Engine detailing/cleaning on newer vehicles
                    I did a search of the past archives and haven't found much relating to cleaning engines on today's vehicles with tons of electronic components.
In the old days, you would just spray gunk on the engine block, let it sit for ten min, start the vehicle and hose off the grease. Now, you are lucky to see 6 square inches of the engine block without interference.
Does anyone have any suggestions for cleaning newer engines? I am going to be doing a bunch of fluid changes on my car with 35k miles and would really like to clean the engine.
Then I spray the engine with a citrus based cleaner and let it sit per directions.
I hose it off with a fine, steady stream of water. I then start the engine to dry some of the water. Shut off engine and hand dry as much as I can.
Any serious cleaning should be done by hand with mild cleaner and an old wash mitt. Rinse lightly. Final step is to apply a water-based protectant to exposed components.
Most modern engines seem to have a large plastic cover that needs to be removed to actually see the engine. Be careful with them as they can be expensive to replace.
Hope this helps.
I clean my engine about every other time I give the car a good wash. Really freaks the dealership technicians out to see "clean" under a hood.
I already use Armor All for hoses and belts. Is there a better product out there?
Not all silicones are bad (there are something like 30,000 silicone formulations) but you have to dig deep to find the protectants that are water-based and use non damaging silicones. Some products are:
303 Aerospace Protectant
Lexol Vinylex
Eagle One Interior/Exterior Protectant
Pinnacle rubber and vinyl lotion
If you want to leave a nice gloss all over the engine there are a few products that work well. The best one I know of is a pro product called Meguiar's Engine Kote; gotta buy it by the gallon, though.
Armor All has reformulated their protectants and some are now water-based. But for many years their products were completely awful and I will never suggest or buy their products again.
There's no real drawback to steam cleaning versus high-pressure, except that the steam fogs your glasses. The same precautions, as far as electrical components, should be taken, but usually aren't.
It's too easy to screw something up by getting water into things.
As far as Armor-All...I happen to think the stuff is pure garbage! It leaves a slimy artifical look and feel to everything. I once applied it to my dash and the next week the dash was cracked in three places.
Professional detailers hate it too.
Jim
Detailing since 1978
