Toyota Sienna 2004+
They are telling me it's a Gulf States only option, and they can't get it due to restricted distribution channels in the different regions.
I'm not sure I buy that exlpanation and was wondering if anyone else out West has one of these items on their Sienna.
Of course you could still have a catastrophic type failure which would be very rare, but would leave you stranded.
I've said this before, if run flats were a good idea, all the Siennas would have them, not just the AWD models where there is no room to bury a spare.
Unfortunately, most minivans are switching to red turn signals in the rear. Chrysler did it for years already, and now Ford Freestar switched to red, and so is the Nissan Quest.
Some people say that red is easier for the eyes, but that's only at night, sitting at a traffic light for 10 minutes and the car in front of you (with a yellow light) is signaling 10 minutes none stop... I hope you get the point... But that's for sure, amber lights are much more visible, and, therefor, a safer choice.
I was going to order the temporary from Sears, but then I got to thinking about what you said about how it might harm the AWD system. Now these temp tires are not a lot smaller. I plugged the 2 tires into a tire calculator and the radius of the 225/60R 17 and the 155/80R 17 is 13.81 inches vs 13.38 inches. The circumference is 86.77 inches vs. 84.06 inches. Would this be enough to throw the AWD system out of whack?
So the options seemed to be: do nothing, get a temporary spare, get a conventional spare, or get a conventional sized run-flat spare. The problem with the latter two is the space they would take up in the back of the car on a trip.
And then I had another thought. If you want to use a regular non run-flat as your spare until you can get your run-flat repaired or replaced, the limiting factor seems to be that dealers don't have rims in stock. It is more likely that they would have at least one 225/60R 17 regular tire available. What if you just get a regular sized rim, either new or from a wrecking yard, and carry that around? It certainly would take up less room than with the tire. Then you could drive to or be towed to the nearest tire shop. They could put their tire on your rim and you could deal with ordering a new run-flat when you get home.
Or maybe this is silly. They could just as easily take your faulty run-flat off and put a new non-run flat on that same rim. Now I am getting confused again.
I believe the difference in this case is minimal, but still would 'bother' me knowing that the finely tuned AWD system would be off kilter for however long I run my spare.
What you DONT want to do is be like those people you see flying down the highway with their temp spare on, doing 60+mph.
Me ?? i wouldn't give it another thought. i wouldnt' want a spare taking up any room in the back seat.
All on the same stretch of I270.
Sienna: Idle 39db, Full Throttle 75db, 70 MPH cruise 70dB
Ody: Idle 41db, Full throttle 72db, 70 MPH cruise 70db
http://www.caranddriver.com/article.asp?section_id=3&article_- id=6647&page_number=4
If you notice the 0-100 speed and street start comparison for the ODY vs Sienna, the ODY gets down the road pretty good.
Idle: 40dB
70mph constant: 69-71dB
0-60: 9.3sec AWD. I did not test the FWD.
Ody
Idle: 38dB
70mph constant: 72-74dB
0-60: 8.4sec
I did not measure full throttle acceleration noise. I used G-TECH PRO (the old one) to measure 0-60.
Its a combination of road, wind, and tire noise along with a less compliant suspension that contribute the the Ody higher noise level. I took all my measurements with the dB meter "mounted" to the passenger seat.
For comparison the Kia, Ford, and Chevy were 40dB idle and 70-73dB at 70mph. The Crysler was closer to the Sienna. The Honda is a good van and clearly faster than the Sienna and I'm not bringing it down but to my ears and by my non-prefessional measurements its not the most quiet. If anything, it was the loudest at 70mph.
Anybody who says the Ody is quieter is absolutely lying. Everybody knows. Somebody needs to talk to that editor and straighten him out. He must be confused. Shoot. He probably didn't even test drive the Sienna! Some of the things some writers say makes you wonder if they even know what the heck they are talking about. They don't. Everybody knows.
Here's a link for you:
Letters to the Editors
Loaded rolling radius is what matters, not calculated radius or circumference. With the stiff sidewalls and 60 psi, it would probably be the same as the standard tires.
How easy is it to manually modulate your brakes if your ABS equipped system is on the fritz because you've removed the pumpmotor fuse? And are you gonna accept the liability when some poor unsuspecting TH reader actually follows your advice and then slides off of a rain-slickened road?
And do you consider "temporary" as in "temporary spare" meaningless?
I would go with the Sear's deal, since my dealer charged $190 for the tire <ouch>. But I felt better after picking it up, because I can easily do that with one hand (I am a 125 lb weakling).
Interesting that the max load rating of the spare is 1,819 @60 psi, while the Dunlop is 1,653 @51 psi. Probably made like the tires on semi's, skinny, but strong. Probably handles like a semi truck tire, too, hope I never have to find out
We have owned numerous new cars over the years and in fact just took delivery of our own Sienna XLE w/cloth. The new car smell will continuously diminish over several months. The upcoming summer months will accelerate the elimination of that new car smell because the higher temperatures will drive off the volatiles that are causing the odor.
I don't deny you may be very sensitive to the odors. We are all different. Cat dander drives me "nuts". My advise if the odor is hard to tolerate is to open the vans windows whenever you can, even if you just crack them open when parked; and to keep the ventilation flowing when diving the van. Also, keep the vents "open" so that you are drawing in fresh outside air into the van and not on "re circulation" which just recycles the inside air.
I would not recommend trying to cover up the odor with a spray or air freshener because all you are doing is adding another layer of "chemicals" to cover up the new car smell, which may aggravate your sensitivity to smells.
FYI, I just saw on the news that Cadillac is hard at work trying to formulate a way to PROLONG that new car smell. Go figure! ;-)
Hope this helps. Enjoy your new van!
Myles
Note, those kids that got killed by airbags were in the front seat, UNBELTED and playing on the dash when the car had a front end collision trigerring the airbag, so yes the airbag did kill them but if not the airbag then the windshield would of. See how the media spins it?
As I remember it the one area that was the most diverse, ABS vs Non-ABS, was single vehicle injury or fatal accidents. Apparently something about ABS equipped cars make them more prone to these.
The IMPROPER use was belting the child, with or without a child's seat, into the front passenger seat. "Belting", therefore no threat of flying through the windshield.
It's really the same problem of some adult of slight frame and weight behind the steering wheel and being injured by the airbag in an otherwise non-injury accident.
BTW - "brake assist" is standard equipment on the Sienna.
Some drivers are tending to drive their cars to the limit of ABS, ie driving such that even ABS cannot save them.
However this is not evidence that ABS is less safe. Its just not safer. From the IIHS site:
Quote:4. Do car antilocks reduce crashes? Although car antilocks perform well on the test track, there's no evidence they have made significant reductions in the number of on-the-road crashes. A 1994 Highway Loss Data Institute (HLDI) study1 and a subsequent 1995 study2 compare insurance claims for groups of otherwise identical cars with and without antilocks, finding no differences in the overall frequency or cost of crashes for which insurance claims for vehicle damage are filed. Because antilocks should make the most difference on wet and slippery roads, researchers also studied insurance claims experience in 29 northern states during winter months. Even here they found no difference in the frequency of insurance claims for vehicles with and without antilock brakes. A 1997 Institute study,3 as well as a 2001 update,4 reported no difference in the overall fatal crash involvement of cars with and without antilocks.
Federal studies of car antilocks are consistent with Institute and HLDI findings. According to one federal report, "the overall, net effect of antilock brakes" on both police-reported crashes and fatal crashes "was close to zero."5 The federal studies of effects of antilocks on passenger vehicle crashes found positive effects on wet roads and negative effects for run-off-road crashes. These two opposite results cancel each other. Leonard Evans, a researcher with General Motors, reported that antilock-equipped cars were less likely to rear-end other vehicles but more likely to have other vehicles rear-end them.6 Again, the net result was little effect on overall crash risk. In a study done for auto manufacturers, Failure Analysis Associates reported a net beneficial effect of antilocks on nonfatal crashes but no effect on fatal crashes.7
5. Why aren't car antilocks reducing crashes as expected? No one knows for sure why their test performance hasn't translated into a significant reduction in real-world crashes. A possible reason is that the average motorist rarely experiences total loss of vehicle control, which antilocks are designed to prevent. There's also evidence that many car owners don't know how to use antilock brakes effectively. An Institute survey of drivers with antilock-equipped cars found that more than 50 percent in North Carolina and 40 percent in Wisconsin incorrectly thought they should pump the brakes.8 Another possibility is that some motorists may drive less cautiously because they believe antilocks allow them to brake better.
This was from the following: http://www.highwaysafety.org/safety_facts/qanda/antilock.htm
you write:
i'd have to agree - the automation may be enabling some driver's poor habits.
I strongly believe in VSC, I have it on my Sienna LE.
Once I start relying on VSC then there is no difference than wider tires???
There is a huge difference between VSC and wide tires.
VSC has little or nothing to do with getting more roadbed traction, it will allow you to use the traction that is there.
VSC is about keeping the vehicle on the chosen path, ie the steering wheel is pointed in a particular direction, the vehicle should be going in that direction. We have had this conversation before so I won't belabor the point.
I will take the time this evening to post information about VSC.
IMMHO VSC is intended for those times when there is really no way I can foresee and thereby prepare for an "on the edge" event. Unseen unpredictable black ice as I enter a curve, as an instance.
initially, ABS was hailed as a technology which would dramatically improve safety. for various reasons, this appears that it may not be the case.
VSC looks great. these websites showing cars zipping around corners at the limit of the test driver (hmmmm), track and vehicle capability...very impressive.
we need to be careful to avoid putting ourselves into the situation where we must rely on the technology to keep the car going straight and under-control.
OK OK. so there are situations where people (good drivers and bad) will unexpectadly find themselves in a jam, and yes, maybe VSC will make the difference.
but still, is the extra complexity and cost justified? like ABS, will down the road we find out the technology hasn't lead to the dramatic improvements in safety which were advertised?
i wonder.
we need to slow down, refuse to answer the cell-phone, take it off cruise control, and drive.
Pardon me..........???
Counter-steer against the driver's steering inputs??
Catch 22 multiplied by the thousands.
My steering input would have put me "safely" around the corner and NOT over the cliff at the edge of the road. The car tends to oversteer and BMW automatically countersteers, which I detect and correct, since I don't want to go over the cliffside, BMW again countersteers against my new inputs to prevent oversteering.....
Isn't that a lot like limiting the climb rate of the airbus that crashed years ago due to computer interference with the pilot's inputs??
'[Your] steering input would have put [you] "safely" around the corner and NOT over the cliff at the edge of the road' only if you were already steering as their system would.
If not, then your personal control decision to maintain a steering angle too great to retain friction would still result in your vehicle going off the cliff -- it's just that you would slide off sideways! ;-)
When ABS went to all four wheels, I think safety actually took a step back. Front wheel lock up does not cause a loss of control. My experience, particularly on gravel and rough surfaces is that the ABS increases stopping distances. When the fronts lock up, they are very effective at braking (although the tires may be worse off for it.) With ABS the tires free wheel until suitable traction is sensed.
The only time I can see an advantage to front wheel ABS is a panic stop and turn combination. This is very rare and there a very few drivers who know the limitations of their vehicle enough to try this.
