Automatic Headlights
I have purchase a 99 Chevy 3/4 ton 4x4. I love
the truck, but question the automatic headlights
that come on when it gets dark. Anybody messed
with this option. I would like to disconnect it if
I can without effecting my regular headlight
switch. Let me know what you think. thanks
has driving lights that come on with the engine?
If you push the parking brake down halfway while the vehicle is stopped, these lights will go out - otherwise hunters would be "headlighting" deer accidentally.
This is the first I have heard of, or seen reference to, headlights that come on automatically? What would happen in a dark garage?
Front Porch Philosopher
SUV, Pickup, & Aftermarket and Accessories Host
and BAD in that.... When they take away too much of what the driver SHOULD be doing as a result of "situational awareness" it makes me nervous!....
Rich
Emergency brakes are mechanical systems, essentially what you are doing is adding tension to the system and locking the wheels. Any application of the brake is going to add tension and begin to apply the brake.
Can't say I'd be happy driving like that.
Me thinks that you only have to put the parking brake on enough to light the light on the dash and not enough to cause any braking effect.
Rich
I may be extremely naive, and as I say am used to having lights of some kind on all the time - but how can having lights on be a disadvantage??
Not trying to be difficult - just genuinely want to know
I can give at least one specific reason. I work on contracts that require me to enter secure military bases. They all REQUIRE you to turn off your headlights (parking lights are OK) as you enter the base at night. The entrances are well lit and the ARMED guards need to be able to identify you. Most of these guards are relatively young and in many cases carrying M16s. I definitely don't want to annoy them.
There are other situations where I want the engine running but don't want the headlights on. For this reason, I'm seriously considering disassembling the dash and installing an override for the light sensor. Just haven't gotten around to it yet.
John
I'm sure the 99 didn't have that feature so those people are forgiven.
Stevo
2000 z-71 ex. cab
Mike Freeman
Any update? Did your Z71 go to DRLs when headlights went off, so you at least had some light? Please advise. Thx. Scott
jim
When necessary, you may turn off the Automatic Headlamp System and the Daytime Running Lamps (DRL) feature by following the steps below:
1. Turn the ignition to RUN.
2. Press the DOME OVERRIDE button four times within six seconds. After the fourth press of the button, a chime will sound informing you that the system is off. The system will revert back to the automatic on mode when the ignition is turned off and on again.
3. To return to the automatic mode, push the DOME OVERRIDE button four times within six seconds (the chime will sound), or turn the ignition off and on again.
Gary
Have tried it out on my 2000 GMC and it works for me.
- Tim
anyone think of any badness by taking drl fuse out?- thanks
The dome-light override method doesn't work on the '99. :-(
at least on this one. My 97 F-150 and 98 Exp both have Autolamp and I can manually shut it off on the dash, don't have to do a lot of other stuff, like by passes, disassemble dash et. Good luck.
I really don't know how someone could hit a vehicle head on just because the DRL wasn't working.
The DRL is there because the purveyors of relays spread the myth through the legislative bodies that drivers can't see other vehicles without DRLs.
Actually the problem of DRLs could be solved at the service advisor's desk. Ask the question, "Where is the relay that I (Emphasis on "I") could manipulate to prevent the DRL from coming on." :-)
Rich
I would bet that GM isn't putting the override only on the higher priced models; instead, I think that they slipped it in at a certain point, probably after your truck was built.
DRLs are front only and reduced power, the automatic headlights are normal headlights but triggered by a light sensor.
There is (or was) a DRL option on my '99 Super Duty when I ordered it. When I mentioned to the sales manager that I didn't know that Ford offered it, his comment was that he had never ordered a vehicle with DRL.
There are situations where a DRL is advisable but I think that I would rather be in control. I wouldn't want a trucker thinking I was talking with my lights when I really wasn't.
Rich
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
