems in all Toyota/Lexus 5-speed transaxles.
    Constantly monitor the gas pedal position via the OEM hall effect sensors. If/when the gas pedal returns to the "neutral' position check to see which gear the transaxle is currently in and automatically change the "shifter" electrical gear control contacts (there is no mechanical connection) to "command" a one-level downshift.
    If the brakes are applied simultaneously with the gas pedal being returned to neutral then "command" a downshift all the way into first. The vehicle will not downshift until the appropriate lower speed is reached.
    In both cases while the transaxle may not actually downshift due to roadspeed being too high it certainly would not upshift and later leave you waiting 2 to 3 seconds for it to downshift back into the most appropriate gear ratio for the acceleration level dictated by the new gas pedal position.
    If these were RWD vehicles I wouldn't hesitate to bring such a product to market but with FWD we would be incurring the liability that arises from FIRM engine compression braking on the front wheels.
    re the NHTSA reports. We could argue this until the cows come home and everyone coming up with different answers. Another complication is that not all complaints are filed under the same component or are filed under several different components. I took the time to check individual complaints, eliminating the duplicates and eliminating the unintended acceleration, for the 2002 Lexus ES300 when this was first being discussed and found over 40 complaints under this one model for this one year. Didn't look at other years. Didn't look at the Camry, Avalon, Highlander, RX-300, etc. So I would say you are low-balling it, Shepali.
    Anyone reading this who has the problem, file the complaint if you are dissatisfied. I think it is important also for those who had the TSB performed and still have the problem to make a complaint (or file with NHTSA again) because if NHTSA closed their investigation, it likely had to do with Toyota announcing the new TSB shortly after NHTSA saying they would look into it. So they need to know that the TSB is not the "end all".
    Yep, you got it. The problem is not unique to the Lexus ES300, even though that is the title of this particular forum. There is another in its infancy, "Toyota-Lexus Transaxle Shift Delay" and the earlier (now closed/read only) "Engine Hesitation" forum, both set up to address the problem as it exists in all Toyota-Lexus models and, respectively, in all makes and models.
    I just did a recount and did find more duplicate VINs. So the ones with unique VINs are 30.
    1.
    Make : LEXUS Model : ES300 Year : 2002
    Manufacturer : TOYOTA MOTOR NORTH AMERICA, INC.
    Crash : No Fire : No Number of Injuries: 0
    ODI ID Number : 759781 Number of Deaths: 0
    Date of Failure:
    VIN : JTHBF30G525...
    Component: POWER TRAIN:AUTOMATIC TRANSMISSION
    Summary: CAR WON'T GO INTO GEAR PROPERLY DURING STOP-AND-GO TRAFFIC OR PULL OUT INTO TRAFFIC WHILE TURNING A CORNER, RESULTING IN UNSAFE SITUATIONS AS NOTED BY OTHER CARS' HORNS HONKING AND BRAKES BEING APPLIED . DEALER SAYS IT PERFORMS AS DESIGNED BY FACTORY, AND THERE IS NO WAY TO FIX IT. *AK
    2
    ODI ID Number : 762166 Number of Deaths: 0
    Date of Failure:
    VIN : JTHBF30GX20...
    Component: ELECTRICAL SYSTEM:IGNITION
    Summary: THE CAR STALLS AND PAUSES IN TRAFFIC. THE CAR HAS ROUGH VIBRATION WHEN THE GEARS SHIFT. THE DEALER SAID THE COMPUTER WAS DESIGNED TO OPERATE IN THAT MANNER AND THAT THERE IS PRESENTLY NO CORRECTION FOR THE PROBLEM. THE DEALER ACKNOWLEDGED THE PROBLEM, BUT REFUSES TO REPLACE THE CAR OR TO BUY ME OUT BECAUSE THIS PROBLEM HAS NOT RESULTED IN ANY FATALITIES.
    3
    ODI ID Number : 762530 Number of Deaths: 0
    Date of Failure: January 1, 2002
    VIN : JTHBF30G025...
    Summary: WE HAVE AN ESCALATING SHUDDER WHEN DOWN SHIFTING THE TRANSMISSION. THE DEALER ACKNOWLEDGED THAT THEY HAVE A PROBLEM WITH SOFTWARE BETWEEN THE ENGINE AND THE POWERTRAIN/TRANSMISSION. THEY DO NOT HAVE A FIX AND ARE ASKING CUSTOMERS TO DRIVE THE VEHICLE FOR ANOTHER POSSIBLE 45 TO 60 DAYS UNTIL THE FIX IS ISSUED. WE HAVE REQUESTED ANOTHER CAR SINCE THIS IS OUR 4TH ES400 IN THE PAST TEN YEARS AND THE 97 LEXUS WE TRADED WAS IN PERFECT CONDITION. WE ARE NOT WILLING TO WAIT FOR A REPAIR AND HAVE NOTIFIED THE COMPANY THAT THEY NEED TO RESOLVE OUR PROBLEM CAUSED BY THEIR DEFECTIVE PRODUCT WITH A NEW VEHICLE.*AK
    4
    ODI ID Number : 764271 Number of Deaths: 0
    Date of Failure:
    VIN : JTHBF30G425...
    Component: VEHICLE SPEED CONTROL
    Summary: WE HAVE A SURGE OR SKIP ON DEACCELERATION.THIS WILL HAPPEN FROM 40 TO 60 MPH. THE DEALER WILL ONLY TELL US THEY ARE AWARE OF THE PROBLEM BUT HAVE NO CURE. I FEEL THAT AFTER 7 MONTHS THEY SHOULD HAVE A FIX.*AK
    5
    ODI ID Number : 764487 Number of Deaths: 0
    Date of Failure:
    VIN : JTHBF30G725...
    Summary: CAR HAS VERY POOR SHIFTING CHARACTERISTICS. IT IS ALWAYS ANNOYING AND SOMETIMES UNSAFE. TWICE I HAVE STARTED TO QUICKLY ACCELERATE FROM A STOP TO TURN LEFT AND HAD THE TRANSMISSION START TO DOWNSHIFT THEN WAIT THROUGH A DELAY AS IF THE SOFTWARE WAS CONFUSED. THE RESULT WAS THE CAR SITTING IN THE INTERSECTION WITH THE ACCELERATOR DEPRESSED BUT NO POWER TO THE WHEELS FOR AROUND 1 OR 2 SECONDS. DEALER ACKNOWLEDGES "SHIFTING COMFORT" ISSUES ARE THE NUMBER ONE COMPLAINT FOR THE CAR BUT SAYS NO FIX IS AVAILABLE. I HAVE BEEN IN DISCUSSIONS WITH THE SERVICE MANAGER ON THIS ISSUE FOR OVER 8 MONTHS AND HAVE HAD NO HELP.*AK
    6
    ODI ID Number : 769597 Number of Deaths: 0
    Date of Failure:
    VIN : JTHBF30G120...
    Summary: SHIFT COMFORT ISSUE EXISTS AT SOMEWHAT PREDICTABLE DRIVING CONDITIONS THAT CAUSE THE DRIVER TO HANDLE THE CAR IN A CAUTIOUS MANNER TO AVOID VEHICLE MALFUNCTION. DT
    7
    ODI ID Number : 8018169 Number of Deaths: 0
    Date of Failure: August 25, 2002
    VIN : JTHBF30G920...
    Summary: WHILE DRIVING AT 20MPH AND WITH NO WARNING MAKING A TURN AND VEHICLE WILL STALL. IT WILL BE HARD FOR CONSUMER TO CONTROL VEHICLE. DEALER NOTIFIED.*AK
    8
    ODI ID Number : 10000029 Number of Deaths: 0
    Date of Failure: December 10, 2002
    VIN : JTHBF30G520...
    Summary: TRANSMISSION GETS CONFUSED WHEN SHIFTING INTO AND OUT OF THE LOWER GEARS, THEN SPENDS TOO LONG TRYING TO FIGURE OUT WHAT GEAR TO BE IN. THIS CAUSES DANGEROUS DELAYS IN ACCELERATION, THE EFFECT IS THE SAME AS A MOMENTARY ENGINE STALL. WE HAVE HAD THIS HAPPEN ON SEVERAL OCCASIONS, FREEWAY RAMP ENTRANCES ARE CERTAINLY THE MOST DANGEROUS PLACE THAT THIS HAS OCCURRED. DEALER ACKNOWLEDGES THAT THERE HAVE BEEN COMPLAINTS ABOUT THE SHIFTING DELAYS BUT THEY SAY NO FIX IS AVAILABLE. THIS IS OUR THIRD ES300, THE PREVIOUS MODELS USED A CABLE BETWEEN THE GAS PEDAL AND THE THROTTLE, THIS NEW ONE USES WHAT IS CALLED "FLY BY WIRE", A POSITION SENSOR ON THE ACCELARATOR THAT A COMPUTER IS SUPPOSED TO USE TO FIGURE OUT WHAT TO TELL THE ENGINE AND TRANSMISSION. IT ISN'T WORKING VERY WELL. IF NOT RECTIFIED THIS PROBLEM WILL CERTAINLY LEAD TO A CRASH SOMEDAY, THEN WE'LL GET TO SEE HOW GOOD THE SAFETY EQUIPMENT IS.
    9
    ODI ID Number : 10001095 Number of Deaths: 0
    Date of Failure: February 15, 2002
    VIN : KPHBF30G325...
    Summary: WHILE DRIVING THE VEHICLE AT ANY SPEED, THE ENGINE SUFFERED SUDDEN ACCELERATION. THE DEALER COULD NOT DUPLICATE OR CORRECT THE PROBLEM. TS WHEN ACCELERATING TO CHANGE LANE OR ENTER THE FREEWAY, THE VEHICLE ALMOST STALLED AND OR DECELERATED. SCC
    10
    ODI ID Number : 10004854 Number of Deaths: 0
    Date of Failure: January 8, 2003
    VIN : JTHBF30G625...
    Summary: THE TRANSMISSION HAD A JERK IN THE TRANSMISSION, THE DEALER TOLD THE CONSUMER IT WAS THE DESIGN THE OF THE VEHICLE. *TS *JB
    11
    ODI ID Number : 10012059 Number of Deaths: 0
    Date of Failure:
    VIN : Not Available
    Component: OTHER
    Summary: THE VEHICLE INTERMITTENTLY EXPERIENCED A HESITATION WHEN ACCELERATING, THE DEALERSHIP WAS UNABLE TO DUPLICATE THE PROBLEM. *JB
    12
    ODI ID Number : 10016697 Number of Deaths: 0
    Date of Failure: October 30, 2001
    VIN : Not Available
    Summary: 1) STUMBLE - THIS OCCURS WHEN YOU QUICKLY ACCELERATE AND THE CAR HESITATES FOR 1-2 SECONDS BEFORE IT KICKS IN. 2) SHUDDER - WITH NO PATTERN, THE CAR WILL SUDDENLY SHUDDER. THIS OCCURS WITH NO/LITTLE ACCELERATION. 3) SURGING - THE CAR SURGES APPROX. 1/2 FOOT WHEN THE AIR CONDITIONER IS ON. I HAVE NOTICED THAT THIS PROBLEM IS INTENSIFIED WHEN THE CAR IS SLOWLY (E.G., IN TRAFFIC) MOVING DOWN HILL. *JB
    13
    ODI ID Number : 10016699 Number of Deaths: 0
    Date of Failure: May 1, 2002
    VIN : Not Available
    Summary: 1. SHUDDERING TRANSMISSION IN STOP/GO TRAFFIC. 2. WHEN AT A COMPLETE STOP, CAR NUDGES FORWARD EVEN WHEN BRAKES ARE FULLY DEPRESSED. NOTIFIED DEALER AS WELL AS LEXUS CORP AND WAS TOLD NO FIX IS AVAILABLE AT THIS TIME. *JB
    14
    ODI ID Number : 10018429 Number of Deaths: 0
    VIN : JTHBF30G925...
    Summary: I HAVE EXPERIENCED SIGNIFICANT DELAY IN DOWNSHIFTING WHEN ATTEMPTING TO MERGE WITH TRAFFIC IN MY 2002 LEXUS ES300. FOLLOWING THE DELAY, THE TRANSMISSION SHIFTS TO THE TOP OF THE RPM RANGE EFFECTIVELY RESULTING IN NO ACCELERATION, THEN IT UP SHIFTS TO AN APPROPRIATE GEAR. THIS IS A DANGEROUS CONDITION. I HAVE HAD SEVERAL NEAR MISSES FROM BEING REAR ENDED AS A RESULT. THE DEALER HAS DUPLICATED THIS PROBLEM ON OTHER 2002'S AND LEXUS IN CALIFORNIA ADMITS THERE IS A PROBLEM BUT HAS NO FIX. I HAVE BEEN TOLD FOR ALMOST A YEAR NOW THAT A FIX IS COMING BUT STILL NO FIX. I HOPE SOMEONE DOES NOT GET KILLED FROM THIS DEFECT BEFORE IT GETS FIXED! PLEASE DO SOMETHING. *NLM
    15
    ODI ID Number : 10023430 Number of Deaths: 0
    Date of Failure: December 1, 2002
    VIN : Not Available
    Summary: THE 2002 LEXUS ES300 HAS A SIGNIFICANT FLAW IN THE NEW ELECTRONICALLY CONTROLLED TRANSMISSION SYSTEM. THIS FLAW HAS BEEN RECOGNIZED BY MULTIPLE DEALERSHIPS AND BY LEXUS CUSTOMER SERVICE. I HAVE BEEN WAITING FOR A RESOLUTION TO THIS PROBLEM SINCE DECEMBER 2002 WHICH IS SHORTLY AFTER I PURCHASED THE VEHICLE. THERE ARE THREE VERY OBVIOUS SYMPTOMS THAT HAVE BEEN OCCURRING EVER SINCE I PURCHASED THE VEHICLE. DEPENDING UPON FUEL AND DRIVING CONDITIONS, THE CAR WILL DEVELOP A NECK JERKING SHUTTER AS IT VIOLENTLY SHIFTS BETWEEN GEARS. THIS USUALLY OCCURS ANYWHERE BETWEEN 40 AND 50 MPH, BUT MOST OFTEN WHEN YOU ARE TRYING TO MAINTAIN A CONSTANT SPEED. THE SECOND CONDITION OCCURS WHEN YOU GO FROM A SLOWING SITUATION INTO AN ACCELERATION SITUATION. DURING THIS TIME, THE CAR OFTEN GOES INTO A NEUTRAL CONDITION AND TAKES A COUPLE SECONDS BEFORE POWER IS RETURNED TO THE WHEELS. THIS CONDITION IS VERY DANGEROUS WHEN MOVING INTO TRAFFIC OR TURNING A CORNER. WHEN TURNING, YOU WILL NEARLY COAST AROUND THE CORNER UNTIL THE POWER IS RETURNED TO THE WHEELS. WHEN THE POWER IS RETURNED, IT IS VERY ABRUPT AND LUNGES THE CAR FORWARD. THE THIRD CONDITION OCCURS DURING FULL THROTTLE ACCELERATION. THIS IS MOST EVIDENT WHEN ACCELERATING ONTO A HIGHWAY. THE CAR SEEMS TO SHIFT INTO A VERY LOW GEAR WHERE RPM IS NEARLY RED-LINE AND POWER IS ALMOST NON-EXISTENT. THE CAR THEN JERKS INTO A DIFFERENT GEAR WHERE YOU MAY GET MORE POWER, BUT IT DOESN'T USUALLY STAY IN THAT GEAR EITHER. IT THEN SHIFTS BACK TO THE LOW GEAR, RED-LINES AGAIN AND REPEATS THE PROCESS. THIS WILL OFTEN OCCUR 2 OR 3 TIMES BEFORE A GOOD GEAR IS FOUND AND YOU CAN THEN PROCEED WITH NORMAL DRIVING. AT THIS POINT, LEXUS DID MAKE A COUPLE LEASE PAYMENTS FOR ME IN EXCHANGE FOR WAITING A FEW MORE MONTHS FOR THE FIX. UNFORTUNATELY, THAT WAS NEARLY A YEAR AGO AND I'M STILL WAITING. WE NEED TO GET THIS FIXED BEFORE SOMEONE GETS INJURED, NOT AFTER! *NLM
    16
    ODI ID Number : 10037515 Number of Deaths: 0
    Date of Failure: September 8, 2003
    VIN : JTHBF30G720...
    Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
    Summary: DANGEROUS CONDITION EXISTS WITH 2002 LEXUS ES300, WHERE A SEVERE HESITATION EXISTS WHEN ACCELERATING AT SLOW ROLL (< 5MPH) AT INTERSECTION TURNS, EXITING DRIVEWAYS, AND GENERALLY ANYWHERE WHEN TRYING TO GET INTO FLOW OF TRAFFIC WHEN NEARLY STOPPED - ESPECIALLY WHEN A TURN IS INVOLVED ALONG WITH THE ACCELERATION. VERY DANGEROUS CONDITION EXISTS WHEN TRYING TO ENTER LANE, OR MAKE A TURN, IN FRONT OF FAST-MOVING TRAFFIC. IT SEEMS THE CAR'S ELECTRONICS DOES NOT REGOGNIZE THE ACCELERATOR'S REQUEST FOR FUEL UNDER THOSE CONDITIONS. A PRIOR LEXUS TSB ADDRESSED TRANSMISSION SHIFTING AT HIGHER SPEEDS, BUT SEEMS TO HAVE CREATED A NEW, AND POTENTIALLY MORE DANGEROUS CONDITION.*AK
    17
    ODI ID Number : 10037542 Number of Deaths: 0
    Date of Failure: September 7, 2003
    VIN : JTHBF30G820...
    Summary: I WAS DRIVING AT ABOUT 35 MPH ON HIGHWAY. WHEN THE TRAFFIC SLOWED DOWN, I APPLIED THE BRAKE TO BRING DOWN THE SPEED OF THE CAR TO ABOUT 3-7 MPH. AFTER FOLLOWING THE CAR IN FRONT OF ME FOR ABOUT 5 SECONDS AT ABOUT 3/4 CAR DISTANCE, I SAW THE CAR IN FRONT OF ME SPEEDED UP SLOWLY AND I DECIDED TO FOLLOW UP BY PRESSING THE ACCELERATOR MODERATLY. THE CAR FIRST SHUDDERED, THEN PAUSED FOR ABOUT 1 SECOND, AND FINALLY ACCELERATED AT ALMOST MAXIMUM POWER. THIS WAS A NEAR MISS. BEFORE THIS HAPPENED, I BROUGHT OUR CAR TO LEXUS DEALER TO COMPLAIN ABOUT SHUDDERING/PAUSING WHEN ACCELERATING FROM LOW SPEED AFTER THE CAR WAS UPDATED WITH TSB-TC004-03; THE CHIEF TECHNICIAN DROVE THE CAR AND REPRODUCED THE KIND OF PROBLEMS THAT WE HAD. HOWEVER, HE SAID THAT HE COULD NOT DO ANYTHING ABOUT IT AND WAS GOING TO WRITE A REPORT TO TOYOTA CORP BECAUSE IT WAS A SOFTWARE PROBLEM. ON THE OTHER HAND, THE RECEIPT FROM THE DEALER SAID THAT THEY DID NOT FIND ANY ABNORMAL TRANSMISSION SHIFT DURING TEST DRIVING, BUT WOULD FILE A REPORT. WHAT A CONTRADICATION! THE DANGER OF THIS TRANSMISSION PROBLEM WAS FURTHER MAGNIFIED BY THE FACT THAT 2002 ES300 RUNS VERY SMOOTHLY AT MOST TIMES (>98%). THIS SHUDDER/PAUSE/ACCELERATION OR PAUSE/ACCELERATION THAT ONLY OCCURS SPORADICALLY UNDER VERY SPECIAL CONDITIONS GIVES DRIVERS SURPRISE THAT IS THE LAST THING THEY WANT DURING DRIVING. FOR CURIOSITY, I TESTED DRIVING THE CAR FOR ABOUT 50 MINIUTES BY REPEATLY SLOWING DOWN TO ABOUT 5 - 10 MPH BY APPLYING BRAKE, THEN ALLOWING THE CAR TO ROLL FOR ABOUT 3 SECONDS WITHOUT PRESSING GAS PADDLE, AND THEN ACCELERATING MODERATELY TO ABOUT 20 - 30 MPH. THE PROBOBILITY FOR THE SHUDDER/PAUSE/ACCELERATION IS ABOUT 5%, WHILE THAT FOR PAUSE/ACCELERATION ABOUT 15%. IT SEEMED THAT THIS PROBLEM HAPPENDED MORE OFTEN ON DOWN/UP HILL.. *AK
    18
    ODI ID Number : 10061924 Number of Deaths: 0
    Date of Failure: March 1, 2003
    VIN : Not Available
    Component: VEHICLE SPEED CONTROL:ACCELERATOR PEDAL
    Summary: I PUCHASED A 2002 LEXUS 300 FROM WESTSIDE LEXUS IN HOUSTON, TEXAS. SINCE PURCHASE THE VEHICLE HAS SURGED WHEN SHIFTING AT LOWER SPEEDS NUMEROUS TIMES AND HAS SURGED WHEN THE VECHILE IS ON CRUISE CONTROL. I HAVE COMPLAINED NUMEROUS TIMES TO WESTSIDE LEXUS ABOUT THE PROBLEM BUT THEY AWAYS SAY THAT LEXUS IS AWARE OF THE PROBLEM AND IS TRYING TO COME UP WITH A FIX. LAST YEAR THEY ADJUSTED THE ENGINE CONTROL MODULE (ECM) CALIBRATION AND LEXUS SAID THE CAR SHOULD DRIVE BETTER - IT DID AT FIRST BUT IS NOW BACK TO THE SAME OLD SURGING AT SLOW SHIFTING SPEEDS. I BELIEVE LEXUS INTRODUCED THE ES330 MODEL THIS YEAR TO AVOID A PROBLEM WITH THE ES300 THEY COULD NOT FIX. I AM DRIVIG AN UNSAFE VEHICLE THAT LEXUS MAKES NO EFFORT TO FIX EXCEPT HAVE THE SERVICE TECH. GIVE LAME EXCUSES. I THOUGHT I WAS PURCHASING AN UPSCALE CAR TO DRIVE INSTEAD IT HAS TURNED OUT TO BE A MISERABLE UNSAFE EXPERIENCE. PLEASE MAKE LEXUS FIX THE DEFECT OR MAKE THEM REFUND ME MY PURCHASE PRICE. THANK YOU.*AK
    20
    ODI ID Number : 10075325 Number of Deaths: 0
    Date of Failure: August 1, 2002
    VIN : JTHBF30G220...
    Summary: 2003 LEXUS HESITATES ON ACCELERATION WHEN SLOWING ( E.G., MAKING A TURN) AND THEN PROCEEDING TO FULL SPEED. THE MANUFACTURER WAS AWARE OF THE PROBLEM IN PRESS REVIEWS ON RELEASE OF THE CAR, AND TOOK 2 YEARS TO PROVIDE A SOFTWARE PATCH THAT WAS ALLEGED TO HAVE CORRECTED THE PROBLEM. THE PATCH DOES NOT WORK, AND THE CONDITION IS A SAFETY PROBLEM.*AK
    21
    ODI ID Number : 10088532 Number of Deaths: 0
    Date of Failure: May 15, 2004
    VIN : JTHBF30G125...
    Summary: WHEN DRIVING A SPEED AND THE ACCELERATOR IS PRESSED HARD TO PASS OR TO ENTER A HIGHWAY, THE ENGINE RAVS BUT THE CAR DOES NOT ACCELERATE. THE DEALER TELLS ME THAT IS HOW THE CAR IS DESIGNED. I HAVE A 2002 LEXUS ES300 BUT HAVE DRIVEN THE 2004'S AND THEY ACT THE SAME WAY. WHEN YOU STUMP ON THE GAS AND THE CAR DOES NOT GO. IT LEAVES YOU IN A VERY PROCARIES SITUATION.*AK
    22
    ODI ID Number : 10089243 Number of Deaths: 0
    Date of Failure: January 5, 2002
    VIN : JTHBF30G620...
    Summary: WHILE APPLYING THE ACCELERATOR PEDAL, THE VEHICLE HESITATED TO ACCELERATE. CONSUMER TRIED NUMEROUS TIMES AND SUDDENLY THE VEHICLE ACCELERATED UNCONTROLLABLY. THE CONSUMER WAS ABLE TO MAINTAIN CONTROL OF THE VEHICLE AND DROVE IT TO THE DEALER FOR INSPECTION. THE MECHANIC DETERMINED THAT COMPUTER NEEDED TO BE REPROGRAMMED. HOWEVER, THE PROBLEM RECURRED. *AK *TC *JB
    23
    ODI ID Number : 10093211 Number of Deaths: 0
    Date of Failure: May 11, 2004
    VIN : JTHBF30G825...
    Summary: 2002 LEXUS ES300 WITH ABOUT 18,000 MILES HAS A PROBLEM WITH HESITATION WHEN ACCELERATING AFTER SLOWING DOWN, ESPECIALLY AFTER COMPLETING A TURN. IT IS LIKE THE TRANSMISSION DOESN'T ADJUST WITH THE PRESSING OF THE GAS PEDAL. ALMOST HAD AN ACCIDENT BECAUSE OF THE HESITATION. ALSO I HAVE HAD PROBLEMS WITH THE CAR DOWN SHIFTING AS I COME DOWN A HILL. ALSO A PROBLEM WITH THE CAR TRYING TO DECIDE WHAT GEAR TO BE IN WHEN GOING AROUND 20 TO 25 MILES PER HOUR. YOU CAN FEEL THE CAR CHANGE GEAR. PASSENGERS EVEN HAVE ASKED WHAT WAS THAT? COMPLAINED TO DEALERSHIP, AND WAS TOLD IT WAS THE WAY I DRIVE. I HAD THE SB-TC004-03 PERFORMED AFTER RECEIVING THE LETTER FROM LEXUS, BUT IT DIDN'T HELP. MAY HAVE MADE IT WORSE. *AK
    24
    ODI ID Number : 10099705 Number of Deaths: 0
    Date of Failure: November 9, 2004
    VIN : JTHBF30G320...
    Summary: WHEN ACCELERATING OR DECELERATING VEHICLE SHIFTED VIOLENTLY. DEALER STATED THEY KNEW ABOUT THE PROBLEM, BUT COULD NOT FIND A SOLUTION AT THIS TIME. *AK
    25
    ODI ID Number : 10102266 Number of Deaths: 0
    Date of Failure: September 16, 2004
    VIN : JTHBF30G020...
    Summary: I OWN A 2002 LEXUS ES300, AND THE CAR IS DANGEROUS! I'VE TAKEN IT TO THE DEALER MANY TIMES TO HAVE THE TRANSMISSION CHECKED OUT, BECAUSE IT HESITATES IN TRAFFIC WHEN YOU PRESS THE GAS.THEY JUST SAY SOME BABBLE ABOUT THE "TRANSMISSION JUST NEEDS TO GET USED TO THE DRIVER", IM SORRY BUT JUST BECAUSE WE CAN AFFORD AN EXPENSIVE CAR DOESNT MEAN THAT WE'RE STUPID. THIS IS MY WIFE'S CAR, AND I REALLY DON'T THINK THERE NEEDS TO BE ANY INJURIES OR FATALITIES TO HAVE SOMETHING DONE ABOUT THIS WIDE SPREAD PROBLEM. *AK
    26
    ODI ID Number : 10110385 Number of Deaths: 0
    Date of Failure: February 5, 2005
    VIN : Not Available
    Summary: MY 2002 LEXUS ES300 HAS HAD CONTINUAL TRANSMISSION AND SHIFTING PROBLEMS. WE TOOK IT IN FOR THE UPDATE BUT THAT DID NOT FIX THE PROBLEM. WHEN I ASKED AGAIN I WAS TOLD I ALREADY HAD THE UPDATE AND THERE WAS NOTHING ELSE THAT COULD BE DONE. I BELIEVE LEXUS NEEDS TO TAKE RESPONSIBILITY AND FIX THIS ISSUE. OFTEN TIMES I WILL PRESS THE GAS PEDAL TO QUICKLY GET OUT OF THE WAY AND THE DELAY IS NOT ONLY ANNOYING, IT'S DANGEROUS.*JB
    27
    ODI ID Number : 10116627 Number of Deaths: 0
    Date of Failure: June 30, 2004
    VIN : Not Available
    Summary: WHEN ACCELERATING IN MY 2002 LEXUS ES300, I EXPERIENCE HESITATION OF A FEW SECONDS BEFORE THE VEHICLE BEGINS TO INCREASE IN SPEED. THIS DID NOT SEEM TO BE A PROBLEM WHEN I FIRST GOT THE VEHICLE, BUT OVER TIME HAS BECOME EXTREMELY NOTICEABLE AND DANGEROUS SINCE I DRIVE ON THE MAJOR HIGHWAYS IN THE WASHINGTON, DC AREA. WHEN IT WAS REPORTED TO MY DEALER A FEW MONTHS AGO THEY EXPLAINED IT AWAY AND TOOK NO ACTION.*AK
    28
    ODI ID Number : 10130430 Number of Deaths: 0
    Date of Failure: July 23, 2005
    VIN : JTHBF30G225...
    Component: ENGINE AND ENGINE COOLING:ENGINE
    Summary: UPON ACCELERATION IN STOP-AND-GO TRAFFIC, SEVERE HESITATION WITH BRAKE-LIKE EFFECT, ENGINE REVIVING, WITH DRIVER THROWN FORWARD, THEN LURCHING INTO GEAR. SAID WAS FIXED WITH INSTALLATION OF TSIB TC004-3. NARROWLY BEING MISSED BY ONCOMING TRAFFIC WHEN CAR BASICALLY STALLED. TSIB NOT A FIX. NOW ENGINE LIGHT ON. DANGEROUS IN STOP-AND-GO TRAFFIC. *NM
    29
    ODI ID Number : 10131624 Number of Deaths: 0
    Date of Failure: August 4, 2005
    VIN : Not Available
    Summary: MY 2002 LEXUS 300 HAS A DANGEROUS AND SIGNIFICANT HESITATION AND SHIFTING PROBLEM. ACCELERATION IS SLUGGISH AND THEN SURGES FORWARD SUDDENLY CAUSING THE VEHICLE TO MOVE FORWARD UNEXPECTEDLY. IN ADDITION, THERE IS A REPEATED SHIFTING PROBLEM AT LOW SPEEDS WHEREIN THE VEHICLE CONTINUOUSLY SHIFTS IN AND OUT OF OVERDRIVE, AGAIN WITH UNEXPECTED AND UNCONTROLLABLE RESULTS. THE DEALER INDICATED THIS WAS THE WAY THESE CARS WERE ENGINEERED AND DID AN FIRMWARE UPGRADE. HOWEVER, THE PROBLEM PERSISTS IN MUCH THE SAME WAY. *JB
    30
    ODI ID Number : 10135396 Number of Deaths: 0
    Date of Failure: December 15, 2002
    VIN : Not Available
    Summary: THE FLAWS AND FAILURES OF THE TRANSMISSION IN MY 2002 LEXUS ES300 WERE NOTICEABLE WITHIN 500 MILES OF DRIVING THE NEW CAR OFF THE LOT. I NOW HAVE 47,000 MILES ON THE CAR AND LEXUS HAS PERFORMED RE-PROGRAMMING OF THE TRANSMISSION LOGIC. HOWEVER, THAT HAS NOT HELPED. IT SEEMS THAT AS I DRIVE MORE MILEAGE THE PROBLEM OF THE TRANSMISSION NOT KNOWING WHAT GEAR TO BE IN IS BECOMING WORSE. THE RESULTING HESITATION IS DANGEROUS FOR THE DRIVER AND OCCUPANTS OF MY CAR AS IT RESULTS IN CLOSE-CALLS WITH OTHER VEHICLES HITTING ME FROM BEHIND DURING HESITATION. *JB
    Just what is your point scoti? I dont think anyone ever said these reports did not exist. I also see a lot of "VIN: Not available" so the possiblity of multiple posts by the same people is not only possible, but likely. And for someone who does not even own an affected vehicle to go to the great effort of collecting and posting all of these is certainly curious indeed. I guess we could plaster this board with testimonies of great performance too but I am not sure it would prove anything. Just as the posts above dont prove anything we have not already discussed. I personally think it is a bit absurd and I am really starting to have serious concerns about the motivation here.
    I made a mistake and checked the total cars sold and I also lowballed it bigtime. The total combined sales for the V6 Camry and Highlander, ES330, RX330 and Sienna for the last 4 years is actually about two million cars (107,000 RX330s in 2005 alone). So again, if this big safety issue applies to all the cars, and only one in 10 people even reports it, we are still short 199,970 complaints. We are going to need a much bigger discussion board.
    :P You haven't figured him out yet. He is our resident anti Toyota/Lexus crusader. You will find him in just about all the Toyota/Lexus forum preaching his anti Toyota gospel. If you want I can keep counting on how many forums he has visited and how times he keeps linking those websites to the hesitation forum. :P
    ahh - if anyone should look in numerous forums, one will find wwest (and other "regulars") actually helping people of various makes and models of vehicles. what you will not find is him nor anyone else (at lest that i have read) preaching any anti-Toyota gospel. his motivation, and the motivation of others like myself and scoti1 are quite legitimate and sincerely focused on helping other vehicle owners.
    these are truthful statements. if you care to prove me wrong, you may.
    if someone would like to get this forum shutdown just like the Engine Hesitation All Makes and Models, why not be a bit more overt about it? what is the motivation to do that?
    factually, wwest has added more to this discussion topic than anyone. it's true he's been theorizing and it's also true his theories are a bit hard to follow, and change a bit from time to time, but at least he has people discussing the phenomenon, and what might be causing it, and he's an open minded soul, and he's been doing some research on the issue, searching for and consulting technical materials so that he may write on the subject from a more informed perspective.
    in contrast there are a few posters that keep on asserting "regulars" are trying to run them off, and that some are not welcome, and that while there is the apparent sincere belief that the posters are unhappy with their ride, it's not a problem, it's not significant, it doesn't impact safety, it's not the responsibility of the manufacturer to make right, they don't experience any problem and therefore it's very difficult to believe one exists.
    so i ask, what have they actually provided which furthers the discussion besides presenting arguments for dismissing the reports of those with the problem?
    in 5 minutes I scanned the NHTSA site for 2002 model year ES300s for complaints on operation of the drivetrain and hesitation, and found approximately 30 unique hits. ok, they might not all be unique. ok - maybe someone is bent on casting toyota/lexus in a bad light by making multiple submissions to the agency. i conceed that probably happens. but clearly, I didn't even try to look for other Toyota or Lexus models nor other years. how is it that i was so successful, when we have posters that can't seem to (or is it don't want to) find more than 10 to 20 total?
    remember, that was 30 for 2002 Lexus ES300. i didn't bother searching for other years or models. i don't need to. i've been contemplating the reports of people with the problem and taking them at face value.
    anyone following this discussion that's open minded sees there is a deliberate attempt to cast doubt on the validity of the postings by people with the hesitation, and to also label others as motivated to bring down the house of toyota.
    please.
    why i wonder can't these posters conceed there are people deserving of better treatment by the manufacturer, and take at face value their concerns re: drivability, acceptance, expectation of performance and service, and even safety?
    for the record, i didn't play the safety card first.
    numerous posters with the hesitation issue did that. it is true that i have been arguing there is a branch of psychology called "Human Factors" with specialists (also tending to be computer scientists or systems engineers - thus trained in multiple relevant domains) that deal with human / computer interaction and complex systems.
    they analyze the performance of humans "in the loop" performing tasks and assess impact of design attributes / affordances / indications / behaviors which collide with or fail to support prior learning, an appropriate mental model consistent with the design / functional model, human capacity and our limitations (along the lines of mental processing time, perception, motor control, memory (short- long- and memory organization(narrow / wide vs. deep / shallow), abstraction, simulation of future events, decision making etc, etc).
    they should be the ones looking into the issue here. i'm quite perplexed myself that i cannot find significant writings w.r.t. human factors research and the automotive domain, dealing specifically with issues such as this one.
    at least not yet. ;)
    Sorry I don't take anything posted on the internet at face value. The Nhtsa website is filled with duplicates and fake VIN #. While I respect some of WWEST's opinions I certainly don't agree with all of them. And regarding Scotie, I don't know what is personal motivation is; but he seems to have gone through a lot of trouble cutting and pasting the engine hesitation complaint from all over the internet and posting it here. I see him sometimes in the Camry, Highlander and Avalon forum and trying this same thing over there. I find his intense obsession with this particular topic rather curious and I must say i am a bit skeptical of his true intention.
    even I no longer believe in some of my theories.
    Thank you Scoti for listing all those "Complaints" from NHTSA. You certainly saved some of us the trouble, and you are to be commended for your efforts. (In doing so it looks like some aren't too impressed and now think you are an anti Toyota advocate--go figure!)
    However, I think your diligence has exposed a serious example of how the complaint system at NHTSA is exploited. You deserve MANY thanks from everyone for that!!
    I believe at least 25 of the 30 "complaints" listed by you are counterfeit. Call them fakes, bogus, frauds, dishonest, or whatever you like, but on close examination there is absolutely no doubt they aren't legitimate.
    Reasons for concluding this are because of some disturbing anomalies with VIN numbers in many of the "complaints".
    Here's what jumps right out:
    Eight have no VIN number listed at all--"not available". This could be because complainants don't know what it is or how to find it, but I seriously doubt that. VINs are very common knowledge and easy to source.
    Nine have consecutive VIN numbers with only one digit changed. They are shown as a distinct unique numerical sequence in the last three digits; JTHBF30G025, 125,225,325,425,525,625,725 and 925.
    Eight others contain another unique numerical sequence listed as follows: JTHBF30G120, 220,320,520,620,720, and 820.
    Furthermore, if you also look closely at those other Toyota sites at NHTSA you mentioned, you will quickly discover the same peculiar anomaly common to all of them.
    So my conclusion is that some individual(s) are posting fake complaints at NHTSA to get attention by NHTSA, perhaps in the belief they are doing a service by making complaints look bigger than they really are.
    The reason why no investigation was done by NHTSA may even relate to this fraud. NHTSA verifies each one of their listed complaints by contacting the owner. Most likely it didn't take NHTSA very long to figure out this scam.
    What are your thoughts on this disturbing situation Scoti?
    I started to register a complaint with the NHTSA website. When I got to the request for the VIN, I realized that I did not want to register my vehicle with NHTSA, by VIN. When I decide to get rid of this car, I do not want a computer record of my "imaginary" problem.
