1979 truck - untraceable stalling
Anyone have any ideas?
I bought a 1979 pickup with a 350 v6,79K original miles (yes i have the original bill of sale and all registrations.
The truck runs fine but will stall occasionally even after riding for hours on the hwy at 60+ mph.
A mechanic looked at the carburator,fuel pump, fuel lines, alternator, battery and says he cant figure it out. any ideas?
It's just a matter of snooping I think.
make sure the vacuum advance motors at the distributor and the carburetor move when you pull their hoses off, or push in the diaphragm with the hose off, cover the nipple with your thumb to seal in the "vacuum," and release the pushing on the diaphragm. if it stays in, good motor. if it doesn't, diaphragm probably leaks, replace it.
little tricks like this will find a LOT of performance problems in a 60s or 70s engine.
I'm sure your mechanic has already checked this possibility. Just a suggestion.
I'm glad I read this thread. I had never thought to use a spray bottle to check for vacuum leaks.
Did your mechanic remove the top of the carbuerator, or just check mixtures while the engine was running?
Harry
BE SURE to get some dielectric grease at the parts counter when you get this dingus. you need to spread a pea-sized bit of that HV grease on the metal plate under the ignition module to get the heat out.
it's a pity that it's heatsinked to a distributor boss that is going to get warm. weren't those 350 distributors behind the engine? the ignition module from an aftermarket like Wells was cheap enough you should maybe get two and put one in the glovebox.
I had a 231 V6 buick with one of these, and took a long time before it got intermittent, a long time. mine showed up as intermittent rough running.. but the distributor on that mill was way up front, and stayed cooler.
A 70 ford has the electronic ignition module on the fenderwell. When they get hot, they have a tendancy to disconnect. Check wiring and make sure that the fuel lines are routed away from the exhaust. If they are close, then get some heat wrap and wrap the fuel lines.
It may be that the fuel system is vapro locking.
One other common problem I have seen on the older vehicles is that the pin for the lever on the fuel pump becomes worn. At idle, the pump will pump enough to fill the carb bowl, but at higher rpms, there is too much slop in the pin to allow the pump to pump enoug fuel to keep up with the demand.
While the pump may look good, if you can move the pump lever more than 1/8" before you feel resistance, then it may be the problem.
Two years later, it died on me again. I had to go on a business trip to Florida, so I just left it where it was, in my grandmother's yard, and decided to mess with it when I got back. 5 days later, it started right up.
Third time was a charm though. About 15 months ago, it tried the same stunt. This time though, it never did re-start. It was just a spare car by this time, so it was no big deal. Every once in awhile I'd just go out and try it, but it never di start. Finally I got tired of looking at it sit at the curb, and had it towed to the mechanic.
Huh? I didn't see that!
A 79 Ford with a V-6?? No that is a new one on me, unless it is a very big Ford.
Beginning to look like one of those test threads to me.
at any rate, if you have a magic transistorized ignition box that bolts to hot metal, suspect it.
Now Ford *did* have a really big inline-6 (often incorrectly referred to nowadays as a V-6, kinda like how people say "V-4") back then, which was a 300 CID unit.
I have heard of some Ford commercial trucks from back then, that had engines I'd never heard of. Awhile back, when I had to supervise an office move, one of the vans had, the guy said, a 352. Maybe Ford did have some big V-6 back then, too? At one time, GMC had a pretty big V-6, but I forget its displacement. I think it was a 60-degree engine too. They mated two of 'em together to make a V-12!
At 702 CID, one of these suckers would come out to a 351, which I'm sure has been rounded down to 350.
I wonder how long they made this engine for? (the V-12 and the V-6 version?) It wasn't still around in the '70's, was it?
and yes, it would take a LOT of oil for that thing. I bet they had twin oil pumps and maybe twin mechanical fuel pumps on that beast. idle or power issues would be fun to troubleshoot on that monster.
Of course that was just speculation, I have no experience with such engines.
TB
and indeed, you make sense here, tboner. I yield, air brakes would go with this engine's applications.
brain fade compliments of 1040 fever... catch it, my ( )!
I don't know what GM a/c compressors looked like back in the early '60's, but the one on my '67 Catalina is just the typical long cylinder. Chrysler used a V-2 a/c compressor. I don't know when they started, but my '67 Newport and '68/69 Darts had it. I think they used it up through '78, on the RWD cars, at least...I couldn't see a '78 Omni or Horizon with a compressor that big!
