Oil extractors - ok to use?
                    Are there any disadvantages to using a pump extractor instead of draining the oil the traditional way?  Thanks.
there are service-mechanic pressure flush systems out there that send a shot of solvent into the engine, then flush that out with new oil. there has been a discussion of those on here, and the grizzled mechanics pale at the thought of the machine disturbing gobs of gunk that lie at the end of passages in older engines, all the slop falling to the pan and plugging the oil strainer and pump.
I prefer myself not poking around dark caves with a stick, because you never know what you're going to stir up out of a nap. same thing with the powerflush rigs.
as for pulling out all the oil... I doubt it very much, thanks. in particular, I would not expect a pump extractor to get the sandy crud with the little metal whiskers that is in the bottom of the pan. if the oil isn't warmed up (not hot) when you drail it through the drain plug, you probably won't get rid of that crud by a pan drain, either... not all of it.
but if you do even-numbered oil service with an extractor and let an oil change outfit or the dealer do a pan drain job on the odd numbered ones, the chance of having enough crud to cause trouble is still pretty small.
a reminder that if you don't remove and replace the oil filter with every oil change, there is still a quart of old oil that will remain in the engine. finish the job with a new filter before you turn off the suctioner... taking the old filter off breaks vacuum and there will be some dirty stuff that falls through the pump and into the pan. there will be a spill of dirty oil when you do this... in my (not world-class, and limited to a dozen or so domestics only) experience, if you work slowly enough when actually breaking the gasket seal between the filter and the pump housing, much of the oil will go into the pan, not down your arm.
Paul29: Do you know if BMW has designed it the same way as Mercedes?
For engine oil I do regular oil changes. However, I am considering alternating a complete change with a suck-and-fill change (changing also the filter...). Only problem is that the dipstick tube may have kink somewhere, and your pump may not be able to get all the way down to the bottom of the pan, and it won't pick up water/coolant that may have found its way into the engine (water is heavier than oil...).
Now, If it does go to the botom, and if the vaccum is good, it should be able to pick up grime pretty good with the oil hot.
Let me know how it goes if you decide to do it. Cheers,
G.
I have a Mityvac 6.5 liter vacuum pump that is quite outstanding. It can be used to extract virtually any fluid you desire.
